Question about Durabrand DUR7 Portable DVD Player
Durabrand 7 " dvd portable started not reading discs suddenly "no valid disk"
I see others with this problem. Please help, it just started happening suddenly.Very frustrating as we've also done all the cleaning , etc. nothing works. Must be timed to break own ;o)
  • 2 more comments
  • robyn mar Jul 29, 2007
    Hmmmm Its still not working. thanks for the advice. I tried the button down & it still says "no valid disc".
  • robyn mar Aug 11, 2007
    Here is what I got from the Walmart Warranty site & I must say , it worked! I did all the steps and nothing but the part about sliding the lens assembly is what worked. Apparently it was stuck in the top of the dvd player, once I pulled it back to center, no problems.(this was for Durabrand DUR-7)
    good luck!
    Here's the email from them :
    Make sure the unit is in DVD Mode.
    Try cleaning the laser assembly. First, power off your machine. Find the
    laser eye located in the centre compartment. It is perfectly round, and
    made of glass with a bluish tint. To clean, moisten a good Q-Tip in rubbing
    alcohol (just a little), and gently swab just the glass lens, taking care
    not to soak it.
    Also try resetting the unit. Remove the power/batteries and then hit the
    power button 10-15 times and then try again. If you continue to have
    problems unfortunately it sounds as though it is within the electrical
    assembly. It is hard to say exactly what caused it or exactly what the
    problem with the circuits are.
    Try sliding the arm of the laser all the way in until it "clicked".
    If this procedure still did not help you with your problem and you still
    have your sales receipt, simply exchange the unit to place of purchase.
    If the place of purchase can not simply exchange the product you can send your machine to us for service.
    Please make sure that the form is filled out COMPLETELY to avoid any further delays on getting your machine service.
    Send me your .....
    Full Name: ...........(no P.O. Box addresses, as UPS will not take them)
    Full Address...........
    Street:
    City:
    State/Province:
    Zip Code:
    Phone#:
    E-mail Address:
    Brand:
    Model#:
    Date of Purchase/ Do you still have your sales receipt:
    Problem with machine:
    ....and I can send you the address to ship the unit in for repairs. Without
    ALL the info, i cannot issue a RA#. I will also need to know the date of
    purchase of the unit and whether there is a receipt for the purchase.
    Repair Policy
    The warranty is 90 days from date of purchase. Check
    the warranty card for information. Please include a copy of any type proof
    of
    purchase. Be sure to double check that all you information is
    included so I can get you the return authorization number and address
    A.S.A.P.
    The non-warranty cost of repair depends on the model number. You may send
    the machine to us by whatever method you prefer, but you are responsible for
    the cost of sending the unit to us. We recommend that the unit be shipped to
    us insured and that a signature be required when we receive it. Repairs
    generally take 4-6 weeks. Your unit will be returned to you at no charge to
    you via UPS.
    Best Regards,
    Jenny
    Customer Support
    Alco Electronics Inc.
    Email: [email protected]
    www.18002526123.com / www.1800customersupport.com
  • Anonymous Jun 26, 2008
    I had the same problem......with it saying no valid disc. I tried everything walmart said and it did not work, however, the posting saying that you open the lid and hold the little black button on the lower left down and if it plays then all you need to do is glue something on to hold the button down father worked great!!!!!!! I couldn't believe it something so simple! I glued a piece of my kids craft foam on just to push the button down farther I feel like McGuiver...haha.
  • ButlerBuck Jan 24, 2009
    Same message....No valid disc. I cleaned it, did the power reset, and push the button. Now, it works, but I can hear the disc spinning. I don't recall that before. Any thoughts?
I had this exact same problem. I took the bottom cover off and took a look at the gears. It turns out I had a rubberband stuck in the gears and it was not letting them turn correctly so I took it out and it works perfectly now.
Posted on Aug 25, 2008
I had what I think might be the same problem...if it is what ya gotta do is open the door and look on the left side. You will see a little black button, there's a piece on the door that pushes that in when it's closed...it's not....with the door open, push that button down and try playing a dvd, if it works, then you have to find something, try using a clipping from something like a fake nail or a something else that thin that can be super glued on the part on the door that pushes it in... if it still doesn't work then I don't know...I got this suggestion from another question that was posted and one of the solutions was this..low and behold, it worked for one of the problems that I have with my portable...I still can't fix the second problem...Good luck!
