Question about Fujitsu Siemens SCENIC P300 PC Desktop
Display Problem with Scenic P300 i845GV
Fixing a friend's PC. Plugged in a new monitor (HP w1907v) to a Scenic P300 i845GV and although the resolution was initially good, I was called back a few weeks later when the resolution deteriorated (reason unknown) and dropped to the lowest resolution (4 colours). I couldn't improve this via the Control Panel in Windows XP Pro (it didn't give me the option), even though Windows was offering to do this automatically.
Therefore I used the monitor install disk (though I haven't needed this in the past with this screen). Again, this didn't help, so I uninstalled the monitor but in doing so, it seems the generic plug and play display driver was removed as well. When I plug in any monitor now, you see the Windows XP progress bar on bootup, but the screen goes blank when Windows has started (you can hear the XP startup chimes). I have tested this on 2 screens. Presumably I need to re-install the graphics/display driver - does anybody know what this is, or how I can do that with no display once XP has booted? I don't have the XP Recovery disc.
Does anyone have any idea how to resolve this, please?
Many thanks,
Andy
  • 1 more comment
  • andrew_horsm Jan 28, 2009
    I should add that I have tried booting to Last Known Config - same blank screen issue. Also tried Safe Mode - hangs on System32\Drivers\Mup.sys
    Thanks,
    Andy
    Thanks harrel. Any ideas how I do that if I don't have the XP Recovery disc? I can't find any hard drive recovery partition.
    Cheers,
    Andy
  • andrew_horsm Jan 31, 2009
    Just to update this issue, I've tried setting display to VGA in BIOS which still doesn't work. I'm therefore assuming it's a hardware issue - maybe a dead graphics card.
    Thanks for your help,
    Andy
  • 107 Answers
It seems that you have a corrputed operating system. try 2 repair it by using the operating system installer and do a repair just follow the steps.
Posted on Jan 28, 2009
I cant find the vga Drivers for my machine. Fujitsu siemens scenic p300
Hello there should be a serial number on your product and enter it on the link below http://ts.fujitsu.com/support/downloads.html
If that don't work you can always try windows update.
or ill post a few links i have fount for you.
http://get-driver-go.com/fujitsu-siemens-scenic-p300-drivers
the best one is the one below it has all of the drivers
http://www.drivershq.com/drivers/fujitsu-siemens/Scenic/SCENIC-P300-(SiS661)/24971/46137/48781/Drivers.aspx
hope this helps.
Jul 13, 2011 | Fujitsu Siemens SCENIC P300 PC Desktop
The system boots normally but does not display on the monitor, what is the way forward
If it boots normally and there is no display on the monitor,it could be
1.Your Display card could have failed or the VGA cable from the display adapter is not connected properly to your monitor- In this case you will see a "no signal" message on your monitor.
2.If the monitor is powered on nothing appears,then your monitor most likely failed.
3.If the monitor's power on led light is not lit,then make sure your monitor is plugged in properly to the power source.
Oct 27, 2010 | Fujitsu Siemens SCENIC P300 PC Desktop
Fujitsu siemens scenic p300 vga drivers
Hi.
There are different P300 versions.
Click on the link below:
Fujitsu Siemens Download page. ( http://ts.fujitsu.com/support/downloads.html )
In the page put scenic p300, or put the serial, or put scenic p300 in model description.
In the following boxes select:
Personal Computer
Former Models
P series
P300
Select model in last box
In the next step you will be asked to select Windows operative system.
Select OS, then find the driver to download.
Oct 04, 2010 | Fujitsu Siemens SCENIC P300 PC Desktop
Scenic P300 VGA AND SOUND DRIVERS
you need to find out what graphics card you have. go to control panel click display,settings tab, then advanced box.one of the tabs will tell you what your graphics card is.will give you link for sound driver, look bottom right and click view more.you will also see nvidia vga drivers also will give you another link which you can search for vga.FileHippo.com - Download Free Software . Where to DOWNLOAD DRIVERS - Driver-Downloads.com .
hope this helps
Aug 17, 2010 | Fujitsu Siemens SCENIC P300 PC Desktop
Fujitsu seimens scenic p300 no chipset drivers where can i get them from
Specification Processor:
Celeron
Intel P4
up to 2GHz
up to 2.66GHz
up to 2GHz
up to 2.66GHz
up to 2.4GHz
up to 3.0GHz
up to 2.6GHz
up to 3.2GHz Motherboard: D1451 D1521 D1561 D1761 Chipset i845GV i845GE i865G SiS661FX Video: On-board On-board + AGP slot On-board + AGP slot On-board + AGP Slot Max Memory 1GB DDR333* 2GB DDR333 2GB DDR** 2GB DDR Memory slots 2 2 4 2 Audio STAC9750 AD198x AD198x Realtek ALC655 On Board Lan AN983B 82562ET 82562EZ AN983N Hard Disk: Depends on choice at time of purchase - 20/40GB (5400rpm), 20/40/80GB (7200rpm silent). CD/DVD Drive: Depends on choice at time of purchase - Cdrom ,DVD or CDRW * 2GB (DDR333) with future memory modules
** 4GB (DDR333/400) with future memory modules
http://uk.ts.fujitsu.com/rl/servicesupport/techsupport/professionalpc/Scenic/ScenicP/scenicP.htm
You know, if you can decipher your motherboard, You'll be able to find the intel chipset and do a download. Make sure you save/rename your old.
Apr 18, 2010 | Fujitsu Siemens SCENIC P300 PC Desktop
Desktop monitor shows lines when i put it on. These line prevent me from seeing the display well. What do i do?
This is normally an indication that this specific monitor cannot synchronize properly: the cause is the requested resolution is too high or the frequency specified is too high. In windows, specify a lower display resolution for your display adapter such as 800 X 600 and gradually change it to a higher resolution until the dsiplay becomes unacceptable to use. Hope it helps! Let me know how you go.
Dec 31, 2009 | Fujitsu Siemens SCENIC P300 PC Desktop
Vgadriver name of my pc fujitsu siemens scenic p300 i845gv
Go to this website: http://www.testmyhardware.com/
download the freeware, it will tell you all the hardware in your pc, then go to the hardware manufacturers website thru Google.
Mar 14, 2009 | Fujitsu Siemens SCENIC P300 PC Desktop
Lost video driver for Scenic P300 i845GV
there are many options open to you.
Boot into safe mode and see if you get a good result. Then if you can, connect to internet and get the new drivers for the video card or built in video.
try this first and we can go from there.
Thanks!
let me know asap.
Jan 28, 2009 | Fujitsu Siemens SCENIC P300 PC Desktop
SigmaTel STAC 97
Disconnect the hardware device until prompted, reboot. Need more info. Or goto MS support site and download, then install driver.
May 16, 2008 | Fujitsu Siemens SCENIC P300 PC Desktop
Fujitsu Siemens SCENIC P300 PC Desktop Logo
401 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
