Question about Dell Inspiron 1300 Notebook
Dell inspiron 1300 wont work from the AC adapter
The laptop wont charge or recognize that the adapter is connected to it. The mains adapter is working
  • Anonymous Feb 03, 2009
    bought new charger and its burning out the charger and battery using a 14.8v battery and a 19v charger.
I'm pretty sure that the power pin on the motherboard is bad. I'm not sure if you can get one and solder it on, but my guess is you need to replace the motherboard.
Posted on Feb 11, 2009
  • 95 Answers
Is the laptop working without the battery, directly on AC. Have you tried using another charger or battery to see if its charging.
Posted on Jan 28, 2009
Dell Inspiron 1300 Of front left four lights, the third is flashing red
I believe that is the battery light indicator saying that the battery is depleted. If you've attempted to recharge the laptop, I'd put my money on a bad AC Adapter. Try a different AC Adapter. Dell laptops are very picky, so I'd recommend acquiring a Dell-brand adapter to ensure it will charge your battery.
Mar 25, 2011 | Dell Inspiron 1300 Notebook
My Dell Inspiron 1525 is now around 4 years old and recently it has not been able to charge and only works when it is plugged in. Also when i start the laptop, it displays a message saying i need to...
As you say the system is 4 years old update the bios
your download link is here!
IMP. Be sure to plug in the battery and it should be charges above 10 % and the system should be connected to the mains power supply also ensure there will not be a power outage during the update process
this will resolve the issue 100 %
Dont forget to say thanks!
Aug 11, 2010 | Dell Inspiron 1525 Notebook
I just bought a replacement 9 cell battery and a 90 watt power adapter for my Dell E1505. With the new battery and power adapter my battery indicator light keeps flashing green and the battery doesn't...
If a new DELL ac adapter (3rd party Adapters are not recognized and the charging circuit is disabled) and a new battery doesn't resolve then the charging circuit on the motherboard is bad
Dec 29, 2009 | Dell Inspiron E1505 Notebook
AC adapter not recognised
Try charging the battery on one of the other dell's.
If the unit runs for any lengh of time, it is not the motherboard.
It could be the A/C adaptor jack on the side of the unit.
Log a complaint will dell's customer care.
Sep 28, 2009 | Dell Inspiron 6400 Notebook
I had the battery not recognized on boot up. then
the Dell AC adapter has a sensing pin so the bios can determine the wattage of the adapter. If the system cannot ID the adapter, the battery charger circuit is disabled. You'll need a functional DELL ac adapter to get the battery to charge
Sep 26, 2009 | Dell Inspiron 1501 Notebook
Dell inspiron 1300 does not see the battery
remove battery check if laptop works fine with ac adapter, if not then download the latest bios version first if fails then replace ac adapter. If laptop works fine with ac adapter. but cannot work with battery alone, download the latest bios then charge the battery for 6 hrs. if still batt not charging then replace batt. but as you mentioned you already replaced the batt and your still getting the same issue. replace motherboard.
Sep 24, 2009 | Dell Inspiron 1300 Notebook
Laptop not turning on
If you replace the main battery and it will not charge, make sure the AC adapter is working (You can test the output with a multimeter) and make sure the LED on the Adapter stays on when connected to the system. Most likely, the motherboard has failed and will need replacement
Sep 14, 2009 | Dell Inspiron 1501 Notebook
Inspiron 1300 battery
If you have replaced the battery with a NEW one and it doesn't charge, then you either have an issue with the AC adapter (If the sensing pin is bent or broken in the barrel of the connector, the battery will not charge) or the charger curcuit of the motherboard. If the issue occurs on a different AC adapter, then FLash the BIOS to current version. If battery still doesn't charge, then replace the motherboard
Jun 24, 2009 | Dell Inspiron 1300 Notebook
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
Dell inspiron 1501 work fine turn off last night now wont turn on
You mentioned trying a different battery, try a different AC adapter.
When plugging in the ac adapter to the wall, see if the POWER LED comes on on the adapter, then when you connect it to the computer, see if the LED stays on.
If the issue occurs with both AC adapters (No battery installed) then the motherboard has failed. If one ac adapter works but the other doesn't then the adapter is bad
Feb 01, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1300 Notebook Logo
168 people viewed this question
Alun Cox
