Question about Refrigerators
Need admiral designer series HMG21177 freezer wire shelfs and or basket
3 Suggested Answers
SOURCE: need top shelf for admiral refrigerator
Click on this link to see if they have what you were looking for.
http://www.repairclinic.com/Appliance-Parts?s=t-HMG211380-%3d%3dc270
Your refrigerator stopped being built more than 6 years ago, so some items are no longer available.
Posted on May 02, 2009
Sebin
  • 712 Answers
SOURCE: my admiral designer series model#HMG621860 is
Every freezer have a drip collector beneath it. Some times it may be filled completely with water thus causing an overflow. Else, the opening to the collector is being blocked by some ice. Also this problem can happen with aging of the fridge. There is nothing you can do in particular in this case.
Posted on Apr 21, 2010
I have the admiral designer series HMG21149 refrigerator and I need the glass that goes on the bottom shelf over the veggie and fruit trays.
go to the service dealer spares for one
if it is no longer available go to appliance repair shops and ask if there is one from a fridge unit going to the dump
Jun 22, 2016 | Admiral Refrigerators
I have a" Admiral designer series model HMG24922" Refrigerator, And the freezer keeps leaking out water can anyone tell me how to fix it!??
if it is a self defrosting unit then check the operating times of the defroster
if the water is leaking out of the door then replace the door seal
check for a blocked outlet tube for the freezer section
Apr 08, 2015 | Admiral Refrigerators
GE side by side # PSCS 5RGX CFSS freezer shelf fall out
I also have this problem with the same GE Profile series. The shelf sits above the "quick freeze" drawer. It's very annoying and I am looking for a way to fix it.
May 09, 2010 | General Electric Profile PSCS5RGXSS...
My admiral designer series model#HMG621860 is leaking water onto the floor from the freezer compartment where is the drain located on this model, I took everything out of the freezer one week ago and could...
Apr 20, 2010 | Admiral 26 cu. ft. Side-By-Side...
My admiral designer series stove is showing a F 1
f-1 usuqally meens a stuck key pad.sometimes if you unplug it for a wile it may reset other than that you need to replace the clock/touchpad.
Mar 08, 2010 | Maytag Admiral LER3330AAW / LER3330AAZ /...
Need top shelf for admiral refrigerator
May 02, 2009 | Refrigerators
Admiral Designer Series
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1737&PPStack=1
Nov 21, 2008 | Dryers
Admiral HMG 62163 water leaking internally & freezing in lower basket
good attempt, its actually a clogged drain thats backing up and your drain water is not able to leave refrig so it falls to bottom of freezer floor and eventually out the door. romve the items from the freezer and take the lower back wall off form inside, directly under the evaporator under all that ice there is a drain hole, youll need to clear that hole of iec( pouring boiling water down until you get a free flow of water then you can reassemble uint problem solved
Oct 25, 2008 | Admiral 26 cu. ft. Side-By-Side...
Leak
Is there ice build up under the bottom basket in the freezer??
sounds like the defrost drain is frozen up. especially since your cleaning up once or twice a day. simply defrost the drain and flush the drain line with warm water. you will likely have to remove the freezer cover inside the freezer compartment to do this.
if there is no ice build up under the baskets then its likely there is a leak in the water line for your water dispenser line that runs in the door. if thats teh case you will most likely need a service company to fix it for you..
Dec 19, 2007 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
