Question about GE Ovens
WB27T10277 GE Electronic Control came with no wiring instructions
WB27T10277 GE part substitution came with no instructions on how to wire correctly. Most match up but there are some that don't. Are there wiring instructions for this replacement part?
Powerman
  • 68 Answers
SOURCE: Kenmore oven clock control installation instructions
Your prpblem is not the control, it is a short circuit in the ribbon cable between the keypad and control. You can find my fix at:
http://fp1.centurytel.net/Powerman/Dreaded%20F7%20Problem.pdf
I have now shared this with over 1400 folks and most report success.
Please let me know if this works for you. Email me at:
hutchipop@yahoo.com
Posted on Nov 22, 2007
SOURCE: I need the squematic wiring GE 24" Built-In Gas Oven
I have the same problem -- did you ever get this question answered?
Posted on Jun 14, 2010
emissionwiz
  • 78267 Answers
SOURCE: GE part number WB27K5272 changed to WB27T10277.
we have no way to reference part numbers, suggest if new part is different they sent the wrong part, call the company that sold u the part and find out what is going on, in the tech trade if it doesn't fit most times it is the incorrect part. You can also try using live chat with this company
http://www.repairclinic.com/GE-Parts
look at the top of the web page and u will see the "Live Chat Now" click it and give the part numbers.
Posted on Oct 20, 2010
KevinWhite
  • 1902 Answers
SOURCE: I have a GE oven.
Hello & Welcome to FixYa
This indicates a problem with the door lock switch mechanism that needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on Sep 06, 2011
  • 5370 Answers
SOURCE: new replacement part WB27T10272 for
The instructions as follows the GROUND not used. The Neutral located in near the same position. The L1B goes to the little black box near the vacant L1B location on the board.------ There is an L1B stamped on lower right corner of purple housing just below numbers 04400.
On the instruction sheet it tells you to plug in the wire L1A but it is supposed to be L1B. L1A is marked on the board where it is supposed to go.
-------- Click this link below for more details:--- http://whatisbyme.blogspot.com/2011/09/l1b-wire-to-new-control-board-on-ge.html ---------- This will help.Thanks.Helpmech.
Posted on Sep 21, 2011
What does the F-9 code for a Ge oven mean
An F9 error code on a General Electric (GE) oven indicates that the oven's electronic control system has detected a problem with the automatic door lock. The automatic door lock mechanism prevents the oven door from being opened when the oven is set for "Clean" mode. The malfunction may be a jammed door lock mechanism, a pinched or broken wire, a faulty lock switch or a fault in the control board itself.
Jun 17, 2011 | GE Ovens
I have a kitchen add KGSS907 it is showing an error message F6E0 lost communications how do I correct this
F6 E0 means the switch pulse return line to the electronic control is not connected
The usual way to correct this is to replace the electronic control (clock).
You might want to check for loose or burnt out wires on the clock unit before replacing tho'.
Dec 17, 2010 | KitchenAid Architect Series KEBC107KSS...
Need wiring diagram for part number WB27T10276 for ge oven model JRS04BW3BB
For anyone installing a replacement oven controller #WB27T10276, there is a GE publication # 31-10515 that should answer your questions. I bought a rebuilt control that did not have this info. with it. Lucky for me, a retail appliance parts store opened a box with a new control in it and copied the instructions for me.
Aug 14, 2010 | GE 24" Built-in Single Electric Wall Oven...
I have just installed a new electronic control in my JTP45 Electric double oven. (part WB27K5273). I have a schematic, but so far have not figured out why that when I open the door the unit turns off and...
It does sound like a wiring mistake. Check all the connections and the wire colors against the colors on the Tech Sheet wiring diagram (which is normally taped on inside the control panel). Particularly look closely at how the door switch and lock connector is plugged in. You may have reversed the plug.
Best Regards,
Bruce
www.fixyourboard.com
Jun 18, 2010 | GE JTP45 Electric Double Oven
PURCHASED NEW GE WB27T10327 OVEN CONTROL TORISAN ERCB3 DID NOT HAVE INSTRUCTIONS FOR A NON SELF CLEANING OVEN. CAN YOU HELP? JERRY
Hi.
I do not have wiring diagram for this ERC. They had never been made available online by GE.
Here GE contact contact 1-800-626-2005.
All I can give you is the oven diagram below:
Nov 06, 2009 | GE 24" Built-In Single Gas Wall Oven
Oven temp does not remain constant. changes + /- 50 degrees.
Sounds like either an intermittent temperature sensor or its wiring, OR a problem with the electronic control.
We repair a lot of controllers with this sort of symptom.
Best Regards,
Bruce
Oct 14, 2009 | GE 24" Built-In Single Gas Wall Oven
Flashing F2 warning
GE
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 and F1 Failed Thermistor Control Replace Electronic Range Control (ERC) F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F3 Open oven temperature sensor circuit Replace oven temperature sensor F4 Shorted wire (Oven temperature sensor) Locate and correct F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC) F8 Component Failure Replace Electronic Range Control (ERC) F9 Program w/ door circuit Check wiring
Aug 18, 2009 | Ovens
Error code F7
your problem is with the EOC (Electronic oven control) or touch pad if it is seperate from the control...if the touch pad is seperate...unplug range - access the control panel - remove the wiring/tape wire from touchpad to EOC...plug range back in...leave over night...if f7 code comes back it's the EOC...if the error code clears it's the touchpad...replace the part with the problem...if touchpad built into EOC replace the EOC. Hope this helps...if you have any other questions please feel free to comment again.
Jul 06, 2009 | GE Ovens
Digital screen goes off oven will not work stove top is working fine
The "digital screen" is connected to the electronic control board which controls the oven (the surface elements on the stove top will not be affected by this problem). The "flickering on and off" could be any connection that feeds the electrical supply of the control board. Like something in the wiring harness that feeds the relay board, or the wiring harness that goes from the relay board to the electronic control board. It could also be the relay board or the electronic control board themselves. To isolate the problem you would need to check electrical supply to each board at the time of the "problem" when the "digital screen goes completely off." This would tell you where you "have" the voltage and where the voltage supply is lost. If it is a loose or burned wiring harness replace the harness or individual wire causing the problem if it turns out that it is the relay control board or electronic control board replace them. The relay control boards are typically around $75.00 and the electronic control board $150.00 and up. Might be cheaper to purchase another used oven or bite the bullet and buy a new range.
Nov 29, 2007 | GE Profile JTP18 Electric Single Oven
F3 Fault
Either your new temp probe failed or there is a wiring problem between the probe and the electronic relay control.
Jul 29, 2007 | GE JKP28 Electric Double Oven
Ovens Logo
64 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
