Question about Exercise & Fitness
E6 error code on vision fitness treadmill - Exercise & Fitness
SOURCE: my life fitness t30 treadmill ''running error''
startup error on life fitness treadmill
Posted on Jan 08, 2010
maxtreadmill
  • 832 Answers
SOURCE: Treadmill (Vision Fitness T8500) turns on, motor doesn't run...
open motor shroud and inspect all connection on the motor control board see if all LED 's are lit except that light up when incline motor is moving up or down. then check the two connector coming from the drive motor to the board sometime over time the two connector will have a cold soldier I would move them to see any excessive movements of the pins then hit start and see if there is any belt movement. Last but not least unplug unit and check the motor brushes if they are less than 3/8 in in length replace them. Call them @ 1-800-335-4348 they under their parent corp. Johnson fitness.
Posted on Mar 01, 2010
maxtreadmill
  • 832 Answers
SOURCE: I turned on my treadmill after a long hiatus :)
E4: Solution 1. Check power to the treadmill, as insufficient voltage to the treadmill can cause this error to reoccur. Check the power socket that the tread is plugged into. Eliminate any extension cords or surge protectors (plug the tread directly into a functional power source). Make sure the circuit is not overloaded. Make sure the circuit is NON-GFI. 2. Calibrate (See engineering mode for specific treadmill). 3. If calibrations do not hold, replace upper console. Note: Usually simultaneous with an E6. E6: Solution 1. Check the elevation plug connection at the lower board. 2. Check ALL large data cable connection at the lower and upper boards. 3. Calibrate (See engineering mode for specific treadmill) 4. Test/change large data cable (use large data cable information provided in the data cable portion of this Guide). 5. Replace elevation motor E7/E9: Solution 1. Certain lower boards have an LED that flashes when the magnet on the roller passes the sensor. Adjust sensor position if LED does not flash. See lower board basic troubleshooting for lower boards with the LED. 2. Unplug RPM sensor at the lower board. Check continuity. Treadmill will operate without sensor but cannot Autocalibrate. Calibrate manually. 3. Replace RPM sensor TREADMILL.TROUBLESHOOTING. AUTO CALIBRATION STEP 1 ENTER ENGINEERING MODE • With the SAFETY KEY in place, hold the “ELEVATION UP” and “SPEED DOWN” buttons for 5 seconds. “DGA3” will appear in the profile window and “EHG1” will appear in the function window. • You are now in ENGINEERING MODE STEP 2 ENTER AUTO CALIBRATIONS • Press the “ELEVATION UP” or “SPEED UP” to “EHG4”. • Press “SELECT”. STEP 3 • Press “START”. The treadmill will calibrate itself. This will take about 3 to 5 minutes. When AUTO is complete, “END” will appear in the window. Wait 10 to 15 seconds and the treadmill will reset itself to “P1”. STEP 4 • Press “START” to test the treadmill
Posted on May 06, 2010
guru_fixya
  • 944 Answers
SOURCE: Vision Fitness T9450 Treadmill error code "E4."
E4 means
- Elevation parameters out of range
- Recalibrate it
If you want to calibrate it see the manual page no 5.
Click here to download the manual
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 25, 2010
vetteman3002
  • 2299 Answers
SOURCE: My Vision Fitness treadmill reads E6 when I turn
This just means that the elevation is out of range. It probably lost its signal when you moved it. The way to fix this is to recalibrate it. You can do an auto recalibration.
Posted on Nov 30, 2010
What does error code R5232 Failed mean on Vision Fitness T9600HRT treadmill
If you wish to get some details about treadmill error codes ; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Dec 04, 2016 | Vision Fitness Exercise & Fitness
How to fix error E9 on vision fitness T 9200 treadmill
If you wish to get some details; check the site linked here. Pull up older posts treadmill . Surf the site with patience.
Jan 10, 2016 | Vision Fitness T9200 Treadmill
E6 error message
It appears that your elevation system is where the fault lies. This could be as simple as recalibrating the lift mechanism, or possibly correcting faulty wiring from the lower controller to the lift motor. Be sure to check the condition of the lift motor as well as the wires entering the lift motor. Sometimes the wires will pull away from the plastic connector causing a lift motor error
Mar 11, 2014 | Dmm Vision Fitness T9500 Treadmill
E6 error code on lifespan tr200 treadmill
please proceed according and fix it. God bless you
trouble +cause+ solution
E6 Faulty Safety key Check Safety key or switch
Elv. Motor not moving Check Elv. Motor
connections
Elv. Motor screw binding Clean screw, lubricate or
remove obstruction
Elv. Motor out of range Check motor zero position
Elv. Potentiometer Calibrate elevat ion motor
Jan 20, 2013 | LifeSpan Fitness TR200 FoldNStor Compact...
Using treadmill stopped and display shows E6 I can not start it again
E6 is error code. You need to go to Vision Fitness website to request the answer to your question. It probably has something to do with the timer circuit.
Dec 26, 2012 | Computers & Internet
VISUAL FITNESS t97005 e6 ERROR CODE
LUBE THE deck belt, this happen because lack of maintenance, do ti
2( lube the rollers bearing too
3( test the input voltage motor, if there are the motor need repair
4) test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Sep 24, 2012 | Dmm Vision Fitness T9500 Treadmill
ERROR CODE E9 VISION FITNESS TREADMILL T9200
If you wish to get some details; check the site linked here. Pull up older posts treadmill . http://electro-medical.blogspot.com/ Surf the site with patience.
May 08, 2012 | Vision Fitness T9200 Premier Treadmill
Hi i have a vision fitness 9450 hrt and i'm getting an error message: E6
Typically an E6 error message indicates that the machine needs to be recalibrated because the elevation motor is out of range or that you have a loose cable connection. Below are the auto calibration instructions. Please make sure that no one is on the machine because it will speed up quickly.
With the safety key in place, hold "ELEVATION UP" and "SPEED
DOWN" buttons for 5 seconds. Software version will appear in display
window for a few seconds before model displays.
Press "STOP" , "ENG1" will appear in display window.
STEP 2 AUTO-CALIBRATE
Press "ELEVATION UP" until "ENG4" is displayed.
Press "SELECT" , display will read "AUTO".
Press "START". Unit will calibrate, when finished "END" appears in
display window, then "ENG1".
STEP 3 EXIT ENGINEERING
Press and hold "STOP" to exit engineering mode
I would also suggest that, with the power to the machine off, you check all of the wire connections underneath the motor cover, the assembly connection that sits where the mast meets the console and underneath the faceplate. Check to be sure that all of the connections are secure and that the pins within the cables are seated properly.
If you are still having any problems you can reach a knowledgeable Vision Fitness Representative toll free at 800-335-4348.
Mar 29, 2011 | Dmm Vision Fitness T9500 Treadmill
Exercise & Fitness Logo
100 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
