Question about Bose Companion 5 Multimedia Speaker System (3-Piece)
Hi. my Bose companion 5 speakers are emitting a loud low buzzing noise when turned on. I always leave my PC on. It was off this morning so i turned it back on, noticing it had tripped the circuit switch on the power board. i've tried uplugging everything, all connections to it and re-booting the PC. I unplugged it completely and tried it in a different power source. it still emitts this noise, even when the input is not connected to anything. Can you please help? Nick
Its got nothing to do with the bass.. i have the exact same problem.. boss comp 5 are pretty useless .. its either usb or mini jack use them both and thats when problems start .. buzzing like mad.. if id have know id have gone for boss 3 .. waste of 100 quid id say.. seems 2 inputs conflict against each other .. go for boss 3 i say
Posted on Jun 21, 2009
    Problem Solver:
  • 15 Answers
Bass is set to loud
Posted on Jan 28, 2009
Hi i have the Bose Companion 5 speakers for more then a year now i have been playing them for over an hour and just realised that they keep fading the sound goes high and low i have never experienced this...
i just bought companion 5 1 month ago and am facing this same problem from 1st week. its an embarrasment. i had given it to the service center and they could not detect the problem. so i did my own research and found that if i kept a fan blowing on the rear vents of the acoustimass module the problem does not occur.you also please check it. i have again given the acoustimass module to the service center and told them this lets see what they do???
May 28, 2011 | Bose Companion 5 Multimedia Speaker System...
Wrong voltage applied
Whoops! Being a Bose, you should be lucky but the sounds you describe are not good. Take it to a competent engineer and get an honest opinion.
May 24, 2017 | Bose Companion III Computer Speakers
Main Bass speaker not working!!
Hello Adam Hi, it looks like your main IC amplifier inside the main bass box is bad, need to replace that IC. What are your plans, do you want to do the repair or have it service by a tech guy.
May 06, 2010 | Bose Companion 3 Computer Speakers
I have a bose companion 5 and when i pwer it up the sub buzzes and then trips on overload has anyone had this issue before ?
Yea, thats why i switched to a Logitech Z2300, get the same sound for less.. the amp in your bose is gone. Need to replace the system or but the above mentioned product.
Apr 18, 2010 | Bose Companion 5 Multimedia Speaker System...
I have Bose Companion 2 Series ones and the left makes odd noises
> I turn the volume to a low it still has the odd noise
If there is any drive to the speaker at all (volume not turned off), the rattle is probably coming from a broken 'surround;' the part that keeps the cone centered around the outer edge.
Another point of failure is a structure called a 'spider' that is located between the voice coil and cone that ensures the voice coil stays centered.
If there is hum with the volume turned completely down, the amplifier driving the speakers (internal or external) has a failing filter in the power supply.
Dec 14, 2009 | Bose Companion 2 Computer Speakers
I have the Bose companions 3 series 2 speakers feedback problem
Another possibility: make sure both speakers are at least ten inches away from any router.
Sep 16, 2009 | Bose Companion 3 Computer Speakers
Loud hum when Bose Companion 3 Series II speakers are turned on.
I had the same problem for many months. I asked a sound & video professional and he suggested I move the subwoofer away from any power source. I had the subwoofer next to my UPS. Once separated and moved all wiring away from the power supply (about 12") the low bass hum was practically gone.
Jun 28, 2009 | Bose Companion 3 Series II Multimedia...
I use low wattage of transformer to my companion 5bose speaker now there is no sound what should i do.
i suggest that you will stop using that low wattage transformer. Using that transformer might destroy your speaker. You should provide the right wattage which the speaker is requiring. Just look at the back of the speaker and you will the required wattage.
Andrezarion
Mar 22, 2009 | Bose Companion 5 Multimedia Speaker System...
Bose companion 3
This is a common problem it seems with the electronics within the speaker set. (Companion 3 with sub and remote pod, aka, 'puck' = help desk support term)
I bought the multimedia speaker set in 2004 and had it replaced in 2005 because the 'puck' would not turn on (no orange light nor green light.) So I called help desk and they accepted the warranty exchange and I mailed the entire system (speakers and all) back to Bose in Markham, Ontario, Canada and they sent it back several weeks later. It worked 5-6 years after that as it is 2009 now, and it has the same problem again (no light on the puck). So I called help desk again and was ran through the same tests again (on/off, power plug off, various audio inputs, etc.) and the guy said to mail it in and they'd fix it as a non-warranty item. Cost: $85(Cdn) for repair + taxes, and $39 for remote pod.
So the sound that I got to enjoy from the Companion 3 system was amazing but electronic quality is very poor. For a set that cost above most other home user sets at FS and BB, it is substandard longevity.
I like Bose and have no complaints about the sound, but I will not buy another Bose multimedia package because at $350 (in 2004), I would expect it to outlast other sets. My friend bought a Logitech speaker set from another company in 2003 and is laughing at me as he realizes this is my second set and it hasn't even lasted as long as his own set.
Dec 03, 2008 | Bose Companion 3 Computer Speakers
Where Can I purchase a bose companion 5 control pod?
You can purchase it from amazon, click here Amazon com bose control pod and choose, which one fits to you.
I hope I was helpful
enjoy
Nov 25, 2008 | Bose Companion 3 Computer Speakers
Bose Companion 5 Multimedia Speaker System (3-Piece) Logo
1,294 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
