Need installation manual for a trane xe80 furnace
5 Suggested Answers
KLR Monkey
  • 22 Answers
SOURCE: what is the efficiency rating on the Trane model
Chances are you need to replace both the condenser and furnace, then you you should get a varaible speed blower with the new furnace, get at least a 90% gas system with a 16 SEER condenser, save on energy cost as soon as it's installed. Go Get IT
Posted on Feb 01, 2010
  • 23 Answers
SOURCE: where is the filter on
It might have higher end filter on in installed at the furnace or check inside of the furnace it should have a filter clip factory add.
Posted on Oct 02, 2010
heatman101
  • 43501 Answers
SOURCE: I am looking for electrical
The electrical schematic will be on the inside of the lower door...
Check also that the board has not been changed...
Also some of the newer furnaces do use a 120v ignitor and maybe you are being given the wrong one...check the full model and serial numbers to figure which ignitor you need...
I thnik you have a 120v board in there...there is really no way a 24v board can give you 100v...that means you should be getting a new style nitride ignitor that is 120v...
heatman101
Posted on Apr 14, 2011
  • 69 Answers
SOURCE: wiring schatic to wire a 10 kw heat strip inside of a trane gas furnace
If you are using strip heat as seperate mode you must install a fan isolation relay which would be energized by emergency ht mode of stat.
Posted on Nov 25, 2012
My Xenon high efficiency furnace has a red blinking led light that blinks 4 times and my furnace will not light. What could be the problem?
Gas furnace fault or error codes for common furnaces - Gray ...
www.grayfurnaceman.com/-ifc-failure-codes.html
Each color will also flash a specific number of times to signify a specific error. ... 4 redcolored flashes may be signaling that the "high-limit" switch might be open. ... 3 green colored flashes on your furnace has the same meaning as 2 green colored flashes. ....If a system problem occurs, a blinking LED shows a fault code.Missing: xenon
7 Tips and Tricks to repair your Furnace DIY - YouTube
? 13:25
https://www.youtube.com/watch?v=rAtcvPqUsBA
Dec 18, 2012 - Uploaded by JRESHOW .
Flash sequence codes 1 through 11 are as follows: LED will turn "on" ... 4 RED FLASHES: This indicates that the main limit switchhas opened ... This no-light condition occurred 3 times (2 retries) during .... My furnace trane xe80 is only flashing once my manual says something about flame being locked out ...Missing: xenon ‎efficiency
Nov 21, 2015 | Heating & Cooling
Trane furnace problems
where? for what? please explain. furnaces tipically have a restrictor where the inducer blower mounts on the furnace.
Apr 05, 2014 | Heating & Cooling
Cracked Selkirk METALBESTOS gas vent pipe on 80% efficiency furnace (Trane XE80)
I would check with a local furnace company that installs Tranes and ask if they sell to the public, if so buy it.
Oct 12, 2012 | Selkirk METALBESTOS 104082 ROUND GAS VENT...
I am looking for electrical schematics for the Trane XE80 furnace. I think the ignitor is getting too much voltage such that it is failing too soon. I measured 100 VAC on the 24 VAC ignitor.
heatman101
Apr 14, 2011 | Heating & Cooling
Need to replace bearing for blower in trane xe80. where can i find a parts list & purchase this part
I would try a local furnace distributor and installer. Some times the installers can be a wealth of information. If in the Warrren/Youngstown Ohio area I would see Pete Torok at Torok Heating Supply, or McCruddens on Indianola. A good furnace supply place that handles Trane products. If you wish to call and order parts here is the phone number to a very good person to ask is Torok supply at (330)-799-6677 he is a good honest man and runs a great business here in Youngstown.the other is McCruddens at (330)-744-4108 these two are the problem solvers and then some. I am sure that they will be happy to help you out and possibly refer you to some one in your area.
Dec 21, 2010 | Heating & Cooling
Where is the filter on an xe80 trane res. hvac system is not in return in house.
Oct 02, 2010 | Heating & Cooling
My trane XE80 will only blow cold air. The fan
It sounds like the problem is a tripped limit switch. Look in the burner compartment and on the blower assembly for a switch that looks like the one below. It will be about the same size round as a quarter. Press the red button on any of the switches you find, then re-try furnace.
Mar 23, 2010 | Heating & Cooling
What is the efficiency rating on the Trane model BLU055E936B1 upflow furnace and what new furnaces are available to replace this old Trane furnace without having to change the venting system.
Jan 28, 2010 | Ruud Central System Air Conditioner
Hooking up a used 550 to a new 80% trane UD-R9V,
In this situatioin you'll eed a second transformer 110volt to 24 volt to relay from w to common to operate only when furnace being called for.
Feb 07, 2009 | Aprilaire 550 Humidifier
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
