Question about JVC Televison & Video
Manual for auria eq3402
Cant huck up
Pyramid 7band equalizer 200watt amp model#402-vl how to huck up the wires
Did you say "huck" up the wires?
Recommend contacting a local car audio professional or Pyramid customer support directly here:
http://www.pyramidcaraudio.com/ContactUs.aspx
Mar 07, 2012 | Pyramid Car Audio & Video
Auria tv "button locked" message.
Holding Vol and Vol- buttons will lock/unlock the buttons. In my case, this didn't completely fix the problem - I was not able to get to many functions. I suspect it was in some store-demo mode. To completely rest, hold the Menu and Chan- buttons then press the Power button (starting from the tv being off). Pressing other button combos will put the tv into manufacturing mode (with cycling solid colors). Turning the tv off and back on will exit this.
Jun 24, 2011 | Televison & Video
My remote doesn't turn on my tv AURIA EQ5588, do I need a code
I also have an Auria EQ5588, the on screen prompts are the same as my APEX 32" 720p I bought over a year ago so either both are the same company or they share the same software. Both are Chinese Mfg. so who knows??? If your factory remote doesn't work call the phone # on the warranty page. There are universal remote codes listed on P. 6 of the owners manual if you are trying to code a cable or dish remote. There is also a reference to LG codes which are carried by Best Buy, Perhaps they can help you out if nothing else helps. The only glitch I've noticed is switch back to TV before turning off your blue ray player. If I turn off my Sony blue ray player and then go back to TV mode I get no sound, turn off the TV and restart it and it's fixed. Seems to be an issue between the brands. I'm pretty happy with the Auria since I got it for $700. Could have spent a lot more!!!!
Feb 23, 2011 | Televison & Video
Auria eq5588, cannot find code for DTV.
Auria is not even in the menu here so I had to select DirecTV DVR DTV. Someone needs to keep up with the brands. Anyway, the DTV codes for the Auria EQ5588 are: 11423, 10017,11265, 10178, 10856,11178 These are the codes. Mine worked with the first one.
Feb 16, 2011 | Directv Plus DVR DTV Receiver / 100-Hours...
Auria eq2288f 22" lcd tv
What has happened is that one or more of the back light tubes were broken in shipping, AURIA used hard foam packing and the TV could not handle the shock of shipping because of BAD PACKING from AURIA. if you call customer support they will tell you that is a power supply or inverter issue but it's not it's a broken bulb, you know they know about it because they will not tell you one or the other. if you open the Samsung screen (LTA400HM01) you will see that the bottom back light bulb is broken, why AURIA will not address this issue is beyond me. don't waste you time or money on power supply or inverter boards before you look at the back light bulbs.
Jan 19, 2011 | Televison & Video
Televison & Video Logo
77 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
