Question about Garden
Jonsered 2040 fuel line replacement
Need to replace fuel line from tank to carb.
  • 97 Answers
SOURCE: fuel line routing help.
You should have one line (with filter) going to the carb inlet & one line going to the bulb then back to the tank.
Posted on Mar 17, 2009
  • 4 Answers
SOURCE: Mcculloch 3216 starts few seconds and dies, choke must be closed.
after jerkin fingers bloody today same problem i took carb apart,,the old hoses deteorated an clogged screen on in take side/// inside of carb plate //of carb,,blew out with choke cleaner,, reassembled now runs well make sure to run same size hoses large an small,,as original other wise floods out,,,
Posted on Mar 21, 2009
#1 Taper
  • 1040 Answers
SOURCE: replacing fuel lines on ryobi 767r trimmer
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Posted on Jul 03, 2009
  • 75 Answers
SOURCE: How to replace fuel lines on Jonsered trimmer model GT 21L
if it's electric, it shouldn't have a carby. Fuel lines are quite simple to replace. try your dealer or someone who does mowers and chainsaws.
Posted on Oct 02, 2009
dontbother10
  • 2220 Answers
SOURCE: Replacing 16
The second carburetor port feeds the primer (bleeder), returns excess fuel to tank.
Filtered line to carb, carb to bleeder, bleeder to tank (probably not visible and no hose in tank).
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
You can find an exploded parts list wit a little detail here:
http://www.searspartsdirect.com/partsdirect/index.action?psid=74199074&sid=PSx20071217x00001a&OVMTC=Exact&site=&creative=3873724584&OVKEY=searspartsdirect%20com
The print is deceptive, it appears the filtered line feed the bleeder it does not!
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Posted on Apr 18, 2010
I have a Jonsered 535 and recently replaced a ring and cleaned it up. I went to put it back together and can't remember where the gas line on the walbro carb goes. The line I'm talking about is the...
This sounds like the hose from the tank breather, the hose goes from the tank on the l/h side to the cylindrical vent, then from the other side of the vent the hose goes around the back of the carb and out through the side of the crankcase with a sintered plug in the edn, there is also a hose from the cylinder base, this is the impulse tube and fits to the top of the pump cover of the carb,
Jun 14, 2011 | Garden
Replaced primer bulb and all fuel lines still getting air in lines. ran pretty good for about 10 minutes now will start with choke but dies in a few seconds. Cannot rev. up. cleaned under both plates but...
The primer bulb pulls fuel from bottom of fuel tank,when bulb is full it will return fuel back into tank,the hose entering bulb runs in the tank to bottom with filter on the end,the return hose stops just as it enters the tank maybe 3/4",make sure the hoses entering tank are tight fit or they will pull air in and leak.the carb may also need rebuild/clean,there is a screen inside of carb that may be stopped up which will need to be replaced.(carb kit).
Feb 18, 2011 | Troy Bilt Tb70ss Gas Trimmer
I HAVE A RYOBI VAC/BLOWER MODEL RGBV3100 THE FUEL LINES NEED REPLACING THEY ROTTED OFF NEED TO KNOW WHICH WAY TO ROUTE FROM PRIMER BUTTON TO CARB
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so
Feb 18, 2011 | Ryobi Garden
I have a Weedeater brand line trimmer model XT 20T. It has a crumbled fuel line. I just want to replace the fuel line. I Googled the Weedeater XT 20T looking for a drawing/instruction, or anything else...
It's not that hard. Fuel line replacement is necessary on these periodically. You have to make sure you get the proper size replacement lines. Small engine repair shops sell the 2 different size "Tygon" fuel lines your unit will need. You might as well replace the fuel filter also. Fuel line sells for about $1.00 / foot or so. The filter is inexpensive also. If you can turn the unit at an angle with the cap off or even upside down, the loose fuel filter line should fall down near the filler neck and you can grab it with long tweezers or needle nosed pliars or what have you. The fuel return line is sometimes held in place in the tank with a small nylon connector, so you will have to push it through the bottom of the tank and then fish it out after removing it from the primer bulb or the carburetor. Here is a synopsis of fuel line routing if you take on the job.
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so.
Jan 29, 2011 | Garden
Replacing fuel lines on ryobi weed eater,need
This is an ongoing issue for users, and rightfully so. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.
If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank.
Jul 10, 2010 | Craftsman Garden
Fuel bulb is not bringing in fuel when pushed
The larger line connects to the primer and returns fuel to tank. The smaller line has the fuel filter connected to it in the tank and connects to the small fitting on the side of carb.
Sounds like your problem is in the carb. You need to look your model up in Sears Parts because some models require replacing the entire carb.
May 01, 2010 | Craftsman 25cc Gas Line Trimmer
Trying to put new fuel lines in all around... bulb has two connections, tank and carb. carb has two connections, I imagine that the tank/filter line goes into the carb, carb then goes out to bulb, bulb...
Fuel routing:
Tank to carb (filter on free end in tank, replace annually)
Carb to primer (primer sucks fuel through carb)
Primer to tank (primer returns excess fuel to tank) HTH
Lou
Oct 11, 2009 | Poulan Garden
Oct 02, 2009 | Ryobi 15" Electric Factory Reconditioned...
My jonsered 2050 will not start and there is a feul line that comes up out of the left side of the carb (from the gas tank) and goes to the right it is broken at the other end and I can't see anything it...
I found an IPL here but it isn't good. Page J shows your fuel system but I'm not certain the hose shown isn't for bar oil.
http://www.jonsered.ws/21452150.pdf
You might try here.
Beg for manuals thread
http://www.arboristsite.com/showthread.php?t=72322
At the top is the [Search this Thread ▼] tab. I did a search for Jonsered 2150 and got 3 hits; 2 for "workshop manuals" If you need to join it is free. They are a collection of chainsaw enthusiasts and will be very helpful. Your saw is considered good; you won't need your flak vest. HTH
Lou
Sep 08, 2009 | Garden
Poulan 2050 chainsaw. Fuel line routing. Replaced all fuel lines. Primer bulb is marked Tank and Carb side. Tank side is for larger line and runs into tank and fuel filter. Carb side is smaller diameter...
Replaced my fuel lines on poulan 2050 today. The large diameter line is a return line from the primer to the tank. The smaller diameter line is the supply line from the tank to the carb. You need to cut this line and run a second piece of small diameter line from the card to the primer. I'm not sure if it makes a difference which of the two stems on the carb is the inlet or outlet line. I used the top stem as the inlet, and connected the bottom stem to the primer. My chainsaw started right up. So I either got lucky or maybe it doesn't matter.
Apr 14, 2009 | Garden
Garden Logo
55 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
