Question about Baby Gear
Do delta 4470-260 meet federal guidelines - Baby Gear
How do I disable passenger air bag?
Some vehicles have a switch on the dashboard to do this. Other (newer) vehicles use a sensor in the passenger seat. The switch only enables after a certain amount of weight is on the seat. That way it is disabled for smaller children IAW manufacturer/federal guidelines.
Oct 13, 2015 | 2007 Buick LaCrosse CX
Need hardware
Don't use the crib with out the exact hardware. Delta Children's Products is located in NYC. But - chech the date code on your crib. If it was made before June 2011 then it probably doesn't meet the latest safety standards. The crib is the only place a child should be left alone and so you want to be sure it is the safest peice of baby gear that you own.
Jan 16, 2015 | Delta Luv Delta - Baby Products 5-in-1...
Need an emissions schamatic for my 1984 K10 silverado 305 engine
Unfortunately, there are 13 variations for this engine and year. Was this truck sold or modified for high altitude? Was it sold in California or modified to meet the CA emission standards? Does it have a manual or auto transmission? After narrowing down based on answers to these questions, there are still alternative configurations depending on the particular equipment, so look carefully at the diagrams to see which components are used on your engine. Sometimes you can match the 3 letter code for the diagram to letters in the VIN or a sticker in the engine compartment. Please let me know if you have questions.
Fig. Fig. 49: 1984 305 (5.0L) V8 engine-4bbl federal and low altitude with automatic transmission
Fig. Fig. 50: 1984 305 (5.0L) V8 engine-4bbl federal and low altitude with automatic transmission alternate
Fig. Fig. 51: 1984 305 (5.0L) V8 engine-4bbl federal and high altitude with automatic transmission
Fig. Fig. 52: 1984 305 (5.0L) V8 engine-4bbl federal and high altitude with automatic transmission alternate
Fig. Fig. 53: 1984 305 (5.0L) V8 engine-4bbl federal and high altitude with manual transmission
Fig. Fig. 54: 1984 305 (5.0L) V8 engine-4bbl federal and high altitude with manual transmission alternate
Fig. Fig. 55: 1984 305 (5.0L) V8 engine-4bbl federal and low altitude with manual transmission
Fig. Fig. 56: 1984 305 (5.0L) V8 engine-4bbl federal and low altitude with manual transmission alternate
Fig. Fig. 57: 1984 305 (5.0L) V8 engine-4bbl federal and low altitude with manual transmission alternate
Fig. Fig. 58: 1984 305 (5.0L) V8 engine-4bbl federal and low altitude with automatic transmission alternate
Fig. Fig. 59: 1984 305 (5.0L) V8 engine-4bbl federal and high altitude with automatic transmission alternate
Fig. Fig. 60: 1984 305 (5.0L) V8 engine-4bbl federal and low altitude with automatic transmission alternate
Fig. Fig. 61: 1984 305 (5.0L) V8 engine-4bbl federal and high altitude with automatic transmission alternate
Oct 27, 2011 | Cars & Trucks
Is the crib model 4464 a fit federal standards?
You can find out about the recalls at www.cpsc.gov. That model number appears to be on recall for a Delta Portable crib. They are sending out a repair kit for the recall. Please visit the above website for the recall information.
Sep 20, 2011 | Delta Luv Delta - Baby Products 5-in-1...
My printer has a problem picking up the paper and moving through the rollers in the back.
Paper does not feed
into the machine.
• Remove any obstructions from inside the
machine.
• Paper has not been loaded correctly. Remove
paper from the tray and reload it correctly.
• There is too much paper in the tray. Remove
excess paper from the tray.
• The paper is too thick. Use only paper that
meets the specifications required by the
machine.
SELECTING PRINT MEDIA
You can print on a variety of print media, such as plain paper, envelopes,
labels, and transparencies. Always use print media that meet the guidelines
for use with your machine. Print media that does not meet the guidelines
outlined in this user's guide may cause the following problems:
• Poor print quality
• Increased paper jams
• Premature wear on the machine.
Properties, such as weight, composition, grain, and moisture content, are
important factors that affect the machine's performance and the output
quality. When you choose print materials, consider the following:
• The type, size and weight of the print media for your machine are
described later in this section.
• Desired outcome: The print media you choose should be appropriate for
your project.
• Brightness: Some print media are whiter than others and produce
sharper, more vibrant images.
• Surface smoothness: The smoothness of the print media affects how
crisp the printing looks on the paper.
• Some print media may meet all of the guidelines in this section and
still not produce satisfactory results. This may be the result of
improper handling, unacceptable temperature and humidity levels,
or other variables over which Samsung has no control.
• Before purchasing large quantities of print media, ensure that it
meets the requirements specified in this user's guide.
Using print media that does not meet these specifications may cause
problems, requiring repairs. Such repairs are not covered by
Samsung's warranty or service agreements.
Make sure not to use the inkjet photo paper with this machine. It could
cause damage to the machine.
May 16, 2011 | Samsung CLP 300 Laser Printer
Hi I am getting a speed indication message on my washing machine
his washer, the MAH500B, like the other washers in the Neptune line, is a front-load design without an agitator. The result is less wear and tear on clothing and improved cleaning and stain removal. This machine also offers remarkable energy and water savings and meets or exceeds the recent federal Energy Star® guidelines for efficiency. The Neptune boasts an automatic detergent dispenser and a bleach dispenser, ensuring that these additives enter the cycle at the optimum time. It has a large tub that can handle the cleaning of bulky items such as bedspreads and rugs. The tremendous variety of cycles ensures that this unit can handle almost any job. Of the many features included is an automatic water level selector, which saves energy by matching the amount of water to the load size. Additional workhorse features include an infinite-speed motor and infinite-speed combinations. The durable stainless-steel washtub will last a lifetime and will cut down on pilling the surfaces of garments.
Apr 30, 2011 | Maytag Neptune MAH5500B Front Load Washer
The soap dispenser door will not stay closed. Also, there seems to be grit on the glasses after washing the dishes. What is the best product to use to clean the inside of the dishwasher? Thank you
New state and federal guidelines were established for phosphatecontent in the detergents. The newer version contain no phosphates and are really poor at cleaning.
Jan 31, 2011 | Dishwashers
Check engine light indicating a need to replace the catalitic converter. What is the warranty on catalitic converters
usually 100,000 miles , some are 70,000 miles. just call your local toyota dealer parts or service dept. , or look in your owners manual under the warranty section of your manual.
Good luck with your problem
Oct 01, 2009 | 2003 Toyota Corolla
Delta 473 faucet very loose where it meets the granite
This is a view from the underside of our sink. Is this what you were talking about? The steel plate is W-shaped (upside down in this case) and has a single nut larger than 3/4". It's almost impossible to fit a wrench up there to tighten it.
Jul 30, 2009 | Delta Model 473: Saxony Kitchen...
Delta luv milano
Use archive.org to look on an old version of their website to see if later models use the same parts. (Check the manuals, they will have pictures). They were fine sending me parts for a 2001 crib today.
Mar 05, 2008 | Delta Luv Delta - Baby Products 5-in-1...
Baby Gear Logo
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
