Question about Samsung SF-5100 Plain Paper Laser Fax
Can send but not receive faxes
Got fax from somebody else. Need to change fax number on fax maybe that is the problem. The previous owner's name and number is still on there.
No identification is not the problem. It sounds like you have it set to "manual receive" rather than "auto receive"
Posted on Apr 26, 2009
My fax machine MX532 won't let me send a fax though the machine
This is probably an issue for the receiving fax. Try this:
1. Find a piece of paper and write fairly large:
Call me if you get this
Your name
Your phone number
2. Send this to a different fax machine at a different company and location. If it works, then attempt to send it to the same fax you initially attempted.
- If it works then your document may be too large and you will have to send it over a couple pages (or less at a time).
- If it doesn't work then there is a compatibility issue with either your or the receiving end fax machine. You will have to find an alternative fax number to a different model fax machine. Don't expect the company on the other end to just change out their fax machine but they may have another model at a different phone number.
Another alternative - you can attempt to scan your documents and send them by email but check with your and the receiving destination security departments.
Best wishes,
Joe
Aug 25, 2016 | Canon PIXMA MX532 Wireless All-in-One...
When ever i recieved fax its gives me fax remote error after 15 20 min it prints
Hi. You may be having a problem with the quality of connection. Check telephone cable for any physical defects. Try to plug printer in a different phone jack in the wall. Try to call your phone company to have the line checked, maybe they can do something to increase the quality of signal. Make sure that you already registered the user information like your fax name and your fax number in the fax by going to Fax mode > press Menu > Fax setup > Dialling and Sending > Your Fax Name or Your Fax Number. You can also decrease the transmission speed of your fax by going to Fax mode > press Menu > Fax setup > Dialling and Sending > Max Send Speed > change the speed to 9600 bps > hit check to save settings. Hope this helps.
Mar 14, 2010 | Lexmark X5470 All-In-One InkJet Printer
How do i change my fax number
Changing the Fax Configuration
1 Click Start/Programs or All Programs/Accessories/ Communications/ Fax, and then click Fax Console.
2 In Fax Console, click Configure Fax on the Tools menu to start the Fax Configuration
Wizard.
3. On the Transmitting Subscriber Identification (TSID) screen, type the identification information (usually your fax number and your name or business name) in the TSID box. This information will appear in the header area of the faxes you send and identifies your
fax machine to the person who receives your faxes.
Aug 16, 2009 | Dell 942 All-In-One InkJet Printer
Given a Brother 590MC FAX machine, Need to remove previous detail
You can go under (menu) and then (Initial Setup) and using up or down tabs move till you see Machine ID. Press (menu) or (ok) button and change phone, fax number, and name. Press(ok) button after each is set to your specification. Hope this helped!
Mar 13, 2009 | Office Equipment & Supplies
Need to reprint previous fax.
you can't. check the journal for the last receive transaction fax number. send a request for re-transmit.
Mar 11, 2009 | Brother IntelliFax-2820 Laser Fax
Printing wrong fax number on paper headings
HI
Cant find a manual for that model but this is close enough for changing the details i think.
Download it from here
http://safemanuals.com/user-guide-instructions-owner-manual/CANON/IMAGERUNNER%202025I-_E
Feb 16, 2009 | Canon imageRUNNER 3035 Black and White...
Want to change the Header
Press Data registation,on usersettings press set,press the arrows untill you get unit name,press set,insert you company name there.
To change the fax number-under usersettings select unit number and change it to your number.
Jan 12, 2009 | Canon LaserClass LC 8500 Plain Paper Fax
Need to change name and number
Press the MENU button and press 7, then 2 on the numbers keypad. You can then use the keypad to change the fax header. Press the keypad numbers corresponding to the letters you need. It will cycle through lower case first, then upper case. Press the RIGHT arrow button to advance one space between letters.
Jul 18, 2008 | HP 920 Plain Paper Fax
Changing user name on used machine
there is the HELP key on the pannel board press it and go in the user data so you can find your desire setting or go by function key
Sep 20, 2007 | HP 1240 Plain Paper Inkjet Fax
Samsung SF-5100 Plain Paper Laser Fax Logo
153 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
