Question about Panasonic Televison & Video
Panasonic remote N2QAJB000050
Some of the buttons fail to function, others are OK
2 Suggested Answers
  • 6 Answers
SOURCE: remote ok but no respondindg on tv, pannel buttons not function.
then best idea is buy new tv
Posted on Oct 09, 2009
Panasonic tv model tc-p42c2 remote is inop
It is a common thing that all the buttons of a universal remote control might not work, as it meant to be. Try an other code. If this too won't help you, there is no other way than buy a new original remote control for your Panasonic TV. You can buy in from the authorized service center for Panasonic at your town. Just give them the exact model number to your TV. They will provide you the original one.
Jul 20, 2012 | Panasonic TCP42C2 42 in TV
My panasonic dvd recorder / remote control is not working On pressing button on remote I get dvd2 on recorder screen but no other response. I have tried reset without effect
Try reprogramming the remote itself; i.e. point remote at unit (while on), press and hold the [2] and [ENTER/OK] buttons together for 5 - 10 seconds, then release. The remote's command should now match that of the unit (DVD 2) (the unit should now recognise the remote). Failing that, remove batteries from remote, replace with new ones (just in case) and repeat the above suggestion. You should not need to reset the main unit.
Whenever the batteries are replaced in Panasonic remotes, in some cases, a remote command reprogram is often required to ensure that the remote commands the unit fully and correctly. You may find this procedure outlined in your instruction manual. Hope this helps a tad.
Aug 14, 2011 | Televison & Video
Panasonic dvd s75,when remote is pressed the panel shows up as" remote dv2" why?
Because the command mode of the remote control is different to the unit - hence the DVD 2 (or similar) indicator on the front panel display. Try changing the command mode of the remote itself, by pressing and holding ENTER/OK and the number 2 button together for 5 - 10 seconds, then release.
You should hopefully now have full remote function which matches your unit. Failing that, reset the unit to factory defaults as outlined in the user instruction manual (if you still have it, and this can usually be done without the remote).
This may or may not help.
May 05, 2011 | Panasonic Televison & Video
When I try to use the remote, the only reaction I get with my Panasonic DMP BD35 player is the message, "Set 1", this is regardless of what button I depress on the remote. No other action occurs....
Hi, I hope you solved your problem before throwing out your controller.
Just press the "OK" button with the "1" button and hold them a few seconds. Your BD player will say "Hello" and you're done!
If you have something like "set 2" or "set 3" error, just do the same thing with that number.
I hope it works!
Nov 26, 2010 | Panasonic N2qayb000184 Remote Control
We have a Panasonic DMR-EH50 DVD player/recorder. We recently moved house and following the move, the FUNCTIONS button on the remote no longer works. Everything else on the remote does. I've tried...
The message displayed means that the remote control and unit are not communicating and the remote needs to be programmed. To program the remote, press and hold the same number that is displaying on the unit and the [ENTER] or [OK] button for more than 2 seconds. For example, if the unit displays “SET 2”, press and hold [2] and [ENTER] or [OK] for more than 2 seconds.
Apr 04, 2010 | Panasonic DMR-EH50 DVD Recorder
Shows unformat when DVD+RW inserted
Disc need formating. While disc is in the unit press Function on the remote then arrow down to Other Function then OK button then select DVD Management then select Format disc.
Sep 21, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Setting humax foxsat hdr remote to control panasonic tx32lxd60 tv
Had the same problem with my panasonic - it would appear that none of the codes will actually turn the TV off because they need a longer signal to turn off. I eventually found that code 0650 works for mine - input the code as instructed in the manual and then selected OK - holding down the standby button on the humax controller then turns the TV off. Try all the codes and see which gives most control functions. Hope this helps.
Jan 01, 2009 | RCA 3-Device Universal Remote with...
Panasonic DVD Recorder DMR EX95VEBS remote control only displays DVD3 how can I reset this to get back to proper functions?
Dear FixYa
Thank you for your support. I have solved the problem on my DVD Recorder by reading other peoples solutions to this problem. My DVD display was showing DVD3 and all buttons would not work. So on the handset I pressed the ENTER/OK button and no. 3 button together for a few seconds, this cleared DVD3. I was so pleased that this worked. croneruk, 6/10/2008
Oct 04, 2008 | Panasonic DMRES15 DVD Recorder
Vchip was accidentaly set by guest and password was forgotten
For Panasonic:
Parental Lock Feature
Combo's, Screen will say VCR Lock Activated.
During stop or power off, hold the stop/eject button on the unit for at least seven seconds.
Combo's, Another method
With unit on and no cassette inside, hold the rec/time button on the front of unit for 7 seconds.
CTV's Lock Mode
Only the on/off button will work,the others have no effect. Press the action and power buttons at the same time on the front of the set for 10 seconds or so.
LCD TV's, Lock Mode
If customer forgot Parental Lock Code, unit must be re-initialized.
Press and hold the Volume down button on the front panel, press the OK button on the remote for 5 seconds.
DVD's Lock Mode
Setting Method
The sales demonstration lock function is set by simultaneously pressing the "POWER" button of DVD Player on the remote control unit and the "STOP" button on the main unit. ("LOCKED" is displayed when the lock function is engaged.)
Release Method
The function can be released using the same procedure as for setting. If the remote control unit is not at hand, the function can be released by using the same method as for player initialization (pressing the "PAUSE," "SKIP/SEARCH<<"and "OPEN/CLOSE" buttons simultaneously).
VHS-DVD Recorder (DMR-ES40V), Forgotten Ratings Password
From the Owners manual: Open tray, Keep Pressing Rec and Play/X 1.3 buttons on the remote for 5 or more seconds.
Another servicer found resetting to defaults worked well.
(VCR>DVD Dub) + (Open/Close) + (DVD Rec)
Bill
Apr 01, 2008 | Panasonic CT-27E13 27" TV
Error code RC3
I absolutely can't believe this worked for me, I'm so excited!! My error was RC3; my remote had an OK button (not Enter) for a Panasonic DVD/VHS recorder. I held down OK and the number 3 and the remote started working!! Thank you so much, I was getting very frustrated!
Sep 12, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Televison & Video Logo
21 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
