Question about Behringer EUROPOWER EP2500 Amplifier
Behringer pmp2000 europower no sound
Hi every one, i need schematic diagram pmp2000. or you can inform me about line from output mix until power amp. tank's
best regard joe
  • Marek
    Marek Mar 02, 2014
    hi here is schemahttp://ulozto.cz/xMzzohUV/behringer-pmh2...
  • Anonymous Mar 25, 2014
    Behringer power amp europower epx4000 display lites flashes on and off and no output
  • Behringer Master
  • 5,603 Answers
Probably the power amp has arced and popped a lot of components.
When teh amps go usually the final pwer transistors, their drivers and sometimes even the power supply gets zapped.
Check the output of the preamp at the inserts for the final amp with headphones to see if anything is coming through.
Posted on Jun 25, 2010
Need schematics for europower pmp518m
Hello
I've with me the schematics for Behringer Europower PMP-3000 -PMP 1280 & PMH 518. If any one will suit for your set, inform me. OK.
Dec 28, 2011 | Audio Players & Recorders
Hi! I need a SM of my europower pmp 2000
This site for the PMH2000 should be near identicla to your unit:
http://elektrotanya.com/behringer_pmh2000.pdf/download.html
Scroll down to "get manual" and click to download schematic. IGNORE other download links.
The HCA2400 amp module in this has a chronic failure and is hard to work on.
Aug 28, 2011 | Behringer Pmp2000 Europower 800w 10ch...
Behringer Europower PMP2000 Fuse keeps blowing when the amp is switched on.
For goodness sakes do NOT replace the fuse... doing so causes more damage inside. Likely one of the power amps has shorted and may have damaged the power supply as well. Also please read my tip on Fixya regarding a HAZARD with channel A if you use 1/4 inch plugs with the speaker cables. Essentially the sleeve of the channel A plug is the hot, and not the tip. Ground the sleeve of the plug and you can blow the channel A amp. YOU WILL NEED TO TAKE THE UNIT IN FOR REPAIR... THIS IS NOT A DIY REPAIR!!!!
Aug 23, 2011 | Behringer Rx 1202fx 12 Channel Line and...
My europower pmp 2000 powered mixer wont turn on and the fuse appears good. I turned it on and it immediately turned off ,nothing smells burnt. any ideas on what it could be
This is likely a power supply failure, possibly brought on by a failure of one of the amp channels.
This is probably close to your supply:
http://elektrotanya.com/behringer_sps600_power-supply_sch.pdf/download.html
Scroll down to "get manual" and click on that to download schematic. Ignore other download links.
Aug 05, 2011 | Behringer Pmp2000 Europower 800w 10ch...
I need a service manual with a circuit diagramme to repair one of these with an input circuit fault.
GO ONLINE AND CHECK BEHRINGER EUROPOWER EXP3000 STEREO POWER AMP. YOU MAY GET SOME HELP THERE.
Mar 23, 2011 | Behringer EUROPOWER EPX3000 Stereo Power...
Hi I have a behringer europower pmp2000 I've just got the back panel back from the shop after having a new fuse and holder fitted. The trouble is I've lost my wiring diagram to re-attach the back panel,...
If those green wires have eye connectors on their ends, that indicates chassis grounds and should be put under one of the mounting screws on the board. you should be able to get a diagram from Behringer's website.
https://grounenimex.files.wordpress.com/2015/11/behringer-pmp2000-schematic-diagram.pdf
Jun 27, 2017 | Audio Players & Recorders
We are having problems with a Behringer PMP5000 board. We have the switch setting on Mon1/Mono. We can get sound out of the monitor output, but the mono output is almost silent. Do you have suggestions...
It is NOT clear what configuration you have set up and what you consider the MONO output is, whether it is the power amp MONO side output or the line level MONO 1/4 inch jack on the top of the unit (this jack is NOT speaker output). If you can run normal stereo speakers using both sides of the power amp in the AB mode, the problems you are having is pilot error.
REMEMBER the main out 1/4 inch jacks are BALANCED TRS jacks... DO NOT put mono plugs into these.
A WARNING: If you use Speakon to 1/4 inch speaker cables, remember that the BARREL of side A is HOT, not the tip!!! You can fry the amp if you inadvertently ground that barrel someplace. (Side B has the barrel grounded) This information is NOT readily available in the manual and results in many a blown amp. They do this to implement the "Bridged" mode easily.
I have schematics and can unravel most any problem you are having.
Aug 20, 2010 | Behringer Europower Pmp5000 Powered Mixer...
Behringer EUROPOWER EP2500 Amplifier Logo
1,874 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
