Question about Kenmore Washing Machines
Kenmore washer model 4528191 - Kenmore Washing Machines
I need a washing machine manual for a Kenmore top loader, model number 22422100
Please check your model number. Kenmore washers have a 3 digit prefix followed by another 8 digits. If your full model number is 110.22422100, then Manage My Life has the manual here: http://www.managemylife.com/mmh/owner_manuals/12008/KENMORE-Residential-Washers-L0407343?brand_name_search=110.22422100 . This is a generic manual for all Kenmore one-speed automatic washers. A copy of the descriptions of the washer settings is available here: http://www.managemylife.com/mmh/owner_manuals/15224/KENMORE-Residential-Washers-L0305156?brand_name_search=110.22422100 .
I hope this helps. If your washer has a different prefix, please add a comment with the prefix. I'll try to find manual for the correct model.
Jan 22, 2012 | Kenmore Washing Machines
I need the electial diagram for my kenmore washer model 110.20702990.
See the following two documents:
The first is the Sears parts list including major component diagrams and parts / prices:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11020702990/0582/0153200?pathTaken=
Also see the Whirlpool / Kenmore Service Manual for top load, direct drive washers:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Jan 04, 2011 | Kenmore Washing Machines
Diagram for Kenmore Washer 110.26912690
See the following Sears Parts site for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-110.26912690/0582/0153200?pathTaken=
Also see the following Whirlpool / Kenmore Service manual for top load, direct drive washers:
Sep 17, 2010 | Washing Machines
Belt is loose or needs replaced. on a 70 series kenmore washer machine
Can you provide the exact Make, Model and Kenmore model number? ..........
Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines.........
The model number on top load washers is usually found by lifting the lid and looking above the tub.
The Fixya numbers are Stock Numbers.
Since basic top load direct drive, top load electronic and front load washers are very different, the actual Model Numbers are necessary to correctly diagnose the problem.
Slipping on direct drive washers is usually caused by a damaged / broken Motor Coupler or clutch.
If yours is a direct drive machine, see the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135&osCsid=5666a1d539401da8aec3c1514f2bc0f9
Jul 09, 2010 | Kenmore 24032\24036 Top Load Washer
Model 417.43042200 Kenmore Washer
I HAVE A KENMORE FRONT LOADER WASHER. MODEL 41743042200 AND IT MAKES A NOISE WHEN IN THE SPIN CYCLE, THIS ONLY HAPPENS WHEN SPINNING. CAN SOMEONE HELP
Apr 23, 2009 | Kenmore 45081 Front Load Washer / Dryer
Kenmore Model 417.44072300 Front Load Washer
Kenmore Model 417.44072300 Front Load Washer Kenmore Model 417.44072300 Front load washer.
The drum is loose. I pulled the back panel off and the nut is tight behind the drum? could it be the bearing? do I need to change the whole drum? is this a common problem or was this do to abuse.
Jul 28, 2008 | Kenmore 46462 Front Load Washer
Washing Machines Logo
99 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
