Question about SAMTRON 55V 15" CRT Monitor
Samsung Samtron 15" screen shinked both side horizonatally. All the Resolution settings are fine. But the problem is still ther. Pls help
Moniter male port are been damaged, so i want to reconnect the cable. Now i want a color coding
Posted on Jan 30, 2009
When I switch on my computer, Windows XP start loading and then my Samsung Samtron 45Bn monitor's screen goes blank and the green light keeps flashing every 0.5 secs.
It sounds like your video is set to the wrong resolution. Try booting into safe mode by pressing F12 at the start of the boot process. If you get into windows that way, then adjust the display to something you monitor can display like 1024x728@32bits. The monitor can only display a certain amount of pixels and if you set the video card to high you will lose visual. Hope this helps.
Mar 19, 2011 | SAMTRON 55V 15" CRT Monitor
I am trying to clone my lapptop image with a samtron 73.v and the samtron seems dead :-( It says Test Good but does not work
Most laptops have three video-settings:
* output only to internal screen
* output only to external monitor
* output to both internal and external
Select the appropriate video-setting.
Set your laptop's screen-resolution to 800-by-600 by 60Hz -- a resolution that should be compatible with any 15" Samtron monitor.
Dec 26, 2009 | SAMTRON 55V 15" CRT Monitor
I can not adjust the resolution in my samtron 55v i run xp on my pc
In Xp right click on the desktop and select Properties->Settings->Resolution. Here you will get all the options that the combination of your display adapter and monitor can take. select any that you want and Windows will show to the new resolution and ask you if you like it. Accept if you like it else Cancel it and select one lower or higher till you are satisfied. Go up one notch at a time.
Dec 07, 2009 | SAMTRON 55V 15" CRT Monitor
Resolution problem with xp
Here is a link to the instructions for resetting the resolution for your monitor: Resolution/Refresh
If you need other information about your monitor please look here
Mar 31, 2009 | SAMTRON 55V 15" CRT Monitor
Minitor is shrinked on both side horizontally. The settings are all ok and resolution is perfect. Seem some problem with CRT or something like H/W. Any help on this???
Open your on-screen display on your monitor, find & press auto adjust. If that doesn't work go to factory reset menu and pressed to reset to original settings.Then reboot your pc.
Jan 28, 2009 | SAMTRON 55V 15" CRT Monitor
Samsung samtron 55v display problem
assuming that u r a professional..
i guess there is no problem with ur monitor, it sounds like itz due to graphic adapter..either the adapter on ur system main/mother board/agp/pci/pcie is damaged or itz simply 'driver corruption'..
don't panic..check for driver update/download n reinstall graphic/display driver..
however, 1st make sure that the Screen Resolution (1024x768 or as applicable) and Color Quality (32 bit or as applicable) is correct..from Display Settings->Settings tab..
always better to contact system admin/vendor....
Dec 30, 2008 | SAMTRON 55V 15" CRT Monitor
Desktop screen is stretched abnormally
please trie and double check the resolution on the screen that its correct.
Also check so you dont use too much Hrz on the monitor/settings.
Jul 14, 2008 | SAMTRON 55V 15" CRT Monitor
Samsung Samtron 94V N Screen setting problem
Perhaps other than the screen resolution you need to also lower down the refresh rate (found in the advanced tab of the display properties).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 19, 2008 | Samsung 94V 19 inch LCD Monitor
Samtron 15" CRT monitor gone dark but readable!
Go to a computer fair and get a flat screen monitor for around $195 dollars. Why even keep this anicent artifact in todays new screens?
Feb 28, 2008 | SAMTRON 55V 15" CRT Monitor
Samsung SAMTRON 55V
just find it on just vote for me so that i can help u again
Aug 29, 2007 | SAMTRON 55V 15" CRT Monitor
SAMTRON 55V 15" CRT Monitor Logo
73 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
Richard Lilja
Richard Lilja
William Miller
William Miller
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
