Question about KitchenAid KGRA806PSS Gas Kitchen Range
51 E6 error, door latch error
Kitchenaid KGRA806PSS gas range. The first problem I noticed was that I would turn on the oven and it would get stuck on a low temp. it happened twice and both times i shut the oven off and turned it back on and it would then work ok. A few weeks later I turned the oven on and after about 1 minute the oven went off and the error code F1 E6 appeared on the panel, and the oven does not work at all.. We unplugged the stove and waited awhile and plugged it back in and received DOOR LATCH NOT OPERATING. we also get that code when recalling the last error code. We called for service ( 3 years old and no warranty) the repair person told me that it would cost us 1000.00 to repair it because it was the control board that got fried from the heat from the oven due to where it is situated. He said it happens to all of these stoves and that it would happen again if we had it replaced and we should buy a new stove.he did not even look at the stove. all he did was read the paperwork. Instead we read the manual and it seemed that this code pointed to changing the control board. we bought a new one and replaced it and it still does not work. we still got the same codes. we can't return the part because we installed it. we tested the door latch and it doesn't seem to be operating but we don't know if its a faulty door latch or something else causing the door latch not to work. I never had the problem of the door not opening after cleaning the oven. We need to know what to do next. What parts to order? when testing the latch it does show that the motorized lock is not working.
  • 11 more comments
  • L mc Jan 28, 2009
    the door did not ever lock up. we did replace the control board with a brand new one and we are still getting the same code. F1 E6 and when unplugging and replugging the power - we get latch not operating.
  • L mc Jan 28, 2009
    The door is not locked. I never had that problem. We did unplug for over an hour.
  • L mc Jan 28, 2009
    and again. we did replace the control board with a brand new one. the same codes are coming up. is the control board that you are talking about - the one directly behind the control panel? that is the one we replaced.
  • L mc Jan 28, 2009
    i tried the resets nothing worked.
  • L mc Jan 28, 2009
    we have already contacted kitchenaid with no help from them.
  • L mc Jan 28, 2009
    Kitchenaid Gas Range oven not working. F1 E6 error code. Also latch not operating error on display board. called kitchenaid - they had us reset. it didn't work. they sent repairman from A & E. He said it was the computer. we opted to repair it ourselves. we bought the control board and installed. oven still does not work, still getting the same errors. What else can this be? THE DOOR IS NOT LOCKED. IT NEVER LOCKED.
  • L mc Jan 28, 2009
    WHAT IF THE PRESSURES AND AIR DOME DO NOT PASS TESTING?
  • L mc Jan 28, 2009
    thanks. i ordered the part. i'll let you know if it fixes the problem.
  • L mc Feb 03, 2009
    Kitchenaid KGRA806PSS gas range. error code F1 E6 when preheating oven. oven shut down. recalled last error ( latch not operating ) replaced the control board. same errors came up. replaced motorized door latch. same errors. still no solution.
  • L mc Feb 03, 2009
    the door latch has been replaced. still errors and oven doesn't work.
  • L mc Feb 03, 2009
    The door latch has been replaced. I believe the door switch and door latch are one piece. I am at a loss of what to do.
  • L mc Feb 03, 2009
    the problem is with a gas range. not a printer
  • L mc Feb 03, 2009
    this gas range is not yet 3 years old. the oven stopped working and the control panel showed an internal error. F1E6. when unplugged and waiting an hour and replugging. the error became "latch not operating". the stove is not under warranty so we researched the errors. everything pointed to changing the control board. we replaced it and it did not fix the problem. we also replaced the motorized latch with no luck. we do not know what to do next. we were told it would cost 1000.00 to have it repaired. its not even 3 years old. any technical help with this or suggestions would be greatly appreciated. thank you,
    XT0808861
    KGRA806PSS
  • KitchenAid Master
  • 19,396 Answers
F1 E6 is faulty control board, the door latch had been locked for security reasons.
Posted on Jan 28, 2009
  • 2 more comments
  • Ginko
    Ginko Jan 28, 2009
    Try unplugging for longer (or trip circuit breaker).
    Unplug the appliance for oine hour or so and see if this reset F1 E6 , if it does not you need to replace control board.
    To unlock door latck you can try moving the timer control knob while you press the door latch at the same time, try also holding door latch and press cancel.
    Even if you unlock the door you will need to replace the control board if error does not reset by itself.
    See also here.
  • Ginko
    Ginko Jan 28, 2009
    and press cancel.
  • Ginko
    Ginko Jan 28, 2009
    Here is also a reset procedure that works on same Sears/Kenmore ranges.
    STEP 1 Power off and wait 5 seconds.
    STEP 2 Power on and wait 5 seconds.
    STEP 3 Press the following keys:
    CONVECTION - CONV. BROIL CLEAN BAKED GOODS 190 TIMER SET
    NON-CONVECTION - CLEAN STOP TIME 0 OVEN LIGHT 1
    STEP 4 Press START.
    STEP 5 Make sure Timer ID is the same as the oven.
    STEP 6 Press CANCEL to exit.
  • Ginko
    Ginko Jan 28, 2009
    Try also folowing reset procedure:
    "POWER OFF 5 SEC
    POWER ON WAIT 5 SEC
    CONVECTION BROIL
    CLEAN
    BAKED GOODS
    "STOP TIME"
    190
    TIMER SET
    START
    Then depending on whether it is free-standing etc. the START button is pressed. I have a free standing so it was 12 times. "
    from website here.
