My HP DV9000 Will not start.
My DV9000 laptop has been starting properly. I would use control- alt- delete once or twice and would boot up. but the other day the screen developed lines. The computer froze up I tried to get out of it but that didn't work. I used the power button to shut it down. when I turned it back on it now won't start at all. I sounds like it is starting but shuts down after about 2 seconds then does it again and again. any ideas? I just hope I can get my pictures at the very least.
    Scholar:
  • 102 Answers
I understood your problem. Here i providing you perfect solution for this problem.
there is may problem with your screen driver cord(cable)
if you have sufficient knowledge about this then open your laptop's back cover.
> after that you will find small screws, remove them carefully.
>then you able to open the keyboard section
>Now at the area of Power Button and support of Screen there is pair of wires.
>Find tiny socket of that pair.
then remove it,clean it with alcohol then reconnect it.
If problem occur due to some Software malfunctioning the you have to format your laptop.
thanks for giving such opportunity to solve your problem. have a nice day.
Posted on Jan 24, 2013
  • 2427 Answers
SOURCE: Screen stays black after laptop comes back up from hibernation
Its software,, format and reinstall windows
Posted on Dec 31, 2007
  • 85 Answers
SOURCE: Laptop keeps losing power at start up and shuts down repeatedly
does it run with the power cord plugged in? if so your batterys dead, otherwise harddrive/bios/motherboard fault? is your power supply charging the battery?
Posted on May 09, 2009
  • 54 Answers
SOURCE: HP Pavilion dv9000 laptop computer will not stay
Restart the notebook, press F10 and check if you see the BIOS screen or not.
If you see the BIOS screen and if the notebook does not restart in BIOS then this could not be a hardware issue.
But if you do not see the BIOS screen, then perform the steps below :
1. Disconnect the ac adapter and remove the battery from the notebook.
2. press and hold the power button for 30 seconds
3. replace the battery and connect the ac adapter
4. turn On the notebook and check
If the issue persists then remove and replace the memory modules of the notebook and check it.
If the issue still persists then it could be a hardware issue and your notebook needs to be serviced.
Posted on Jun 13, 2010
  • 1705 Answers
SOURCE: insert smart card into reader problem
I think its looking for a boot command from the card reader. Which means pressing the DEL or F10 or F2 key repeatedly while booting to get into your bios to change your boot order.
If it wont let you, try booting while pressing the F8 key, with luck it may bring up windows boot options, choose the safe mode. When up, Click on Start - all programmes - accessories - system tools - system restore - choose a date prior to problems. (This is for XP, Vista and Win7 slightly different)
Boot from your windows disk, and choose the repair option.
Or download, UBCD4Win , the ultimate boot cd for windows, This will load a windows shell system with loads of diagnotic and repair tools.
You could download and run Ubuntu without installing, that will give you access to any data files.
If none of this works, the only recourse is to re-install windows. But in
doing this, you will be re-formatting the hard drive which will remove all data on the drive.
If you don't have a copy of windows, you do have Ubuntu. I use it nearly all the time now, even though I have a dual boot system.
Posted on Jul 21, 2010
  • 73 Answers
SOURCE: Hi, My Samsung R580 I3 JBB2-US
You can try go to Start - Control Panel - Power Options and check what you want computer do when you close the lid of your laptop. Fix that and restart laptop to apply the setting.
If the boot up not complete and restart by itself, in my opinon, there is something wrong on the start up process, could be hardware malfuctions, could be a software not compatible. Try check the start up process to see.(use Start- Run: msconfig)
If this happen often, you should call the Samsung customer services to find out. Laptop i3 should still under warranty.
Hope this will help.
Thanks for reading
Posted on Jul 20, 2011
Boot error - requires control alt delete to recover
Bootconfig might be bad for windows not to start. Or could be a hard drive problem. Windows startup repair might work or you might have to reinstall the operating system. If this does not work then possible the hard drive has problems.
Nov 26, 2012 | Computers & Internet
I have a pc HP Pavilion dv9000 what key do i use to play on t.v
Connect your Notebook with the TV and use Fn+F4 key combination to switch the signal output to TV.
Dec 19, 2011 | HP Computers & Internet
Forgot password my password
on the start screen of the computer press ctrl+alt+delete twice then in the password box that appears type administrator in the username and hit enter then once ur in the admin account hit start then control panel then users then ur account then change password u will only lose ur msn or saved passwords for sites that u have
Jul 23, 2011 | Computers & Internet
I forgot my account password on my laptop. What should I do?
when you start up the computer press ctrl+alt+delete twice then in the password box that appears type administrator in the username and hit enter then once your in the admin account hit start then control panel then users then your account then change password.
Jul 04, 2011 | Computers & Internet
HP Pavillion DV9000 will not start. Before, I would press the power button and the lights would flash, once, then turn off immediately. Less than a second. By resetting the motherboard, I was able to...
Hi
Try to remove the battery, hold on power button for about 50-60seconds, then plug-in the charger and turn the laptop ON, see what happens.
Please tell us your results
Good Luck
May 15, 2011 | HP Pavilion dv9000z Notebook
I get a bootmgr compressed error when i start my acer netbook its telsl me to hit control alt delete but this only repeats over and over how can i uncompress the bootmgr file so the netbook boots up
Boot Manager is the file controlling the boot security process and is corrupt.
Try and start in safe mode and run CHKDSK/F
If you can't get it to work, use your recovery disc and recover your system.
Feb 05, 2011 | HP Mini 1000 Netbook
Wont boot up error msg: BOOTMGR is compressed. Press control Alt Delete.
...to reboot your computer. I am really sorry, but that means that your windows wont start because root folder is corrupted/damaged. On HP machines usually f10 is restore button. If not that one try f8.Reboot your computer and start tapping f10 till you see restore options. Then have your choice.Good luck!
Nov 16, 2010 | HP Mini 1000 Netbook
Need password
ok best thing to do is to start the computer up in safe mode
when you boot up computer it will say press a key to go to "boot menu"
press that key
then select boot up in safe mode
then log on as admin and delete the password
if that dosnt work then you will need to download and butn this to dvd
http://www.hiren.info/pages/bootcd
make sure yu do not choose the ods version and you choose the gui if there are two versions
the gui has a graphical usser interface the dos is just like comand prompt
then go into bios set to boot from cd then choose the password tools and use it to delete it
good luck
Sep 21, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
Hp dv9000 freezes up halfway through a video
If this has been a problem since you bought it, you should add more memory and or use a different movie program
Dec 22, 2008 | HP Pavilion dv9000z Notebook
Wrong bios
The # 443694-001 refers to the cd set. You need to know which DV9000 you have. On this link you will see all the DV9000 models.:
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-002&h_query=DV9000+443694-001&submit.x=6&submit.y=4
You will need to use a friend's computer for the following.
Once you find the correct firmware, You can make a bootable CD by using Nero or Roxio burning software,these are the most common on computers nowaday.Once you make the bootable CD, you will have to set your laptop to boot from the CDROM. Then boot the CD you made and run the firmware update.
I don't believe you would be able to get a USB flash drive to boot in this condition.
Good Luck
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 12, 2008 | HP Pavilion dv9000z Notebook
Computers & Internet Logo
David Payne
David Payne
