Question about Panasonic Panafax UF-585 Plain Paper Laser Fax
Info Code 54
The incoming fax will not print out. We have not been able to get a clear print for some time. I beleive there is a problem with the feed mechanism. Previously I have been able to get feed by disconnecting the machina and plugging it back in again. Is therre anything else I can do?
  • 2,120 Answers
Code 54 is a BAD LASER UNIT
try this:
Open the toner door
press function
monitor key slowly 4 times
scroll down to SHIPMENT SET
wait for reboot
Posted on Feb 03, 2009
This means that your fax is only storing into its internal memory and not printing all incoming faxes, therefore it has no more space for more incoming documents, you should print the documents and maybe you'll need to clear the memory, depending on fax machine, this is done automatically when the documents are printed, and of course, set the incoming faxes to print not to store, this feature is supposed to be used only when the fax has no paper to print.
Mar 15, 2011 | Computers & Internet
Auto print off
Under service mode MENU and # select clear, and all.
After thath fax is returned on factory sett. Reenter your set. and fax will work.
Jun 09, 2010 | Canon FAX-JX200
Ran out of toner a week ago...stopped printing....did my print jobs and/or faxes go somewhere to retrieve later when toner replaced?
Your print jobs may still be in the spooler of the printer. Check the computer (Windows 7, Start > Devices and Printers. Windows XP, the title was Printers (IIRC)). The incoming faxes will be stored in memory; it can store up to 320 pages. (If you have other faxes in memory, the number of incoming faxes that can be stored will be less. Clear the memory after replacing the toner and printing the stored jobs. Press Menu until you see Maintenance then the left and right arrow to select the item to clear. Then press Enter to clear that area. When done, press Clear/Stop.)
I hope this helps.
May 17, 2010 | Ricoh AC205 All-In-One Laser Printer
HP laserjet 1020 fax incoming fax, machine
hp laserjet is not a fax.It is only a printer.
Dec 09, 2009 | HP LaserJet 1020 Printer
My plain paper will not feed to print incoming fax????
If it is a WCP 580. clean the feed tire very well with something like formula 4009 then rinse it with alcohol.
Most likely that feed roller is cracked and worn. Will need replaced.
Jul 01, 2009 | Xerox WorkCentre Pro 580 Plain Paper Laser...
The copy/receiving function will not work.
hi,clean feed roll if the feed roll out of use please replace it.
May 14, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Won't print an incoming fax; displays error message 004
I think the error is point to a fuser (temp issue) problem.
You can check out this thread for some more info that might be helpful. - LINK
Nov 11, 2008 | Canon LaserCLASS Fax 710 Printer
Need to clear the memory of Brother MFC-8220 fax
The easy way to reset the machine is to power it off for a period of time. Say overnight will allow the battery back up on the board to run out and the machine to loose its memory.
Feb 18, 2008 | Brother MFC-8220 Fax
Panasonic Panafax UF-585 Plain Paper Laser Fax Logo
79 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
