Question about Bosch Axxis+ WFR 2460 Front Load Washer
How can I change the Carbon Brushers
Hi, I tried to exchange the Carbon Brushers, but realized that I most probably have to take out the enire motor of my Bosch washer to do this. Does anybody have an idea how to avoid that? There are some kind of plastic bolds, holding the motor and I can't remove those w/o destroying them (at least I think so). Thx Olav
I have a Bosch Max 2460 washer and the brushes are impossible to change in situ - you have to remove the motor - easy if machine on side! But make sure you tip machine with soap tray down to floor - I did not and soaked & damaged circuit control board (not cheap!). Brushes are relatively easy when motor out - I used a pair of long nose pliers and carefully bent lugs holding in old brushes - motor is held in by 2 large self tapping bolts - unclip splash guard & cablle & earth lead - I take a digital picture before I start so I know where all the bits go! Good luck - if I had tipped machine the correct way this repair would have cost me under 20 quid... but with a new board its 120!
Posted on Aug 07, 2007
Thanks a lot, but unfortunately it's the small European model and they use Carbon Brusher (see link: it's part number 16. I knocked on them and now the drum is spinning again. That's a sign that they are almost done. The stupid thing is, that I have to take out the motor to replace them and I can't get this done. Thx! Olav
Posted on Jul 24, 2007
Actually, removing the motor from the smaller European model is quite simple. Remove access panel from the back of the machine. Remove belt from motor. Remove two 10mm bolts securing motor. The round plastic pieces behind the two bolt heads appear to be part of the drum assembly, but they're not -- they're actually attached to the motor. Use a flat screwdriver behind the metal mounting "ears" of the motor (the ones you just removed the bolts from) and gently pry the motor toward you. Pry a little behind one "ear", then the other, until the motor breaks loose. There are two more mounting "ears" on the far end of the motor that slip over pins. Pull the motor toward you to slide it off the pins. The motor should now be loose. Carefully clip the cable tie fastening the wiring harness to the motor and pull out the plug. Also remove the blade connector to ground. The motor should be completely free now.
Posted on Sep 28, 2007
  • Bosch Master
  • 12,061 Answers
I doubt that there are ANY "Brushes" as you know them on most of these machines they use a sorta super "Stepper" motor with many stators and don't use "Brushes" They use Electronic controllers and Motors. Useually one replaces the Motor.. but more often than not, it's not the Motor, it usually is the Controller or the like... even a sensor? Switch?.. but no brushes.. I maybe wrong as I am NOT completely familiar with the exact model. But a lot of the "Other" ones are that way.
if you have system or go to cafe and sign in to change your password through the option, forgotten password and answer the Question ask from you then change the password enirely from the former one
Jul 12, 2014 | Google Gmail
Can you install class-A cotton foil-backed insulation in a furnace heat exchanger duct
HVAC Insulation Cotton thermo acoustic duct wrap reduces noise and increases HVAC...
None of these products are used INSIDE the heat exchanger. If the problem is a cracked heat exchanger, you may be able tp purchase replacement parts to repair it
How to Fix Cracked Furnace Heat Exchanger DoItYourself com
The heat exchanger must be free of cracks and holes due to the potential of carbon monoxide leakage. You can probably make a short term repair with sheet metal and high heat furnace refractory cement, but that is a quick fix only.
Please be aware of the potential for a lethal situation due to carbon monoxide poisoning.
May 26, 2014 | Cozy (W352E) Heater
Model 417.29042992 pumps out water but wont spin
it could be your motor brushers the only way to check is remove the motor and you will see two plasic holders on each side of the motor armature undue the 2 screws and the brushers will come out they should be 1.5 inches long and shinny on the ends also sometimes they can get stuck in they might pull out a bit to get you going if not replace them you can get them on line from euro spares just type in your make model and motor brushers if i can help more let me know
Nov 10, 2011 | Kenmore Front Load Washer
Gas backup wont light. repairman said need new heat exchanger. approx 60 days ago replaced all burners and it woked ok they got it running for 1 night now it is out again. if the xchanger is bad why did...
I would only assume that now you have taken out an over heating sensor. When a heat exchanger goes bad it is a very dangerous situation because now you are pumping carbon monoxide in your house along with your heat. A heat exchanger is a baffle that hot gases pass thru, heating up the exchanger along the way and expelling carbon monoxide out the exhaust/chimney. Bad exchangers crack along seams or burn holes thru allowing the exhaust to mix with the blower air and in time this could cause carbon monoxide build up in your house. This cracking also lets hot exhaust in to the furnace and can burn up over heat protection, wiring and possibly cause a house fire. Please change out the heat exchanger or entire furnace, there is no price to replace a human life.
Dec 20, 2010 | Heating & Cooling
We have yellow flame is that a problem
haven't had much to do with this type of heater but a yello9w falme is usually reducing the oxygen from the gas by the the air mixer on some flame effect fires they cover air holes on burner to get the flames yellow the only problem is they can carbon up from this in a heater you don't look into flames this may be ok but i would check the burner air mixture hole if has one but that smost likely the reason for yellow flame not blue so its probably no problem carbon in heat exchanger will make heat transfer a bit slower so probably best to try and fix
Nov 20, 2010 | Sterling RF45 Propane Gas Heater (45,000...
How do i fit new carbon brushers to dyson dc14
It will be a pointless exercise Ron. By the time the brushes on a YDK DC14 motor have gone, so has the armature. You need to replace the motor. You can get a new motor here: Dyson DC14 new motor.
Also, be sure you change the filters; one of which is washable.
Nov 12, 2010 | Dyson DC14 All floors Bagless Upright...
I have a bosch clasixx 1400 washing machine and it is not spinning but is going through all the programmes and i have also changeed the carbon brushers, what is wrong?
Make sure the filter is clean, this is located at the bottom front right of washer, unscrew anti-clockwise to remove and clean.
Mar 09, 2010 | Washing Machines
Fixing the springs to the carbon brushers to a 24v battery bosch drill
The brushes come as an assembly with the spring and brush in one unit. If your springs are bad you can order a set of brushes. The part number is 2607034901 and they run around $6.50. If your springs are melted looking there may be an underlying problem with the motor, mainly that there is a short in the motor or even switch. If the brushes are just worn and not touching the commutator bars then it is safe to just replace the brush set and you should be ok. Any questions please post back.
Oct 12, 2009 | Bosch 13624 24V Cordless Hammer Drills
Bosch Axxis+ WFR 2460 Front Load Washer Logo
155 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
