Question about Sanyo PLC-XT20L Projector
IS THERE ANY FUSE INSIDE THE PROJECTOR - Sanyo PLC-XT20L Projector
    President:
  • 1,073 Answers
Nop! there is not!
And if you want the manual to see if for yourself you will find it here.
http://www.aboutprojectors.com/pdf/sanyo-plc-xt20l-manual.pdf
Good luck to you
Nic
Posted on Jan 28, 2009
My argus 300 projector bulb blew new one won't work
yes could have been a power surge at the time, or fan cooler packed it in, the internal housing inside the Projector would have been too hot with the bulb inside it cooling down without the fan, i would double check all parts near the lamp housing and check to see they have not melted or burnt, also worth checking the fuse as well should be a T-250 Fuse bulb
Apr 23, 2017 | Argus Vintage Cameras Inc Projector Model...
Optoma h79 wont power up is there a fuse to replace if so where is it thanks
hi,
All electronic equipments have fuse in the power supply section.
In your projector it is inside the unit. The fuse of projectors will blows only if there is any trouble in the power supply. Just try to replace the fuse in the power supply board. It will be near the input connector. If the fuse again blews then you have to replace the power supply board. Because the components in a projector power supply is rearly available. You will not be able to access the fuse with out oppening the projector.
OK
Oct 08, 2011 | Optoma H79 Multimedia Projector
Digital projector not working
check if standby led on projector is glowig red, if yes pannel keys may be in off mode, try to power on with remote control.if standby led does not glow, check power cable and its connections and safety fuse inside projector.
Aug 14, 2010 | Sony VPL-ES1 Multimedia Projector
My panasonic ae900 projector suddenly stopped getting power. No indication lamp is lit.I checked all the outlets and power cords.Could it be a fuse? if yes, where is it located?
there is 2 fuses, one in the power lead and one inside in the projector close to where the power cord enters the rear of the unit, the one inside is white in colour, remove the fuse and test it with a long nose plyers and test it with a multi meter, then you know if you need a new power supply or software
Aug 22, 2009 | Panasonic PT-AE900U Multimedia Projector
EP716 Optoma Projector Fuse
There is no fuse. I took my EP 716 apart to find out why it died. I found a resistor had blown on the power board made by the Tiwan co. Quazarpower.
Dec 11, 2008 | Optoma EP716 Multimedia Projector
No pawer
have you checked if there is a fuse inside the projector
Jul 24, 2008 | Epson EMP 7500 Multimedia Projector
IN72
Hi TheMull
I also checked and the fuse looked fine , but I thought to myself why not take a chance and replace the fuse as this is a very cheap part , and it worked.
May 29, 2008 | InFocus IN72 Multimedia Projector
NEC Projector
they have a fuse on the power board inside the projector itself, But normally the fuse does not go bad unless their is a dead short in the unit.
Dec 13, 2007 | NEC MultiSync MT830 Multimedia Projector
Internal fuse
HI
Check that you use another power outlet,see that the power cord pins are clean,and not burnt or use a new cord,the connection at the projector makes a GOOD connection with the new cord.
You will need a multimeter to check if there is voltage at the inside of the projector cord connection.You will have to remove the internal fuse before you check the the voltage inside.If all looks good then you will have a fault on the circuit board-shorted component on power supply side or further in on the circuit(need an electronic tech for this).Hope this helps--Jay
SAFTEY FIRST ALL TIMES--NOT SURE DO NOT DO IT
Oct 16, 2007 | Hitachi Performa CP-RS55 Multimedia...
No power on Compaq MP2800 Microportable Projector
I am currently struggling with this issue.
There is an easily-accessed fuse inside the projector.
I was very excited to discover this last night.
However, before you get you're hopes up (as I did) remember: If the fuse blew, something else probably went first. After buying and replacing the fuse today, I realise that I need to replace or repair the power supply as it pops the fuse every time.
Here's how to get to the fuse:
Take off the lamp.
Now, looking at the projector from the back, you need to remove the left hand side panel.
This involves taking out 2 screws from that panel, 2 from the bottom and the 2 video connector hexagonal bolt things that are also in that panel.
The panel sort of hinges off, starting from the bottom.
You will see the fuse in the bottom right corner where the power lead goes.
It is a slow-blow (time delay fuse) so get the exact same one to replace it. A pack of 10 cost me €4.19 in Maplin, Galway, Ireland.
Anyways, this did not do the job for me... the power supply set the fuses off like fireworks and also blew a few in the socket plug as well (I don't think US readers will have those)
I will let you know how I get on with the power unit....
Good luck to ye!
Sep 23, 2007 | Compaq iPAQ MP2810 Multimedia Projector
Sanyo PLC-XT20L Projector Logo
142 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
