Question about Texas Instruments TI-Nspire Graphic Calculator
A battery corroded in my TI-Nspire calculator. What do I use to clean off the corrosion residue?
  • 21 Answers
SOURCE: TI-84 Plus Calculator will not turn on, says ram is cleared
Thats because the OS is corrupt. Follow the manual and reload the OS, try the 2.43 OS
Posted on Mar 02, 2009
  • 49 Answers
SOURCE: My TI 84 will not turn on. All batteries have been
try adjusting the contrast up using 2nd + up
just keep pressing it and it should turn back
Posted on Jul 28, 2009
SOURCE: My TI-89 Calculator will not turn on.
The damage was battery corrosion. If you CAREFULLY take a damp(not dripping wet) rag and wipe the contacts of the corrosion you may have luck. The batteries just leaked, Very common especially for cheap "Heavy Duty" batteries. Alkalines seem to hold up better in a discharged condition. I hope this helps.Do wash your hands after the cleaning. A q-tip may also be of help. Just wet it and squeeze most of the water from it.
Posted on Aug 26, 2009
  • 7993 Answers
SOURCE: My TI-nspire CAS doesn't want to go on! I changed
Try the other recipes from the TI knowledge base concerning a calculator failing to turn on
For the TI-Nspire™ Family:
  1. Remove thekeypad (for TI-Nspire) or the battery door (for TI-Nspire CAS) andremove at least 1 battery from each column of batteries. After 2-5seconds, reinsert the batteries and turn the unit on. This will causethe unit to reboot the operating system.
  2. Remove the keypad(for TI-Nspire) or the battery door (for TI-Nspire CAS) and remove atleast 1 battery from each column of batteries. After 2-5 seconds,reinsert the batteries and LEAVE THE UNIT OFF (do not turn on and thenback off). Hold down [Home] [Enter] [P], and while holdingthese keys, press [On]. The device will boot up as in the previousreset, but will display a menu with the following options. Please tryoptions 1, 2, 3, and 4 in that order. ** The [Home] key is located atthe top right of the TI-Nspire keypad and has a picture of a house onit.
Note:TI-Nspire family model options 2 and 4 above require that the OS be installed. The reset menu will only display if the unit is off and batteries have been removed/replaced as described above.
1. Cancel - The most non-intrusive reset option; no changes are made, the unit restarts.
2. Delete Operating System – The operating system will be deleted without deleting any documents.
3. Delete Document Folder Contents – This will delete the user’s documents, but will not delete the OS.
4. Complete Format – This will delete the OS and all documents for a total erase of memory.
Hope it helps you solve the problem.
Posted on Oct 18, 2009
  • 7993 Answers
SOURCE: I have a TI-nspire CAS
You should ( a suggestion) reset the OS by pressing the button on the back of the unit.
If that does not work, you may consider reinstalling the OS. The procedure as described in the TI Knowledge Base is as follows.
What steps are required to reinstall the TI-Nspire family operating system?
To reload the device’s OS using a computer with TI-Nspire Computer Link:
• Connect the TI-Nspire device (with the Nspire keypad) to the computer using the USB Standard A to Mini B cable.
• Open the TI-Nspire Computer Link software. The select device dialog should appear, and detect the device.
• Either drag the OS file (available in the ‘downloads’ area at education.ti.com) onto the TI-Nspire File Browser portion of the window, or click Tools -> Install OS.
To reload the device’s OS using another TI-Nspire or TI-Nspire CAS device:
• Connect the two devices using the USB Mini A to Mini B cable. The end marked A should be inserted into the sending unit, while the end marked B should be inserted into the receiving unit.
• On the sending unit, access the document chooser by pressing [Home] [7]. Once in the document chooser, press [Menu] and choose 9:Send OS…
NOTE: Users can only send an OS to a unit of the same model. Users cannot send an OS from a TI-Nspire to a TI-Nspire CAS.
Please see the TI-Nspire guidebooks for additional information.
Hope that helps.
Posted on Oct 28, 2009
Does not power up after corroded batteries are replaced.
Sometimes these is corrosion on the contacts from the corroded batteries. Try cleaning it off with some sandpaper. Make sure to thoroughly wash your hands after or use gloves!
Good luck.
