Question about Toshiba Libretto 100CT Notebook
100Ct toshiba liberetto 100Ct operating system curepted how to repair os?
    Brigadier General:
  • 6,966 Answers
Hi, Depends on what OS you are using. For this particular model (Libretto 100CT), it is probably either Win9X or RedHat (or some Linux variation). In Win9X, you might try F8 & run it in DOS and run: Scandisk c: /autofix /surface; Scanreg /fix If it is beyond repair you have to have access to the OS installer CD. Sometimes Win9X installer is also saved in the HD. Try checking if it is inside your HD and run setup. Hope this be of some help. Pls post again how things turn up. kind regards.
Posted on Jul 24, 2007
SOURCE:
My Toshiba qosmioF25AV205 is displaying a blue screen fatal system error and then rebooting. Please how do I fix it
That is a Windows Registry error. You need to do a repair install of the Windows Operating system. It reloads Windows over the top of your installation so you won't lease your data. If you have the Restore Disks, install disk 1. Sometimes the OS is on a hidden partition on the laptop itself.
Toshiba has Support. See the link.
http://support.toshiba.com/support/modelHome?freeText=1021512
Nov 04, 2015 | Toshiba Computers & Internet
Sir i have perchase a lenovo laptop 316 serial no CBQ396181. i have a problem with window every month my windo is curept when we go to the retailer shop he said this is is a system problem please tell me...
Lenovo definitely provide a genuine copy of Microsoft Windows OEM operating system upon marketing. If your having troubles with the OS it is a possible corrupted data file and normally performing a recovery to factory default to clear it out and reinstall the OS will fix it.
Apr 10, 2011 | Computers & Internet
Cannot find operating system
system files corrupted may be because of virus
repairing the OS with the OS cd may work if not formatting is the option
Feb 22, 2011 | Toshiba Satellite Pro A200-EZ2204X...
What are the maximum limit to increase the hd,ram,prossesor in sattelite u100 toshiba notebook 2005
Your model has room for one expansion memory module. Toshiba typically came configured with one static module. The memory specification is very likely DDR PC2700. The maximum size available for one memory module of DDR PC2700 is 1 GB. The HD size is only limited by what you can find with a PATA (IDE) interface, typically 320 GB. Installing a new processor may be prohibitively expensive, and the speed would depend on BIOS support. The BIOS may support the fastest Pentium IV processor, @ 3 GHz.
A link for a 320 GB drive, @ $96.28 (shipped) is here.
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136345
The link to your manual is:
http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=http--cdgenp01csdtoshibacom-content-support-manualserguides-su1036115-librettou100-u105ug20050511pdf&sliceId=pdfPage_1&dialogID=117884287&stateId=1%200%20117882861
If you find this helpful, please vote accordingly. I'm just getting started helping here and the votes would be great thanks :)
Aug 11, 2010 | Toshiba PA2502U - Libretto 100, 110,...
When i turn it on it says run recommeded repair or run normal setup then when i run the repair it says hardware or software missing please select ok to shut down and when I run normal set it just goes back...
it's mean your operating system is failure so just do repair or format Ur OS & re install fresh copy of operating system..but take backup ur document before formatting Your OS.
Mar 25, 2010 | Toshiba Satellite Pro L300 Notebook
I cant reformat my Toshiba libretto L3. I tried everything
You cant boot from cd. Try changing the boot order in the BIOS and allow the CD to have ownership over the Harddisk Drive. This way the computer is forced to boot from the CD.
Jan 16, 2009 | Toshiba PA2502U - Libretto 100, 110,...
Libretto 100ct
Está desliogando sozinho.... o que fazer?
Oct 25, 2007 | Toshiba PA2502U - Libretto 100, 110,...
How to overcome 8.4gb bios limit on a toshiba libretto 100ct?
Ok get a program called Partition Magic, I have found you a Tutorial here: http://www.le.ac.uk/cc/dsss/docs/pm4-main.shtml Basically, you divide the 8.5GB into smaller sizes, NO MORE than 4GB, so say 2x3GB, & 1x2.5GB, or whatever suits.. then ya Format each Partition, Make ONE an Active Boot Partition, the rest logical ones. Your actual Size of the drives will be less than the Total due to Formatting information etc. Read the tutorial carefully B4 ya do anything. Ya be using the bigger storage in no time...
Aug 14, 2007 | Toshiba Libretto 100CT (P000249540)...
Toshiba Libretto 100CT Notebook Logo
117 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
