Question about Craftsman 208cc 12" Front Tine Tiller
Sparkplug gap I want to gap a new sparkplug
How to change spark plugs
Those are as easy as they come these days. Mark each spark plug wire with a piece of tape with the cylinder # written on it, so as not to mix up the wires. Remove each spark plug wire by firmly grasping the wire by the boot (do not pull on the wire) and twist it back and forth a few times while pulling slowly. It should pop off without a great deal of effort. If it is seized and it breaks, you will have to replace the wire, or at the very least replace the terminals (if you can get some). Use an air hose and blow around the base of each spark plug to dislodge any loose dirt that could fall into the cylinders (not absolutely necessary, but a good idea). Remove each spark plug with a spark plug socket and extension and ratchet (I forget which size socket, it's either 5/8 or 13/16). Check the gaps of each new spark plug (typically around 0.035 in). re-install each new spark plug by hand (do not cross-thread them) and once you have ensured that the plug is threaded in properly, tighten the plug until it seats, and then tighten an additional 1/16 of a turn. Repeat this for the remaining plugs. Re-install wires to the corresponding spark plugs. You're done!
Jan 10, 2011 | 1983 Ford Crown Victoria
How do I replace spark plugs in a 2002 ford ranger 2.3L
This you do one plug at a time, remove the sparkplug wire from plug next use a plug socket to remove the sparkplug,then make sure to gap the new plugs and install new sparkplugs, its not a hard job just do one at a time so not tom cross any of the wires. hope this helps.
Sep 13, 2010 | Ford Ranger Cars & Trucks
How do i change spark plugs in 1992 buick le sabre
To change the plugs, do one at a time so not to mix up the sparkplug wires, remove plug wire from a plug, use sparkplug socket to remove the sparkplug make sure to gap new plugs, ask parts store for the gap setting they will give it to you when plugs are bought, the plug gapper is about $2.00. and that about it, the rear plugs are a little harder to get to but the same way to remove, some buicks came with metal heat sheild over the sparkplug boot in the rear cylinders make sure to reuse, you will know if you have them they will slide right off old boot.
Aug 20, 2010 | 1992 Buick LeSabre
What is gap clearance for sparkplug on ryobi bc30
to be honest dont bother with it it will be cheaper to buy new but i would stear clear of ryobi
Jun 19, 2010 | Ryobi Garden
I need the Gap settings
the sparkplugs are shipped with the propper gap setting *DO NOT CHANGE IT"
if its been altered, place a penny in the gap, and thats the space it should be gapped.
Mar 04, 2010 | 1994 Mazda MX-3
I have a Puland Pro BVM 200 and I keed to know how to test coil to make sure it is working ok. I can't get it started. I bought a new plug, cleaned the muffler cleaned the carb. Tired of pulling
take a good sparkplug and break off the ground electroid the tail that your supposed to gap, anyway put the sparkplug against the metal part of the cylinder the gap will be about 166 thousand now instead if 30 if it jumps that gap your coil is good
Nov 04, 2009 | Garden
I NEED TO KNOW THE SPARK PLUG GAP AND MAGNITO GAP FOR A POLAN CHAINSAW MODEL # 2375
Spark plug gap is .025
As for the air gap in-between the flywheel, and magneto, I generally start with a piece of notebook paper in-between them.
After the bolts are snugged down, turn the flywheel by hand to spin the paper out.
Oct 29, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I bought new spark plugs for my 01 intrigue. They
the plugs you need are ac delco you can find the replacement proceedure on autozone.com vehicle repair guides
Oct 09, 2009 | 2001 Oldsmobile Intrigue
What is gap on sparkplug on 1978 Yamaha 250 snowmobile?
Hi nana
Leaving the plug set to what it came as is as good as set correctly, unless you have dropped the plug  already:). Attempts to adjust the gap are often done wrong, and potentially damage the plug. Unless you are race prepping the engine/indexing it also, it will be fine straight out of the box. Good likely hood that the old 2stroker will need a new plug long before the gap becomes and issue:) Hope this helps.
regards robotek
Jan 18, 2009 | 1978 Yamaha RD 250
Craftsman 208cc 12" Front Tine Tiller Logo
24 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
