Question about Refrigerators
KIC 223l fridge - what length time reqd to let gas settle?
How long (minimum time) should my KIC 223l fridge stay off, to allow the gas to re-settle, once it has been moved into my new premises? (Assuming it was transported upright).
    New Friend:
Hi,why didnt my friedge switched off, is the second kic friedge ill use and both of them didnt switched of the first one we change the thermosted and still do the same, it works 100 persent only disnt switch off, when u put it of after a couple off minutes it swich on again, and run day in and day out
Posted on Feb 29, 2016
  • 410 Answers
If it was transported upright you should be able to plug it up right away and allow it to start cooling peyton..
Posted on Jan 28, 2009
Can I transport one of your 2 door Fridge/ freezers laying on its side.
only transport a fridge or freezer on it's side if the upright transport is NOT an option.
any chiller using compressed liquid/gas and placed on it's side should be left for 24 hours to settle before powering at the mains, this will allow the coolant time to sink where it should be and prevent the pump (& chiller) from failing.
Nov 23, 2017 | Refrigerators
I have a kic KTF295 fridge. i just need the amount of gas to charged it in grams. I thank you
The refrigeration engineer who will check your fridge for leaks, ensure no moisture is inside, sufficient lubricant is added and finally regas and seal the system will have literature to refer to for the correct gas quantity.
Sep 13, 2017 | Refrigerators
Kenmore Model No. 253.53322302 side-by-side not cold enough. Incidentally, fridge was unplugged in garage last 2 years until plugged in 2 months ago. Fridge stays at 38 F and Freezer at 27 F, so ice...
Since your fridge/freezer has been in storage the gas has settled, did the fridge/freezer get put on its side at any stage during the move?
This could have caused leakage out the breather pipe, have a look at the condenser at the back of the fridge, down low, you will see two hard pipes coming out of the tank, one leads up into the fridge the other doubles over, is open ended and facing downward, this is the breather and gas can escape from this pipe when the appliance is tilted to far over.
Chances are high that you will need to service this appliance.
its a good idea not to turn on immediately after moving. giving the gas time to settle again before turning on.
It could be the door seals need replacing as they can go hard over time when just sitting and no longer form a good seal on the door.
Feb 07, 2014 | Kenmore Refrigerators
My kic fridge have 2 compartments. Freezer and fridge. only the fridge part dont work help please
The freezer is where the heat is removed from the box and cold air should circulate from the freezer into the refrigerator section. Something must be blocking the vent between the two. There is only one cooling unit; it cools the freezer and is also vented into the fridge for sub-freezing temperatures.
Nov 26, 2013 | Red Line Mens Classic Gmt Black Dial Black...
I have a KIC 223l. I moved into my residence yesterday and its not cooling. The moving took 5 min while it was lying down. I immediately switched it on when i got into my room. Its been on for less th
Hiya, u should leave a fridge and freezer after moving it at least 24 hours before switching it on because the gases need to settle. If it has been switched off perhaps you need to check the plug just in case the wires have loosened. hope i was of some help to you kind regards
Feb 11, 2012 | Refrigerators
Put refrigerator in storage for 8 months, doesnt cool now.
Did you switch it on immediately after returning it to your home? If you did the unit has probably burned out because the oil/gas had not yet settled in the compressor after the fridge had been tilted. After a fridge has been moved, it should be allowed to stand for a minimum of three hours before being switched on again.
Mar 10, 2011 | Refrigerators
I own a KIC Fridge the problem is that the door does not closes the rubber does not grip tightly when closing. I have to sometimes lean on the fridge for 5-10 seconds for it to close and it sometimes does...
Hi did anyone get back to you on this? I have a KIC Fridge and it does the same... take out the top door shelf/rack but then you MUST unscrew the light (cause otherwise your light never goes off and your food doesn't stay cold) cause the top shelf/rack in the door switches off the light... anyway... once the top shelf is out, the door will close better.... not sure how else to fix it though...
Feb 09, 2011 | Smeg FAB32 Bottom Freezer Refrigerator
My KIC KTF255P-Aa Fridge is heating up
It's in defrost cycle, But it's getting to hot. has a limit on it think it's not working.
Sep 22, 2009 | Refrigerators
Fridge KIC 223L- FRIDGE NOT COLD ENOUGH
Gas; which also means that it has a leak that must be repaired and fixed. You cannot  buy refrigiation gas unless you have a license from the EPA.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Refrigerators Logo
850 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
