Utlima WT761 will only display final spin
It will only show 800 revs & even when the knob is turned it will not go to any other programme
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
WFS1073DD front load WASHING MACHINE Everything works but will not spin fast enough to spin the water out. It spins very slow
Early automatic washers used a motor with multiple windings to provide the various speeds required by different parts of each wash programme. Modern washers use an entirely different sort of motor and the speeds are selected and controlled electronically with feedback to ensure the speed is correct.
I suspect the problem is the electronics - the part of the programmer and controller that regulates the motor speed but you should check the motor and motor brushes, the drive belt and all electrical connections as a matter of best practice before you spend money...
Aug 13, 2017 | Washing Machines
How do you cancel wash cycle on candy do df 800 the programme is stuck on filling up so have turned water supply off but cannot cancel programme
Good evening Julie
you have problems with your Candy, so have I with mine.it is mostly when I am starting a drying program, that she starts washing again. Then I :
  • turn the machine off
  • Wait 3-5 minutes
  • Turn on emptying
  • Wait 3-5 minutes
  • Turn on spinning
  • Wait 3-5 minutes
Try this way, turning the machine off, waiting and over to the programme you want.
good luck
kolbrun
Aug 12, 2015 | Candy Washing Machines
I have s tecnik washing machine that shows flashing lights on start button along with flashing lights on 800 rinse speed and rinse and wash, I have cleaned out the filter which was blocked but can not get...
plug machine in
turn timer knob to 6 o'clock position
press and hold spin speed button
turn timer knob 1 click clockwise
release spin speed button
now turn programmer knob to off wait 5 secs and turn on
I had the exact same issueI
hopefully it will work but you may have to repeat a few times and some engineers say it only works with motor unplugged but I have not found that.
Apr 07, 2014 | Tecnik Washing Machines
Whirlpool awo/5556 programme knob displays wrong timing for wash cycle
Answered earlier , suspect this error can be due to internal clocking of the program controller unit.
Mar 12, 2012 | Whirlpool Washing Machines
Washing machine programme knob has been pushed into machine
Turn the D Shaped spindle with a pair of grips until your machine will do a spin cycle only .
When it can do that put the knob on the shaft with the marker on the knob pointing to the mark on the facia saying Spin
Jun 05, 2009 | Washing Machines
Error code F 21
I have a Bosch Classixx 6 1200 express washing machine showing error code F21 on the display, what is it?
Apr 05, 2009 | Bosch Classixx WFO 2866 Front Load Washer
Washing programme won't move from final spin
some **** or something is stuck in the drum. u'll have to get it repaired.
Jan 28, 2009 | Washing Machines
Indesit w11
does it have a manual programme knob?if it does ,probably the internal contacts do not mesh so it stops at next step (programme)but the water pump keeps on making the noise.
try turning the knob by hand when machine stops before entering next programme cycle.if machine starts ,programme knob is the problem.
Mar 21, 2008 | Washing Machines
Spin
Electrical module fault
The “Spin Speed” indicator and the “Start
Delay”
option are flashing and an audible tone
sounds. The display shows “F4” to “F16”.
Switch off the appliance. Select a programme
and press the “Start/Pause” button once
again.
The programme will continue.
If the fault re-occurs, contact After Sales
Service (see “After-Sales Service”).
the user man can be found here
http://www.whirlpool.co.uk/app.cnt/whr/en_GB/pageid/pgsrvifuhome001
Jan 15, 2008 | Whirlpool AWM8163 Front Load Washer
Washer stuck on Final Spin
Sounds like a bad timer to test this you need a multimeter to check voltage to the advance motor if so equipped.
Oct 09, 2007 | GE WBSE3120B Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