Sep 08, 2015 | Texas Instruments TI-83 Plus Calculator
The calculator writes 8 all over
During operation of the TI-Nspire handheld it may be necessary to reset the device. Circumstances which may require a reset include; keys not responding, device will not turn on or a garbled display. To reset the device:
• Remove the keypad (for TI-Nspire with ClickPad, TI-Nspire with TouchPad, and TI-Nspire CAS with Touchpad) or the battery door (for TI-Nspire CAS with ClickPad) and remove at least one battery from each column of batteries. After 2-5 seconds, reinsert the batteries but do not turn the handheld on.
For the TI-Nspire and TI-Nspire CAS handheld units with ClickPad:
• Hold down [home] [enter] [P].
• While holding these keys press [on].
For the TI-Nspire and TI-Nspire CAS handheld units with TouchPad and the TI-Nspire CX and TI-Nspire CX CAS:
• Hold down [doc] [enter] [EE].
Please Note: For TI-Nspire Family handheld units that contain rechargeable batteries you can alternatively hold the above keys while pressing the [reset] button on the back of the handheld rather than removing the battery for 2-5 seconds.
• The device will boot up as in the previous reset, but will display a menu with the following options. Please try options 2, 3, and 4 in that order.
• 1: Cancel - The most non-intrusive reset option; no changes are made, the unit restarts.
• 2: Delete Operating System - The operating system will be deleted without deleting any documents on the system.
• 3: Delete Document Folder Contents - This will delete the user's documents, but will not delete the OS. Selecting this option is the same as using the RESET hole on the back of the unit.
• 4: Complete Format - This will delete the OS and all documents for a total wipe of the handheld.
Please note that the second and fourth option will require that the OS will need to be reinstalled
Mar 12, 2014 | Texas Instruments TI-Nspire Graphic...
How do you put the batteries in?
  1. Remove the keypad (for TI-Nspire) or the battery door (for TI-Nspire CAS) and remove at least 1 battery from each column of batteries. After 2-5 seconds, reinsert the batteries and turn the unit on. This will cause the unit to reboot the operating system.
  2. Remove the keypad (for TI-Nspire Family or TI-Nspire CAS Touchpad) or the battery door (for TI-Nspire CAS) and remove at least 1 battery from each column of batteries. After 2-5 seconds, reinsert the batteries and LEAVE THE UNIT OFF (do not turn on and then back off). If the TI-Nspire/TI-Nspire CAS is a Clickpad, hold down [Home] [Enter] [P], and while holding these keys, press [On]. If the TI-Nspire/TI-Nspire CAS is a Touchpad, instead hold down [Doc] [Enter] [EE], and while holding these keys, press [On]. The device will boot up as in the previous reset, but will display a menu with the following options. Please try options 1, 2, 3, and 4 in that order. ** The [Home] key is located at the top right of the TI-Nspire keypad and has a picture of a house on it.
Aug 26, 2011 | Texas Instruments TI-83 Plus Calculator
Ti nspire calculator. calculator will not turn on. installed new batteries, calculator only 2 years old with moderate use by daughter for school. ti cares sent me a link on troubleshooting, methods did not...
I have fixed several TI calculators for a school that had loose or corroded battery contacts. Cleaning the contacts and bending them a bit to get a good grip on the batteries got them going. You can try this on yours and see if you have any luck. Also try another set of batteries on the off chance one of the new ones you installed is bad (it does happen, and isn't one of the first things you'd think to check) or use a battery tester. If the batteries are good and the calculator still doesn't work, something inside has failed. Either go for the refurb or (if that specific model isn't required for school) see what similar brands and models are available. There might be something suitable for less than the TI price.
Jun 30, 2011 | Texas Instruments TI-Nspire Graphic...
TI-nspire will not turn on
Yes we changed out the batteries on now the TI-84 will not turn on HELP
Nov 23, 2009 | Texas Instruments TI-Nspire Graphic...
TI-nspire screen doesn't work
Here is what the TI knowledge base says about a calculator failing to turn on
Aug 30, 2009 | Texas Instruments TI-Nspire Graphic...
My TI-89 Calculator will not turn on. I have changed the batteries with no result. The calculator was damaged while it was in the possession of my brother, thus I do not know what is wrong with it. When I...
Aug 26, 2009 | Texas Instruments TI-89 Calculator
My TI-nspire CAS doesn't want to go on! I changed batteries! Tried the contrast buttons! Nothing works
Jun 10, 2009 | Texas Instruments TI-Nspire Graphic...
Here is what the TI knowledge base says about a calculator failing to turn on.
Mar 08, 2009 | Texas Instruments TI-Nspire Graphic...
Texas Instruments TI-Nspire Graphic Calculator Logo
59 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
