Whirlpool Duet "wfw9200SQ00" error F30
My machine stopped dispensing water with an F30 error message. I have cleaned out the dispenser area with some vinegar due to our extreme hard water, and it worked for another three months, until the same error message occured this evening. When I turn the machine on, it locks the door, I hear the dispenser release the detergent, then when the water is supposed to run into the drum, it just clicks and there isn't any water going into the drum.
  • Washing Mach... Master
  • 17,129 Answers
Possible that there is clogging in the inlet filter or valve, remove the hose to the inlet and check the flow,
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Posted on Jan 24, 2013
jsrock516
  • 5911 Answers
SOURCE: Water pouring out from the detergent dispenser
Remove the washer top panel by removing the three screws in the back of the washer that hold the panel in place. With the three screws removed, the panel will slide back, then lift off. This will give you a full view of your dispenser and components. I strongly suspect that you have a hose leading from the dispenser to the fill tube along the door that may be either kinked or clogged. Inspect the hose for any kinks. You may have to remove it and flush with hot water. Let me know what you find. I hope this helps.
Posted on Sep 03, 2008
  • 958 Answers
SOURCE: Water overflowing from dispenser, no error codes
check the holes of the dispenser, could be clogged with soap and liquid detergent. check the hose where the dispenser flows to the drum, it could be clogged also. open the door, trace the dispenser hose that is attached to the drum or to the big rubber gasket at the front. check and see if there is dirt accumulation or soap clogging the hole.
tnx 4 using fixya,
drcool
Posted on Oct 14, 2008
  • 9 Answers
SOURCE: Whirlpool Duet GHW9100L pours water out of the soap dispenser dra
probable cause is there is an article of clothing that is stuck between the outer and inner tubs, in the area where the dispenser water and detergent enter the machine. you can run your hand around the rubber boot and you might be able to remove the article, it will be in the upper left part of the machine. if nothing can be found than you have a plugged up dispenser hose.
Posted on Jan 31, 2009
SOURCE: Whirlpool Duet dispenser problem
I had the same problem my fabric softener would not dispense.Close shut-off valves and take off the water hoses off the back of the washer and look for blockage on the screen.Mine was plugged up and after cleaning it off it works like new.
Posted on Apr 03, 2009
  • 51 Answers
SOURCE: Whirlpool Duet Sport Leaks from under detergent dispenser
there is a hose that runs from the soap box to the drum to let the water into the drum if it is not connected or has perrished then that would explain the waterfall
Posted on Jun 12, 2009
My washer is giving me an error message of F30 and it makes humming noise like it wants to come on but it doesn't.
The fault guide says the following about F30:
DISPENSER SYSTEM ERROR
The dispenser motor cannot be driven to its proper position
1. Unplug and disconnect power
2. Check mechanical linkage from dispensor motor to top of dispenser
3. Check wire harness connections to the dispenser motor and central control unit
4. Check dispenser motor for powered rotations
Hope this helps
Jul 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F30 error code...what is this problem?
F30 is a dispenser failure code on the Duet Sport washer.
It means the dispenser motor will not go to the proper position.
Remove the top of the washer and inspect the dispenser linkage to see if it is binding up.
Post back with what you find and we will check from there.
Thanks/Mike
Nov 03, 2007 | Whirlpool Duet GHW9150P Front Load Washer
How to reppair a F30 error code
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
* It could have a mechanical failure in the linkage between the dispenser motor and the top of the dispenser.
* Loose wire connection between the machine control board and the dispenser motor
* Failed dispenser motor
Thanks for using FixYa!!
Nov 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I received an F-30 error code on my whirlpool duet washer? Looked in book but could not find what this stands for?
Hi
Thanks for using FixYa. Error F30 is dispenser system error which occurs when the dispenser motor cannot be driven to its proper position. To resolve this issue you’ll have to:
1. Unplug washer or disconnect power.
2. Check mechanical linkage from dispenser motor to the top of the dispenser.
3. Check wire harness connections to the dispenser motor and Central Control Unit (CCU).
4. Check dispenser motor for powered rotations.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool washer flashed F30. Not filling up with water.
"F30" indicates "DISPENSER SYSTEM ERROR" When the dispenser motor cannot be driven to its proper position this error appears in your washer. To fix this problem follow these procedures.
1. Unplug washer or disconnect power. 2. Check mechanical linkage from dispenser motor to the top of the dispenser. 3. Check wire harness connections to the dispenser motor and Central Control Unit (CCU). 4. Check dispenser motor for powered rotations.
Thank you !!
Jun 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What is an F30 code?
It is Dispenser System Error.When the dispenser motor cannot be
driven to its proper position.Follow these steps.
3. Check wire harness connections to the dispenser motor and Central Control Unit(CCU).
Apr 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code F30
The F30 code refers to a failure of the dispenser motor. The clicking you were hearing was probably the dispenser motor switch going on and off trying to activate the dispenser motor.
Here is the service manual.
https://secured.whirlpool.com/Servic...LE/8178558.pdf
Mar 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F30 error
Dispenser system error,make sure the dispenser is clean
Jan 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error Code of F-30
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F30 error code on whirlpool front load washer ''Duet''
You have a problem with your soap dispenser. This has been a very common problem. You need to order W10161052 Actuator, W10157886 Dispenser, 8183186 Actuator Motor. Put these new parts in and you will be fixed.
Nov 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
