Question about VIG Furniture Ingram Round Swivel Top Coffee Table
How to reattached the top - VIG Furniture Ingram Round Swivel Top Coffee Table
  • 5,668 Answers
I can not see the picture,always is poss.
Posted on Jan 24, 2013
How do I reattach the top washer spinning wand on my dishwasher? It was knocked off by an object in the top tray. It is attached to the top of the washer case, above the rack. The washer is a Frigidaire...
Hey friend, that's a great question!
From the information you have provided the wand fell of the top of your Frigidaire dishwasher and you want to reattach it. Normally, the arm screws in. If your arm will not attach properly it could be damaged or the piece it screws into could be damaged. I would check over to make sure there are no cracks or damage done to the arm. Best of luck! -Matt
Feb 14, 2015 | Frigidaire Dishwashers
Tip
OMG! you are the Guru. I have asked just ask online no real help. However, you...
This advice is for a washer that fills and will not shut off, resulting in an overflow. Or, water is leaking from the washer while filling. The symptoms can apply to either a TOP LOADER or FRONT LOADER washer. This may be able to save you from an expensive service call by making these simple visual checks.
Water Does Not Shut Off and Overflows: The water level in a washer is controlled by the Pressure Switch. The switch is usually cylindrical in shape and has an electrical connection and an air hose attached. In many cases, the small air hose comes loose from the Pressure Switch fitting and/or falls off. This air hose is required to detect the air pressure from the wash tub as tub fills. With no air pressure, the switch will not function and the result will be a wash tub that fills continuously to the point of overflowing. The same would be true, if the air hose has any cracks, splits or holes in it.
Water Leaking While Filling: The other end of this hose runs to the air dome fitting on the side of the wash tub. If the lower end of the hose comes off, the water will begin to spill onto the floor under the washer, but the tub will not fill.
What to Look For: Check for the obvious. Make sure the air hose is still attached to the pressure switch and air dome. Then, inspect the entire length of the hose, paying particular attention to areas where chaffing may occur and at the points where the hose connects to the pressure switch and air dome. Vibrations from the washer can cause some wear if the hose is rubbing against anything, and the ends of the hose can stretch over time and not seal properly.
On most top loaders the Pressure Switch is located inside the operator console behind the knob that controls the water level. This knob is commonly referred to as the “Load Level”, “Load Size” or “Water Level”. On front loader washers the pressure switch location is usually located in the back of the washer behind the wash tub, or along the interior cabinet wall adjacent to the wash tub.
How to Correct: If the hose has slipped off, cut about ½” off the end of the hose and reattach to the pressure switch and/or air dome fitting. Take a small zip tie and place it around the hose at the point where it connects to the fitting. DO NOT over tighten as this can damage the air hose fitting. Just make the zip tie snug enough to keep the air hose from sliding off. If the hose has any cracks or holes, you can attempt to seal them by using electrical tape. Replacement tubing can be purchased at any hardware store.
NOTE: This is not an all inclusive fix, as the Pressure Switch can fail in some cases and cause similar symptoms. This is merely a preliminary check for a common occurrence that I have discovered. It can give symptoms of a major problem, resulting in a call for a repairman, only to turn out to be a simple fix that any Do-It-Yourselfer should be able to check and correct themselves. I hope this information is found to be helpful and saves many of you a future service call.
on Nov 16, 2009 | Kenmore 24032\24036 Top Load Washer
Reattach Shift key
If it's the same as mine, there is a little white plastic frame that sits under the mouse... Make sure the frame is attached to the underside of the mouse key, and press into position on the keyboard, pushing down onto the REAR of the button first, until you hear it click, then do the same to the front.
Jul 23, 2010 | HP Pavilion dv6000z Notebook
2 of the 3 dividers in the dryer drum has come off. How do I screw them back in?
You have to disassemble the dryer partially to get the dividers back on.
There are two screws holding the door on, and it is slightly hooked in, take it off.
Take off the two screws on the opposite side.
Remove the front panel, pull out lift off tabs on bottom.
There are two hooks at top corners holding top down, 5/16 bolts I think on each side.
This allows room to reattach dividers when you raise top up, screws that came out should be laying on bottom of dryer. About two in each one, find four screws. Turn drum by hand to align for reattaching the dividers.
Important that you have unplugged and watch out for sharp edges.
Feb 23, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Not enough pressure to top rack
PULL WASH ARM OFF OF THE TOP RACK AND SLAP AGAINST YOUR HAND AND SEE IF FOREIGN MATTER IS LODGED IN ANY OF THE SPRAY JETS. CLEAN AND REATTACH
Jul 22, 2009 | Whirlpool GU1200XTLS Stainless Steel...
Micro wave has come loose from hanger on bottom. Need to know how to reattach microwave to brackets. maytag mmv5100
MOST OF THEM YOU CAN TAKE THE SCREWS LOOSE FROMTHE TOP OF THE CABINET OVER THE STOVE, YOU NEED TO PPL, REMOVE TOP SCREWS HOLD IT AN TILT IT AN THEN PULL IT AWAY FROM THE WALL, MOST WALLL BRACKETS HAVE A HOOK THAT THE MICRO MOUNTS TOO IT 90%OF THE WEIGHT IS BEEN HELD BY THE WALL. GOOD LUCK LEAVE SOME FEEDBACK.!
May 28, 2009 | Maytag MMV5100A Microwave Oven
The screw that holds the handle to the top of the canister came completely loose. How do I get to it to reattach?
Buy a epoxy cement and fill the hole with it, then drill a hole a little smaller than the screw, and finally insert screw.
Apr 15, 2009 | Vacuums
Spring on pickup/loading arm
it should have a hook from the frame of the cd player on top and bottom just attac it and it should work
Dec 22, 2007 | Audio Players & Recorders
VIG Furniture Ingram Round Swivel Top Coffee Table Logo
345 people viewed this question
Top VIG Furniture Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a VIG Furniture Furniture Expert? Answer questions, earn points and help others
