I have a Halstead Hero 60 boiler that makes a clanking and banging noise everytime it comes on. it lasts for about a minute then stops. what can tis be?
4 Suggested Answers
burzerko
  • 254 Answers
SOURCE: when the gas boiler comes
This is caused by a weak flame sensing device. As main burner ignitin occurs this creates a roll out condition , when this condition occurs it derives oxygen from the pilot light thus reducing flame signal and causing the pilot to drop off momentarily.
Posted on Nov 15, 2008
meBNme
  • 334 Answers
SOURCE: boiler bangs when hot water used
You need to install a "water hammer arrestor" they can be found at any local plumbing supply house.
If you can find one with "Shark bite" fittings already installed then there will be no need for soldering or special tools other than a tubing cutter.
Posted on Dec 27, 2008
heatman101
  • 43501 Answers
SOURCE: I'm trying to get hold
Here is a site that seems to have everything in that line...
May cost you a few $$ but it will be worth it...
Halstead Boilers Ltd
heatman101
Posted on Oct 02, 2010
Banging boiler
How to remove the air from your boiler heater The boiler is probably air bound, and the system needs to be purged of air. The link is for an informative video. It will explain the various parts/ produdures to purge the system.
Bleeding Hot Water Boiler
Apr 09, 2014 | Washing Machines
Glow worm 45-60 standing boiler making banging noises when in operation
The noise you refer to is called Kettling, it is caused by the hot water in your boiler not being able to leave the boiler quick enough, if the problem developed quickly and your system is a "fully pumped " system this would generally point to your pump either has failed or is on its way out, i.e . your radiators would not heat up as the hot water is stuck in the boiler hence the banging......( if you know where the pump is you can generally feel if it is running by a small vibration ) if you have gravity hot water and pumped heating circuit then I would assume that it is noisy when just doing HW, and the banging is a problem that has gradually got worse it can indicate that the boiler is scaling up (are you in a hard water area). if this is correct there are various additives that can be put in the system to help quieten it down, I suggest you really need a heating engineer to diagnose fully.
Feb 07, 2014 | Water Heaters
My boiler keeps making a ringing sound. Like a small bell on a bike. What could be causing this noise
Note sure if its the same thing but my boiler (halstead Best 50) made a ringing sound just like you describe. It was the flue fan blades just catching the metal surround of the flue vent on occasions. It only happened when the boiler had been running a while. A new fan was fitted and everything ok now.
Oct 28, 2013 | EuroSteam Steam Iron w/Boiler Tank & Lint...
Clanking noise coming from Allison Transmission on a 2001 Chrevrolet Silverado 8.1 Liter engine
this does sound like theres a loose line tapping the engine/frame,during warm up the engine idles faster which could make it vibrate faster causing the the clanking or tapping noise,if this has started after trans fluid change,then check the lines running from the trani to radiator sometimes the service person might bang into something causing plastic clips that hold the lines to break,try getting under it and have someone start the truck and listen to see where it's coming from also hold the lines & see if the noise stops,the service guy could have unbolted something & never put the bolt back causing the clank ex.line may have a clip holding it thats bolted to the trani pan ?good luck
Dec 29, 2012 | 2001 Chevrolet Silverado 2500HD
GFSS6KKYCSS
If it is a metallic sort of "clank" from lower in the back, it is most likely the inner workings of your compressor has a broken suspension spring designed to isolate motor noise. The bang is the motor coming to life and striking the outer shell. Outside of a new compressor there is no fix. Keith L.
Mar 02, 2012 | GE Refrigerators
I'm trying to get hold of a Halstead CBX boiler 'user guide' and a Halstead RFTH1 room stat 'user guide'. Where can i get these docs?
heatman101
Oct 02, 2010 | Heating & Cooling
Halstead ace high boiler making a whining noise when central heating is turned on also pressure reduces after about 4 hours, need to top up verey day.
Whining = pump bearings
Pressure reduction = pressure relief valve diaphragm either perished of gunged up - look for water coming out of the overflow pipe from the valve
leak in ch system look at all joints
Nov 30, 2009 | Water Heaters
Whirlpool gold makes banging noise
If the refrigerator is working fine the banging noise you hear is the isulation inside the refrigeratior walls that exand and cotract with the change of temperatures. you don t have to worried about it.
Apr 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Heating & Cooling Logo
52 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
