Question about Canon IXUS Cameras
Canon digital camera no power - IXUS Canon Cameras
  • Canon Master
  • 27,725 Answers
Power issues are common in anything electronic, including digital cameras.
A digital camera can fail to power up for a number of reasons, but fortunately, they're often related to the batteries, making them minor in nature.
If your digital camera won't turn on, check several things to diagnose the problem.
Battery Life
It is common to try to turn on your digital camera, only to see that it will not power up. A highly likely cause of this issue is the power in the battery or batteries. If you've used the batteries for an extended period of time, mistakenly left the camera on or are using old batteries, they may simply be dead. Remove the batteries from your digital camera and test them in another electronic device, such as a remote control. If the second device won't turn on, the batteries may need to be replaced or recharged. b> Battery Position b> Though it sounds like a mistake that is too simple to make, it's easy to insert the batteries incorrectly into a digital camera, especially if it's new and you're unfamiliar with it. When the batteries are put in backward, the digital camera will not power up, leading you to assume there may be a graver problem. If the camera will not turn on, open the battery compartment and verify that they're in correctly. If not, rotate them appropriately, close the cover and try to power up the camera. b> Lens Track Problem b> Depending on the camera bag you use, the camera may occasionally and accidentally get turned on while it's in the bag. When this happens, the lens may begin to extend outward from the camera, but get blocked by the camera bag. All this can happen completely unbeknownst to you, which can lead to the camera not turning on the next time you need it. In some cases, the lens can get knocked off its track, which can result in your camera's power light illuminating once the camera is turned on, but the lens not emerging from the camera body. In more severe cases, the lens' repeated attempts to emerge while stuck in your camera bag can burn out the small motor that operates the lens. When this is the case, take your camera to a repair shop and have a technician look at, and fix, the problem. b> Defective b> Although not likely, there's always a chance that when you buy a new digital camera and load it with fresh batteries, it won't turn on. If this is the case, the camera may be defective in some way. Because new cameras are covered under warranty at many shops, take the camera back to the shop and explain the issue to a technician. Hope it helps.
Posted on Jan 24, 2013
CAMERA WILL NOT SWITCH ON. THE POWER BUTTON SEEMS STUCK AT BOTTOM, WITH OR WITHOUT CHARGE
The Canon G9 has a design defect, two screws fall out inside the camera and short out the fuse. If you've never had it fixed for no power before this is most likely what has happened to your camera.
Do a Google search for "canon g9 no power repair" and you will see a full repair service including return shipping of your camera for just $85.
Thomas
Owner, Darntoothysam.com Digital Camera Repair
Apr 24, 2011 | Canon PowerShot G9 Digital Camera
Canon S1 IS. camera power turns on but cannot see
your main power supply capacitor has failed;
send the camera in for repair
Jul 01, 2009 | Canon PowerShot S1 IS Digital Camera
I cannot download my pictures from my canon power
if you dont have the driver disk that came with the camera, check out the canon web site to get the drivers for your camera. you can download them usually for free.
Apr 20, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
NO POWER in my digital camera
Could be your power circuit. You may contact Canon direct in Jamesburg, NJ or take it to an AUTHORIZED service center for faster service. I know of one in Flordia 305-653-7355
Apr 20, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Fit my Canon NB-4L Battery
Canon nb-4l battery pack canon 100 percent compatible with you canon nb-4l camera battery. I bought two canon nb-4l battery from http://www.camera-battery.co.uk/canon/nb-4l.htm two weeks ago, I felt very surprised, because it fits nearly as good as the original battery.
Feb 06, 2009 | Canon Cameras
My Canon sd 1000 won't power on. Battery is OK.
Check to make sure the batteries you are using have enough strength and volt power, if not it wont work. If they are really cheap, and last only a weak in the remote, they wont power up a camera.
Jan 21, 2009 | Canon PowerShot S1 IS Digital Camera
Cameras Logo
32 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
