Question about Fellowes Powershred P-55C Shredder
Fellowes p-55 only reverse works - Fellowes Powershred P-55C Shredder
Yellow light comes on
Look at the manual in the link below. If you do not find the answer, call Fellowes.
Fellowes Shredder Manuals
Sep 18, 2014 | Fellowes FEL-3011001 DS-1 Light-Duty...
Fellowes HD-10Cs won't shred. Power gets to machine because it will manually reverse when reverse button held. Can't get the sensor lights to work. Tried overide switch for sensor light. Held in...
Unplug from mains electricity.
use a cotton bud dipped in rubbing alcohol to clean the sensor
light(s) and heads
Give a quick spray to cutters with WD40 Replace - turn on - and run in reverse.
If all else fails, contact the maker
Jan 31, 2014 | Fellowes HD-10Cs Shredder
Fellowes P35C works in reverse but not forwards
In forward operation, a detector senses the presence of material in the feeder and turns it on. Reverse operation is selected by switch position; no sensor is involved. I would bet that if you remove power and turn the shredder upside down you will find bits of shredded paper clogging your shredder, particularly in the center area where the detector is located. After thorough removal of debris, you should be back to normal operation
Feb 03, 2013 | Fellowes P35C Black Cross Cut Shredder...
When plugged in and turned on, both the red and green light come on and it does not work forward or in reverse
I own a Fellowes PS 60 shredder.
Here is a link to the manual for a Fellowes PS60 Shredder.
Maybe it will help you in resolving some of your problems.
https://app.box.com/s/q3r8jlatlfskvgyh5ne6
Fellowes Shredder PS60
Mar 27, 2011 | Fellowes Powershred PS-60 Shredder
My fellows jbo1 jamed and then stopped running is there a reset buton?
Chances are it's over heated.
Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds. Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled. See oiling instructions below.
From fellow's website: http://www.fellowes.com/fellowes/site/support/support_troubleshooting.aspx#jammed
Dec 15, 2010 | Fellowes Office Equipment & Supplies
I need a main forward and reverse switch for a fellowes ds1 shredder.is that possible?
Have you tried calling Fellows? This link is to your operating instructions, which has phone numbers listed for different countries.
http://www.fellowes.com/Fellowes/Materials/Documents/ds1_2005manual.pdf
This link is for listing your model and serial number to inquired about what parts are available.
http://www.fellowes.com/Fellowes/site/support/support_faq.aspx
Dec 03, 2009 | Fellowes DM8C Cross-Cut Shredder
Reverse shred does not work
either the switch is unplugged or defective, or the main board needs replacing. Also, they come with a 2 year warranty. try calling 1-800-955-0959 for fellows end-user support and have serial # ready (ser.# is found when you open the door).
Oct 29, 2009 | Fellowes C-420C Shredder
Fellowes powershred 320
seems to be an issue with the paper feed sensors i suggest you call Fellowes customer service. 1-800-945-4545
Mar 09, 2008 | Fellowes Powershred 420 Shredder
Fellowes Powershred P-55C Shredder Logo
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
