Question about Sony Handycam CCD-TRV16 Camcorder
Zoom button does not work
My camera was working perfectly fine untill 5 nights ago, I noted that the zoom button had stopped working.
  • 139 Answers
Go get some Electronic Contact cleaner and on the Side of the Toggle switch spay a little bit in the front and rear of the switch ,Make sure the Battery is out and spray the rocker up underneath to get to the Tact switch,Rock the rocker back and forth several times to clean the switches,The Contact clear will dry quickly,After dueing this let dry for 5 Min put batt and try it good luck Let me know if this works ttech
Posted on Jul 24, 2007
I have a Canon EOS 550D camera fitted with a Canon Zoom Lens EF-S 18-200mm lens. I bought both together sometime early in 2010 from London Camera Exchange, Nottingham. I am not in Nottingham at the moment,...
Just a thought - are your Image Stabilizer and Auto Focus switches On or Off?
Might be worth experimenting with them.
Otherwise, sorry, can't help.
May be necessary to contact your vendor.
Aug 09, 2011 | Canon EFS 18200mm f3556 IS Zoom Lens + UV...
The flash is not working on my Fuji FinePix F402 Digital Camera
If the flash is faulty, it will most likely be to expensive to repair. You can still use the camera, though. Indoor photos will be to dark unless you turn off the flash. Cycle through the flash modes untill you get the Suppressed Flash symbol. Flash mode button is next to the zoom button. Watch out for camera shake when shooting indoor without flash.
Mar 27, 2010 | Fuji FinePix F402 Digital Camera
CANON POWERSHOT A640 LCD VIEWFINDER STOPPED WORKING
nice camera ... the button at the bottom left is marked Disp ... each time you push that button it will change the display mode ... there are three modes .. OFF, ON , and NIGHT ... night turns down the brightness a bit ... push the button several times until you get the display you want ..
Oct 06, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Auto zooming on power up, intermittent problem
Possibly a intermittent connection in the control buttons or the ZIF (Zero Insertion Force) connector from the controls to the main PCB.
Take it in for servicing, they will do a trial by substitution (swap out control) and lubricate the connector.
There isn't really anything you can do to fix with this sort of problem.
Cheers.
Sep 28, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
Auto focus not working Kodak V803
is the setup shoing that it is on MACRO? if so turn MACRO off
Jun 20, 2009 | Kodak V803 Digital Camera
The zoom won't work on my Canon A460
Your zoom may be turned off, here is how you can turn it back on:
When you are about to take a picture, press the little menu button, then press down until it says digital zoom, if the little black box is over-top of 'off' change it to say 'on'.
Hope this helps.....and makes sense.
Dec 30, 2008 | Canon PowerShot A460 Digital Camera
I bet you can't solve this.
We have a Canon A520 and it was having all the symptoms noted. Searched for a resolution on numerous sites including the Canon Support site. While on the Canon Support site, I found an FAQ on "How to RESET the A520". Turn camera on, find and hold MENU button for 5+ seconds until "Reset settings to default?" screen appears. Arrow over to OK and press the SET button. When we did this the battery low indicator showed, replaced batteries with standard alkaline batteries. Everything functions properly, with no additional problems for the past 5 days. I guess the camera just lost its mind and had to be defaulted and rebooted, hope this helps.
Oct 01, 2008 | Canon PowerShot A520 Digital Camera
Sony DSC-P3 Zoom stopped working
i had that same problem. check your image size, the camera cant zoom if the image size is set to 3.1M or 2.8M(3:2)
how to change image size:
turn on camera and leave it in camera mode (picture taking mode)
press the delete/image button
change image size until camera zooms again
VGA gives the biggest zoom range
i hope this helps
it worked on my camera
Jul 27, 2008 | Sony Cyber-Shot DSC-P32 Digital Camera
When using the zoom button the cam stops working
This suggests the zoom motor has failed. As you only purchased it 2 weeks ago - it should be replaced under warranty
Aug 21, 2007 | Panasonic Lumix DMC-FX50 Digital Camera
Sony Handycam CCD-TRV16 Camcorder Logo
163 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
