Question about Whirlpool RMC305PD Microwave Oven
No display - Whirlpool RMC305PD Microwave Oven
  • patrickj_mar
    patrickj_mar Jan 24, 2013
    The oven wont work but the microwave works there is no display
  • Whirlpool Master
  • 17,129 Answers
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean, solder and reset the board. Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron. Check this link to know how a microwave works:
http://www.espares.co.uk/advice/microwave/a/5/1443/how-a-microwave-oven-works.html
Posted on Jan 25, 2013
Display is blank
If the display is blank, and the oven works, 9 times out of 10 it is a problem with the circuit board that drives the display.
Apr 16, 2014 | GE Advantium 120 Convection/Microwave Oven
WMG30GS Whirlpool microwave display
please follow this steps and fix it. God bless you
  1. Main control board If the display on your microwave has gone out completely this is usually a sign that it is a malfunctioned main control board. To correct the issue the main control board would need to be replaced.
  2. Display board A display board can either malfunction completely or partially, causing two separate results. If the display on the unit has completely gone out, this can be attributed to either a bad main control board or display board. On the other hand, if the display has only partially gone out, this is usually a sign that the display board is defective and will need to be replaced
Nov 27, 2013 | Microwave Ovens
Dim display
The display may be available but can be very tricky to replace----the issue could also be the voltage source to the display is down or low and the display itself is ok.
Lastly I have seen two units where there was in the menu a setting for how bright the display is.......
To try to locate the part Google the model number with "parts" or "display" etc.
Dec 04, 2012 | Microwave Ovens
The control display on my microwave is very dim. Is there any way to make it brighter?
If you had mentioned your full model number, we could have looked whether the VFD is available as a separate part in case your model has a VFD display, or whether the whole control board would have to be replaced.
If your model has an LCD type display, it may be weak LEDs or other failing components in the display backlight circuit.
We regularly repair microwave displays for $39.95 nationwide.
It's pretty rare for a microwave to have a display brightness feature.
Let us know if we can help you further.
Nov 16, 2012 | Whirlpool MH2155XP Microwave Oven
Digital display of Bauknecht MCG 1731 micro-wave isn't readable in daylight.
If the microwave is workingg fine otherwise , then you can remove the display panel and see if there is dirt or insects that have clogged the display. Use a hair dryer to slighly warm the panel , check the voltage to the display panel from the main board and processor. If there is no issues here then it is possible that the display is weak and needs a replacement
Jul 11, 2011 | Microwave Ovens
No Touch Screen Display
Try pressing "Clock" and then "Start"
Mar 16, 2009 | KitchenAid KHHS179L Convection/Microwave...
Display not lit up
Seems like the display panel went bad. You can check for sure by unplagging the unit for 45 seconds and plugging it back in. If still no display order a new display panel.
Please rate if you are satisfied
Feb 12, 2009 | Microwave Ovens
LCD display missing part of numerals
Yes, we repair these displays for $32.50 with a one-year guarantee. Repair Clinic charges $169.35 for the display board assembly. Tritronics (our supplier) sells the assembly with display (part # DPWBFC167WRKZ) for $107.07. On the rare occasions when we actually replace that type of board for our customer (at our cost of only $73.33) we also perform our proprietary fixes on it. We do that so the new display does not also fail in a few months, or even right out of the box! That actually happens!
Oct 18, 2006 | Sharp R-530ES Microwave Oven
Digital display lighting
The solution depends first on the type of display your microwave has. Please refer to the picture. The left side shows a partially defective LCD type display. If you have this type of display, we regularly repair them for $32.50 nationwide. The right side is a VFD type display which is weak due to age. On some brands and models, we are able to get a replacement display tube and repair it to a like-new brightness. Feel free to e-mail me at _ if you have other questions.
Sep 17, 2006 | Frigidaire FMT144G1 Microwave Oven
Microwave Ovens Logo
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
