Question about Sewing Machines
Brother charger 661 knob will not loosen to thread bobbin
Where can i see photos or manual for this vintage machine? would like to see illistrations
  • linda garcia Jan 29, 2013
    It is the stop motion knob that will not loosen to re-thread bobbins
    on my brother charger 661 sewing machine
SOURCE: Brother XL-5130 Sewing Machine
Put the thread through one of the holes. Then put the bobbin on the spindle. Pull about 3 or 4 inches out of the hole and hold on to it. Start winding the bobbin. After about ten turns, or when the winding thread is secure, you can stop the machine and cut off this 3 or 4 inch tail. To insure that the thread winds up and down the bobbin and not off the top or bottom, there is probably a metal bobbin tension disk that the thread must pass around before it goes to the bobbin. It is probably on the left of the machine and may or may not be part of a thread guide. The thread must pass around this disk on its way to the bobbin in order to put tension on the thread so it will wind properly. If you can't find the disk, which is a small metal button or screw with some type of somewhat moveable spring cap, you can just get the thread to pass through your thumb and forefinger. Hold your hand 6 or 8 inches to the left of the bobbin and pass the thread between your thumb and forefinger so that it makes the thread go in a direct straight line to the bobbin. Pinch the thread only enough to keep it taught but not tight and let it flow through your finger to the bobbin. The thread should go up and down evenly on the bobbin. If not, move your hand up or down to position it so the thread will wind up and down smoothly. It will not be necessary to move your hand once you find the correct position needed for winding.
Posted on Jul 20, 2007
SOURCE: bobbin tangles up thread and jams machine
Hi, Is it your bobbin thread or the top thread wrapping around the bobbin. I just got a used PE150. The top thread keeps wrapping around the bobbin. It is not picking up the bobbin thread. Did you find a solution for your problem?
katfou
Posted on Feb 08, 2008
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
SOURCE: Elna Primula 410 Bobbin Winding Question
Wind the Bobbin
For the usual jobs, it is the best to use a medium sized thread.
2. Disengage the flywheel by unscrewing the coupling knob as far as it will go.
3. Place the bobbin on the bobbin winder, and push the bobbin winder to the right.
4. Pull out one of the spool pins and place the spool of thread on it.
5. Pass the thread through the bobbin winder tension discs, as indicated.
6. Wind the end of the thread around the bobbin by hand, in the direction indicated.
7. Wind the bobbin, at a medium speed by pressing lightly with a finger on the spool so as to stretch the thread better and thus fill the bobbin to a maximum. The full bobbin stops automatically.
8. Re-engage the flywheel by tightening the coupling knob.
9. Cut the thread and remove the bobbin from the bobbin winder by pushing the latter to the left.
Posted on Aug 23, 2008
bilabon
  • 46 Answers
SOURCE: Threading the Bobbin
Place the bobbin in the bobbin case making sure the thread feeds clockwise. Draw the thread through the slot on the case. Continue to draw under the tension spring and through the opening pulling out about 6" of thread. Hold the latch open, position the bobbin case into the suttle and release the latch. THe case should lock into place when the latch is relaeased.
With the top thread, hold out about 5" to the left. While holding on tot he top thread, turn the hand wheel toward you and you should see a loop at the feed dogs. grab the two thread and bring them behind the presser foot.
Bonnie
Posted on Sep 02, 2008
Brother 661 charger keeps breaking the thread on the needle when it goes down in the machine
Install a new needle. Remove the thread from the upper threader. RAISE the presser foot and rethread from the beginning. Verify the thread path is correct. Set the tension to the midway point.
Jan 19, 2017 | Brother Sewing Machines
How to thread model 661 sewing machine
From the photo, it appears that you may have the thread path correct, but it does appear that the thread is not seated in the tension disk (the round knob that the thread goes around before going up to the take-up lever). There is a spring in the tension disk that needs to be activated. FIRST, be sure when you thread the upper thread, ALWAYS RAISE the presser foot. These releases the tension disk and allows the thread to seat. Also, when going around the tension knob, hold the thread above where it goes around the knob and make a complete circle around the tension disk and tug. This should seat it in the spring.
Brother 651 Charger Sewing Machine Threading Diagram
A manual would be most helpful, not only in how to use your machine but also how to maintain (clean & oil) it.
If you don't have a manual, search the internet for:
Make + Model + the word "Manual"
Oct 26, 2016 | Sewing Machines
How to thread bobbin 451 Pfaff
Having difficulty even locating a photo of the 451. Assuming this is an older model, perhaps this manual will help. It says its also for the 551, so perhaps the model is close enough that it will help you with your machine:
Pfaff 551 Manual pages 1 viewing
If you are unable to figure out the bobbin winder, you may be able to use a standalone bobbin winder (one brand is called Sidewinder) from the fabric store. They run ~$25-30. Just be sure to bring a bobbin with you to check the fit.
vintage sewing machine bobbin winding Google Search
How to Wind Bobbin and Thread Bobbin Case for Vintage Singer Featherweight...
Jul 14, 2016 | PfaFF Sewing Machines
Where can I get a manual?
Can't see make and model, but that styling looks 1970s.
Google
make, model manual.
many, but not all are available online, some for a small fee.
Mar 20, 2016 | Sewing Machines
How do you load the thread on the bobbin?
On the back of the machine, by the hand knob, there is a post that moves back and forth, place your bobbin on this, and slide it to the hand knob, unscrew the end to loosen the mechanism, then place thread onto the bobbin, holding one end. With the lock loosened, depress the pedal, and holding the thread, it should spool onto the bobbin. I hope I didn't confuse you too much, but that's pretty much the answer. Just be sure to rescrew the lock onto the hand control knob on the rear of the machine.
Joe
Sep 13, 2011 | Singer Sewing Machines
Sewing Machines Logo
76 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
