Question about Fagor 31 in. VFA-78S Electric Cooktop
Fagor hob touch control
The touch control on our fagor hob will only work if we put something like a teatowel or kitchen towel between our finger and the hob. The hob is clean and grease free.
  • Anonymous Mar 20, 2014
    e-nr pke691q025
    type hmvt462
    with my touch screen bosch hob i have to press very hard for it to work what is the solution
Our hob has the same problem. I would really like to know the reason for this! Try using a rubber eraser instead of your finger - this works every time with our hob. Covering Up and Down arrows with the rubber, zeros it instantly just like using both fingers. Hope this helps.
Posted on Sep 16, 2009
I cannot unlock my fagor induction hob by pressing the plus and minus signs, what should I do?
check the keylock is not activated by holding down the key symbol for a period of 5 secs.
Nov 08, 2016 | Fagor Cooktops
Hob light up.
I take it the two fuses you mention were the house fusebox and the fuse in the outlet in your kitchen? If you know the mains is getting to the hob and nothing at all is lighting up on the panel then this sounds like a job for the professionals. I can't find any mention of a reset button or user acessable fuse in the manual. The only thing left to do is check the main wire connection underneath the hob - if it is accessable. (switch off at the wall first!) Assuming you are in the UK Service force telephone number is 08705 929 929 Hope this helps.
Sep 29, 2007 | AEG 23 in. 67600KF-N Electric Cooktop
What does F flashing mean on miele nduction hob
F means foreign object. In my case a dish towel covered about 10% of the touch panel, so it is really sensitive. In your case just see if anything is on top, or it may be that your stove is tricked into believing the front panel can't be used because something is covering it.
Dec 22, 2012 | Cooktops
One of the rings comes on when the hob is even turned off any idea why this is???
This would normally mean that the hotplate controller if faulty. It is not a common occurrence but it does happen.
Feb 10, 2011 | Fagor 31 in. VFA-78S Electric Cooktop
TOUCH CONTROL HOB (SCHOTT CERAM) GLASS CRACKED
Hi. Yes you can buy a new glass. Most of the come with frame top now. If you get me the model # I can look this up for you and get you an idea on cost.
Vic
May 18, 2009 | Cooktops
ZKT 623 LBV digital hob
hi gud day,all hob is almost the same to use,if touch control ur unit,put ur tumb wer the place sign of child lock & off sign..tnx
Jan 29, 2009 | Cooktops
Cant switch on hob
gud day,the ceramic hob is very sensitive to operate if u not read the manual.after u unlock the switch go to the control of the hob wat area u want to operate by touching the sensor then if u see the zero # touch again the area,positive side to increase the heat 1-9 the standard control heat.some model & brand have a different operational procedure,try to read the manual 1st or check the voltage of the unit coz the ceramic have a 4voltage standard for different country. tnx gerbee
Jan 26, 2009 | Neff 23 in. T1443 Electric Cooktop
Neff 4 ring, ceremic top hob - how do I turn on!!
You press the "on" which is on the left. Press the picture of hob you require and press the up and down for temperature. Then put your pan on the hob and it will work. If you need to adjust the temp you need to remove the pan.
Oct 15, 2007 | Neff 23 in. T1443 Electric Cooktop
Fagor 31 in. VFA-78S Electric Cooktop Logo
1,024 people viewed this question
Top Fagor Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Fagor Cooktop Expert? Answer questions, earn points and help others
