2001 Volvo S60 Logo
Posted on Jan 28, 2009
2001 Volvo S60 2.4 won't start
Help! My 2001 Volvo S60 2.4 non-turbo won't start..message will say "Start prevented. Try again" the engine won't even turn... I'll try again then the engine turns but won't start. Need your opinion before i bring it to volvo. Thanks a lot My 03 Volvo S60 2.4 D5 won't start..message will say "Start prevented. Try again" This can be repeated 4 or 5 times then it will start and run perfectly.
  • Anonymous May 11, 2010
    hello,
    Just FYI the 2.4 Volvo engine is equiped with a low oil/oil pressure cut out switch and has been known to fail per the Volvo TSB. If you have just changed your oil or have not changed your oil this could cause this problem. Typicly when an owner changes to synthetic oil or has low and broken down oil. Also a defective oil pressure sending unit may cause this prblem. All are easy fixes. The Synthetic oil problem is commonly cured by adding an oil treatment like Lucas oil. The sending unit can be checked with a DVOM/multi meter. You can also jumper the two wires on the sending unit to see if the car starts right up. If it does you have now located your problem.
    Good luck
  • Anonymous Mar 18, 2014
    did a evap smoke test on a 2001 s60 Volvo non turbo and all the smoke was coming out of a round object with a little round nipple on it at the rear of the car on the right side in front of the back bumper
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 01, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2228
Points
8
Try to start your car with the valet key instead of master should start right up problem is master key.
2answers
My Volvo s60 won't start replaced battery and starter and still won't start battery test fine what can I do I have good power throught out
you will need to try to turn the engine manually to make sure its not frooze. if it turns then you might need to check the starter again.
1helpful
I have a volvo 940 1992 non turbo and sometimes it won't start
you have to check you engine starter (dispositive that is made to turn on your car)
2answers
Abs ligth an breake turn on, the break fluid is Ok level up, the car is VOLVO S40 2002 1.9 Turbo, the car breake ok. what i do?
Very common problem on Volvo , ABS module is bad.
This is not effecting the brake system , meaning you'll still have normal brake operation , but on slippery road Anti Lock System won't work.
That system prevent wheels to be locked up by driver and prevent car going into spin.
1helpful
1989 volvo 740 turbo no start problem car will
Try replacing your fuel pump relay,
1helpful
2001 volvo xc70 engine leaking
check turbo oil return pipe make sure it not clogged up .make oil pipe to turbo not leaking oil.
volvo only to release immobliser
1helpful
2002 Volvo s80 t-6
This is what my code scanner says:
P0234 Engine Overboost Condition
If you have a non-turbo model, then it's probably something else. It may be a bad turbo overboost switch. My S80 is non-turbo but I had an overboost switch go out on my Mercedes and it shut down the turbo but I had the same error message. Good luck!
Top Volvo Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Volvo Expert? Answer questions, earn points and help others
