Question about Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV
Sony r60xbr1 tv turns on then shuts off and red stand by lite blinks 4 times
I have had the t.v. for just about 1 yr. and loving it but when I went to turn it on the pic. comes on for about 2 seconds then shuts off at that point the red "stand by" light blinks 4 times sony tech. support told me that the red blinking light (4) times ment that the t.v. was over heating but yet it had not been used all day! approx 9hrs.Could some one help me! thank to all in advance.
  • 139 Answers
Moe,You have several Broken Conns via your Mother Board after doing about 500 in the Past 8 yrs,What you need to do is Get a Magnifying Glass and look at the Bottom of the Main Board and look for Ring Breaks around Conns *Note,Any thing on a HeatSink or Plug Conns,Will be Checked First,Use 60/40 Solder and a low heat soldering Pencil to Fix Good Luck ttech
Posted on Jul 24, 2007
My sony sxrd 60 comes on only for a sec than go off and red stanby lamp blinks 4 times,i have cleanned vents and checked bulb door,can only turn tv off and back on ,and still onlly get screen to show...
4 times red light blinking indicates problem with exhaust fan that is not running and tv shuts down instantly due to protection mode activation.
Please check exhaust fan and make sure its connector is plugged in and fan runs freely.
Thanks.
Apr 19, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
Sony tv red light blink 4 times on 60" WEGA
When your red light blinks four times on the Sony KDS-R60XBR1 60 inch HDTV, this is an error code for a stopped up fan. You will need to check the ASU board to verify Fan1-4 power to the fan is supplied, next check the fan connector to make sure it is properly connected, and finally make sure the fan is not caught in the wires or harness.
Feb 27, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
Tv won't turn on 4 blinking led
Red led blinks 4 times is an error code that shows that fan is not running in tv, check fans connections and make sure all are plugged properly.
Thanks.
Jul 18, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
I'm getting the 4 red light blink on my sony R60XBR1. What should I do. I've read to just clean the fan. Is this legit?
Yes this is legit. There's 2 fans and take out the big fan and clean it using a brush or something. I just did yesterday when my TV would not turn on with 4 red blinking light. Now the TV is working like new. Make sure you put everything back including the casing before you turn on the TV.
May 09, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Had Blinking RED blinking lights. FIXED
CHECK LAMP COVER, CLOSE IT AGAIN THE RIGHT WAY
Feb 21, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
I have power but it will not turn on. unplugged from power cord overnight then plugged into wall worked fine until i shut it off again, now it keeps blinking the delay light
go to turn tv on,hear a poping noise,once then tv standby lite blinks 3 times repeatily but no picture or audio.can you help me out with this thank you
Feb 14, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
After a power failure I have 4 red blinks and tv
The fan has stopped most likey a problem with the AGU board
Jun 17, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
TV does not turn on. Stand By LED blinks 4 times and pauses and blinks 4 times again Tv will not turn on...when plugged in the red stand by light flashes 4 times...you can hear the tv turn on but a black...
On older Sony, sometimes a power surge causes the set to be in shut down mode. Try unplugging for 5 minutes and then plug in and try. This many times will fix.
May 31, 2009 | Sony KV-27S42 27" TV
KDS R60XBR1 Red Light blinks 3 times when turning
on my xbr tv there is a little *** that sticks out on the lamp cover. the wrapped and it wont work light flashed 3 time with a new cover it worked fine. there was a t. s. b. for an over heat problem new fan and sensor and door. go to sony.com its there
Mar 22, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV Logo
83 people viewed this question
Top Sony Televison & Video Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
