Question about Arrow Tools & Hardware - Others
Arrow 9s How do you assemble the 9s tagging gun?
NEED INSTRUCTIONS HOW TO ASSEMBLE INTERNAL SPRINGS AND PARTS...
After disassembling my EasyShot 5650, I had the same problem with the pesky spring. NOTE: The spring in question is NOT the tension spring for the staples.
The picture shows the internal schematics of an EasyShot 5650 staple gun or tacker by Arrow. It was taken from a reverse engineering project for school kids. Unlike the boring grey one in the picture, the most updated version of the EasyShot 5650 comes in translucent jewel tones.
Oct 08, 2014 | Tools & Hardware - Others
Replacing staples
On the back there is a small metal piece that is spring loaded push it in and down and that should release it pull it out and slide staples in replace assembly remembering to push in and up to reinstall holder .Hope this helps.
Bob
Jul 18, 2014 | Arrow Fastener T72 Wire & Cable Staple Gun
HOW DO YOU ASSEMBLE AND INSTALL A DANCO 9S-4H/C
Turn off the water supplying the faucet. Now open the faucet. Remove handle by taking off index button and removing screw. You may need to purchase a handle puller, 10-15 dollars, and a stem wrench set. After removing handle, place appropiate sized wrench on stem and turn counter clockwise. Before installing stem, make sure it is in the open position. You may need to use the handle to turn the new stem. Screw in clockwise.
Jul 05, 2014 | Danco Faucet Stem
Reassembling powershot stapler
You might be able to get assembly instructions and/or a diagram from Arrow. Schematic diagrams usually pertain to electronic equipment
Jun 25, 2013 | Tools & Hardware - Others
I was messing around with my calculator. I pressed 9 and then pressed enter repeatedly until my there was a big column of 9s. Then I pressed second up and held it and pressed 6. The screen became totally...
Turn the calculator on. Press an release the 2ND key, then press and hold the down-arrow key until the screen lightens. If you go too far, press and release the 2ND key then press and hold the up-arrow like you did before.
Oct 20, 2010 | Texas Instruments TI-84 Plus Silver...
I need to put in new staples. How do I do it?
This stapler does not swing open like a paper stapler. It has a little square metal piece at its heel (about the size of a postage stamp). Press in lightly on this metal piece as you move it up or down just a bit, to unhook it. Then pull out the piston and spring assembly, insert staples in the hole and replace the piston. You must use T50 staples (of various lengths). T35 and others will not fit. Good luck, Al K
Sep 01, 2010 | Arrow T50P ARROW STAPLE GUN
Arrow T50P gun jammed - how do you unjam it?
Buu a different brand or model this one is junk and should be taken off the shelf
Feb 06, 2010 | Arrow T50P ARROW STAPLE GUN
Stanley sharpshooter staplegun
how do you put the brads in the gun?
Sep 11, 2008 | Arrow T25 Staple Gun
Tools & Hardware - Others Logo
224 people viewed this question
Top Arrow Tools & Hardware - Others Experts
JOHN LAPIER
Mike
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