Posted on Jul 24, 2007
SOURCE:
Portable durabrand dvd wont read disc
If it is reading a burned movie from the internet make sure you set you brun software for captability mode.
If this is a orginal disk make sure its free of dust and scratches.
1. buy a lens cleaning kit from walmart or any other eletronics store.
2. Make sure the disc is free of scratches.
3. change disc's and see if it works on any others.
if these steps do not help then the laser would need to be replaced. Durabrand is a Wal mart brand i had mine for 2 years and i had to clean the lens 3 times with a cleaning kit.
Thanks
Rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jul 17, 2009 | Durabrand DUR7 Portable DVD Player
Displays "No Disc"
It can be several reasons
1. Disk is upside down
2. Lens is durty. CD/DVD cleaning disk will help
3. Disk is in different formate (for instance NTSC for US but you trying to playback disk in PAL)
4. Disk has different region code (look is the dvd player and disk have the same code, or ALL Regions code)
Good Luck
Dec 26, 2008 | Durabrand DUR7 Portable DVD Player
Pvs1371
I could walk you through a list of tests, but the truth is the unit will need service. The good news is, you can now contact Durabrand and get the tests directly from their website. Please click on the link below:
Durabrand Technical Support, Parts and Accessories
http://1800customersupport.com/
If you require any additional assistance do not hesitate to click on the "ASK ME" button and I will respond to your request as soon sa I can.
Oct 06, 2008 | Durabrand Portable DVD
No Valid Disc
Try cleaning the laser lens if this don't repair it ,is the flat cable connector between the laser lens and the main board.Good luck
Jul 25, 2008 | Durabrand Portable DVD
Durabrand portable dvd player dur-7
Duarbrand portable DVD players are no longer supported by Walmart because the company contracted to manufacture them is no longer in business. Ripoffreport.com has several complaints on the product line. Walmart has been exchanging the item.
Jun 28, 2008 | Durabrand DUR7 Portable DVD Player
Durabrand DUR-7 portable DVD player
Most DVD players that would display such a message even with a known good disc inside signifies that the that the laser eye/lens is not reading the disc. This could probably be attributed to:
1. dirty, damaged, inverted, blank, un-finalized burned CDs or DVDs;
2. defective, weak burned-out laser eye/lens;
3. defective slider shafting (where the laser eye's carriage moves.
A few things you can try:
1. Use a CD cleaner (readily available from most computer shops);
2. use a can of compressed air and blow through the inside of the loaded disc area;
3. gently tap on the top cover where you estimate the reading/laser eye/lens would be;
4. gently press on the tray door once the disc is loaded.
Should this not be corrective, perhaps your best bet would be to seek the services of a qualified professional such as those in a Service Center. Alternately, your friendly neighborhood electronic shop should do just fine.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kindest regards.
Feb 10, 2008 | Durabrand DUR7 Portable DVD Player
DVD player issues
Most likely the dvd is dirty, scratched, or chipped. Try cleaning the dvd disk with a soft cloth (chamois works best). Look at the surface of the disk and if it is scratched lightly, dust and dirt particles, fingerprints, etc will cause refractions from the laser light in the dvd player, which is then read as an error by the dvd player. Cleaning it with a soft cloth will sometimes help.
If that does not work, hold the disk up towards a light source and look for light coming through from the other side. If this happens, the disk is unreadable and unrepairable as the data source has been corrupted.
Dec 17, 2007 | Televison & Video
I put the disc in the player ithen tries to play then it says disc not valid .
Same here!!! We've only used it maybe 8 or 9 times. And it's been worthless for the past month because of it. It reads everything "no valid disk" and nothing will work. And I tried e-mailing customer support several times, with no luck.
Nov 21, 2007 | Durabrand DUR7 Portable DVD Player
No Valid Disc
Try this out; Go to your DVD player's settings/setup menu, find the "Disc Lock", set it to "off" if it is already set to "on"
Apr 16, 2007 | Durabrand PVS1966 Portable DVD Player
Durabrand DUR7 Portable DVD Player Logo
1,905 people viewed this question
Top Durabrand Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
