Question about Smeg Dishwashers
I have a six month old Smeg, integrated dishwasher, model D1612CT which has been working fine until recently. The pots are not clean. The cups and mugs have tea "rings" around them and the glassware is covered in a "milky" film, which comes off immediately if rinsed under the tap. I stack the dishwasher as recommended in the manual. I use loose powder rather that tablets, salt and rinse aid. Can you please sdvise me?
  • 11 Answers
SOURCE: DISHES COVERED IN WHITE POWDER
To check on the source of the white powder (calcium?) soak some dishes in vinegar to see if this cleans them up nicely ... or if the 'white powder' is actually permanent etching. You may have very 'hard' water and will need to deal with that with a water softener or additives.
Read the following article for a better understanding and try the vinegar test . (also ensure you are using dishwasher specific salt to regenerate your integral softener... assuming you have one)
http://www.dishwasher-care.org.uk/best.html
Posted on Nov 02, 2007
  • 26 Answers
SOURCE: Dishes and glassware are not
never put silver in a dishwasher..
ensure the rotating arms are not being blocked by anything
Posted on Apr 27, 2008
  • 677 Answers
SOURCE: Smelly dishes
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Posted on Sep 07, 2009
  • 457 Answers
SOURCE: cloudy film left on glassware *rinse aid cup
make sure b4 you start the machine run the water until it is hot then start the machine. let me know if it works by sending me a 4 thumbs up post. thanks
Posted on Mar 01, 2010
clrvuedoc
  • 175 Answers
SOURCE: my glassware is coming out cloudy! the dishes are
If you have hard water, glasses can look spotted and cloudy even after cleaning. Sometimes changing the dishwasher detergent can help. The easiest solution to clearing up glasses that start to look cloudy is to add some vinegar to the bottom of the dishwasher before you start a cycle. Simply add 1 cup of white vinegar and it will clear up your glasses very well.
You should see marked improvement after the first time you do this. If they are not crystal clear then simply repeat the process until all of the cloudiness is gone. In fact I recommend to using a little vinegar in each cycle to maintain the clarity of the glass.
Note: you can pre-test this by rubbing some vinegar on an individual glass with a cloth. If you cannot remove the cloudiness by soaking it and rubbing vinegar on it then it is possible that the glass is etched due to harsh or cheap dishwasher detergent and vinegar will not solve the problem.
Posted on Mar 01, 2011
I cleaned out the filter on my Smeg integrated dishwasher, model D16012, yesterday then started a fully loaded cycle. The items were all clean when I unloaded but some water remained in the bottom of the...
It may be possible that something fell out of the filter and into the drain pump. The machine will do a short drain cycle at the start of a program and if it is jammed or blocked, this will cause this problem.
Jul 02, 2014 | Smeg Dishwashers
Re: SMEG Integrated Dishwasher ST663. I'm having
usually a screw on the striker (the bit sticking out that goes into the door) it will be a slotted adjustment so just loosen (not remove) the screw and pull it out a mm or 2.
retighten and test.
Also, clean the seal. While your at it, the sump filters and spray arms.
Oct 18, 2013 | Dishwashers
How do i fit smeg integrated smeg dishwasher
Not sure I understand the question. Are you asking how you fit your new dishwasher into the old dishwasher's hole, or are you asking how you get the actual measurements of the dishwasher because you're building a new set of cabinets and need to build it to fit?
Sep 02, 2012 | Smeg Dishwashers
I have a BOSCH model 53L06UC dishwasher and was
every bosch dishwasher unit is different. you can get odor from different source. #1 solution to fight odor is the proper maintenance. every month run the cycle with just a cup of vinegar on a hot wash. i am a old bosch tech and alot of people dont add the jet dry properly. this is for drying,spots and-cleaning you must add the jet dry or rinse agent (same thing)into the compartment. close compartment,then lower and raise door 3 times,then fill again repeat until you cant add anymore then it is filled.if this help please send me a 4 thumbs up post. thanks
Feb 28, 2010 | Dishwashers
I put in 12 cups of water and only 4 cups come out with coffee what is wrong with this. It is only one month old
This occurs occasionally if the unit needs cleaning or you are brewing a new pot of coffee immediately after emptying a hot pot of coffee.
Run a cup of vinegar through the coffee maker twice, run at least 2 pots of clean water through to rinse the vinegar out.
This should clear the problem until it needs cleaning. The suggested frequency of cleaning is every 30 pots, but this varies depending upon the type of water you use.
Nov 16, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Glasses in top rack not getting clean anymore.
-Have you changed the dishwasher soap recently? What are you using? Is the powder remaining behind in the soap dispenser?
-Have you removed the filter in the sump area, cleaned it and removed any debris under the filter. (watch out for broken glass that is almost always found in 5 year old dishwashers.)
-You are running water at the sink until it gets hot, but you may still have problems if the heating element has failed. Recommend you check that element. If you can get to the element, check resistence of the heater to see if is has any at all.
If heating element checks out good, the next common problem is a failing wash pump motor.
Mar 30, 2009 | Whirlpool 24 in. DU915QW Built-in...
GE 169164 Coffee Pot Not Brewing
Loosen the charcoal filter. You only need to GENTLY place it in. Your problems will all be solved. I just did it 5 minutes ago and i just brewed a 6 cup pot of coffee completely.
Jan 07, 2009 | GE 106591 Coffee Maker
Cuisinart Grind & Brew not using all the water in the reservoir
I was having problems like this and then I read on a different string on this website that people have had success by flushing the system numerous times (sometimes up to six times) with vinegar. I took out the charcoal filter and flushed once with vinegar but only saw a small amount of improvement. I was out of vinegar so I used Lemishine mixed with water and it went from making one cup to making a full pot with one flush.
Jan 10, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Help
We have a Smeg SA8605W which has had a similar problem 3 times in its short 3 month life. The problem with ours is that the control panel on the front pushes against a very brittle plastic frame to activate the micro switches. Because of the brittle nature the 'fingers' of plastic break off and either get stuck holding the machine in a set cycle or break off fully so nothing functions. Gaffa tape or Elastoplast is a simple solution.
Nov 08, 2006 | Smeg CSU2001 Built-in Dishwasher
Dishwashers Logo
75 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
