Fault H4-01 on Sharp Photocopier ARC-172m
Does anyone know what these means or how to clear it ?
I have HL-1450 Brother Printer but i don,t have its driver please solve my problem
Posted on Jan 28, 2009
How do I clear F2 and H4 on Sharp photocopier
F2 means wrong cartridge installed, could be a bad cartridge. H4 is a low fuser temp error. try resetting by pressing "#","interrupt","C","interrupt. then press"1","4","start". then turn off/on and see if it clears. if not you will need a tech.
Nov 12, 2009 | Televison & Video
Please .. my Photocopier sudunly stop and find
My Sharp is a different model but my reset is:
Hit:
Clear (then)
Auto (then)
Clear (then)
Auto (then)
14 THEN
Start
It resets itself.
Oct 06, 2009 | Sharp AR-207 Copier
My black and white sharp photocopier mdel sf 2530 is showing h5 what is the meaning of this fault and how do i clear this fault
Hello sir; To reset H5 ,you have turn power on then open front door, press and hold exposure key while you closing front door.
Oct 06, 2009 | Sharp Office Equipment & Supplies
How to reset u2-40 for sharp AR266 photocopier
Since this appears to be a non-US model I can only base my response on the closest US body type AR-M237.
U2-40 means the countdown (CRUM) chip in your toner cartridge either broke or went to zero. If you can put in a fresh CRUM chip in your cartridge, that's great, otherwise you'll have to replace the toner cartridge.
L4-01 means main motor lock, probably due to a brownout or otherwise missed timing. You can probably get by with a power off and on. Not sharing your copier with other devices on the same outlet will also help here.
To reset error codes, put the machine in test mode with the four-key combo: # - * - C - * ... 16-Start clears your U2 trouble, 14-Start and 17-Start clear the rest. Then hit CA and allow your copier to reboot. Good luck!
Jun 02, 2009 | Sharp AR-M237 Copier
Sharp ARC-172M how the drums get out?
open the front cover. remove the toner cartridge/s by lifting the green lever and pulling the toner out. Open the left side door. look at where you just pulled out the toner and there is one screw (facing you) holding each drum in place - loosen the screw and pull the drum out towards you....done.
Apr 21, 2009 | Sharp AR-BC260 Color Copier
SHarp Z-20 home photocopier toner refill- Manual?.
There is a small door at the right front, unlatch from the top, open the door and unlatch the green tab on the cartridge and pull the cartridge out.
Mar 17, 2009 | Sharp Office Equipment & Supplies
SHARP AR M-205
Hello sir; this error code require reset the procedure as follow;
1, press "#", "interrupt", "clear", "interrupt".
2, enter 14, press start.
3, turn power off and back on
Feb 07, 2009 | Sharp AR-M205 Copier
Sharp arc 270 error code l4-04
Possible bind in one or more of the developer units. Replace as needed. Sec. 11 Page 11-61 it talks about Paper Feed Drive Motor, it is the same motor as the Black Developer Drive Motor.
For L4-04 swap those two motors around to troubleshoot bad motor
Feb 03, 2009 | Sharp AR-C270 Color Copier
Printer displaying an error message: 2U
There is a long list here for the U2 code so if you let me know I will tell you what it means..
Again what is the Last part of the Code?
If it is U2-40 code, it is a Crum Chip, Take the toner out clean the end of the toner cartridge, there is a chip, a small plastic connection piece with bronze/silver wire on it.
Or replace the toner cartridge.
You will also need to clear the code with simulation 16.
Turning the machine off might work but, not usually.
Oct 28, 2008 | Sharp AR-M205 Copier
AL-1000 Sharp Photocopier
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Mar 11, 2008 | Sharp AL-1000 Laser Printer
80 people viewed this question
jasbo
jasbo