  • 700 Answers
Go ahead and get a new door latch for the unit. since you did check it out and it was not operational.
Posted on Feb 03, 2009
    Genius:
  • 1,913 Answers
First power off the printer u tell that u reset all settigns to factory defualts right?
now refix your ik cartridge check there is not any paper jam.check in back side.
there is one plate open it then u see RAM refix your RAM or trying change RAM if u have 2 RAM then try it 1 by 1 .it is RAM problem i think .
    President:
  • 2,559 Answers
Replace the door switch.(This is a very common problem)
You may also consider replacing the latch as well.
  • 130 Answers
You got a bum for a repair man. Yes it is the door latch, I find that these codes are usually right on the money. I love fault codes they make my job easier. replace the latch and you should be all set. Sorry to hear you got stuck w/ the panel.
    Genius:
  • 1,550 Answers
The F1 error code indicates a primary control failure or pressure signal out of range. Once the pressure hose & air dome have passed testing, the control board will need replaced.
Also you need to replace touch sensor panel .
  • 350 Answers
Dear FixYa Customer lauriem719,
RE: Kitchenaid KGRA806PSS gas range 51 E6 Door Latch Error F1 E6
I would 1st go to KITCHENAIDS' WEBSITE and ask for help! Click on the link below @
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?siteCd=KAD&searchTerm=KGRA806PSS
Call them toll-free! You can download the manuel, warranty info, installation instructions and parts at the site above!
Note: If your going to download and you don't have Adobe Reader you will be prompted to download it. Adobe is a well known trusted Reader used by many local & worldwide gov'ts, schools and professionals! Feel safe to download it for free!
If you don't believe you can do it, look what this person did (NOTE: This has nothing to do with your project but shows what someone can do when they put their mind to it! Click Below!
http://www.biertijd.com/mediaplayer/?itemid=10248
Hope this is helpful.
51 E6 error, door latch error - 678d778.jpg jackiaria
  • Jack Iaria
    Jack Iaria Jan 28, 2009
    I've just read the reviews on your KGRA806PSS Gas Kitchen Range and the REVIEW IS NOT GOOD!!!!!!!
    If I was you I'd forget trying to fix this and file a claim in Small Claims Court!
    READ WHAT OTHER OWNERS HAVE SAID by clicking on the http:// link that follows @ http://www.mysimon.com/9035-10987_8-2305...
    I'm saddened for you!
    So Sorry!
    jackiaria
  • Jack Iaria
    Jack Iaria Feb 03, 2009
    Once again!
    So Sorry!
    jackiaria
    Sorry I couldn't FixYa!
I have a KitchenAid KGRA806PSS range. The oven door won't register as closed and thusly, it won't heat up. I used to have to have something pressed against it and it would hold shut and I could use it, but...
I found this online...hope it helps. Look towards the center of the door, next to the "self clean latch" youll see a thin metal "plunger", try pressing this in and then restarting a clean cycle, then quickly cancel clean it should reset the lock/latch mechanism
Dec 01, 2013 | KitchenAid KDRS807SSS Dual Fuel (Electric...
Kitchen Aid KGRA806PSS
hmmm....that interlock is dependent on a temperature sensor, to ensure that no one opens that door when it's too hot inside. I'm assuming that it's still locked, even after the temperature has dropped off?
Feb 26, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Kitchenaid KGSS907 oven door locked after self clean mode, what I must do?
Thermostat at the back/rear might have blown.
Is the oven still working?
Then the door actuator motor may have failed.
Jan 27, 2013 | KitchenAid KGRA806PSS Gas Kitchen Range
Kitchenaid KGSS907 oven door locked while in self clean mode
It locks so you dont open it during the cleaning cycle. It gets very hot so it burns everything stuck fast to a crisp. after cycle is over and temp drops it will unlock. dont worry about a small amount of fire as long as it dosent get too big it should be fine. Might make alot of smoke though.
Dec 27, 2011 | KitchenAid KGRA806PSS Gas Kitchen Range
Oven went dead in self clean mode and the door remains locked. Is this the thermostat? How do I get the door unlocked when control panel shut down? Kitchenaide KGRA806
Unplugged the stove and turn off the gas.Take the back off the oven and replace the thermostat. It's super easy. Before you buy the part call kitchen aid... this is a known problem. They will say the parts are not free and try to give you a discount. But if you continue to argue , they'll send it for free.
Mar 02, 2010 | KitchenAid KGRA806PSS Gas Kitchen Range
Lock on oven is locked and door open
look towards the center of the door, next to the "self clean latch" youll see a thin metl "plunger", try pressing this in and then restarting a clean cycle, then quicklly cancel clean it should reset the lock/latch mechanism
Jan 21, 2009 | KitchenAid KGRA806PSS Gas Kitchen Range
try pressing stop/clear press and hold timer for 5 seconds after making sure there is piower to the range
Jan 22, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Kitchenaid Superba Gas Range
It appeared to be something to do with the plenum and cleaning - repair man came - cleansed and it was okay. MK
Jan 15, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
KitchenAid KGRA806PSS Gas Kitchen Range Logo
168 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
