Question about Bosch Classixx KGV28323 Bottom Freezer Refrigerator
Bosch fridge freezer
My fridge freezer leaked and defosted but my fridge was still working so i turned it off and restarted it but for some reason there both dont work now i can hear the motor when its on but warm air is coming out ive only had it 1.5 years it was working the day b4 as normal but woke up to find the leak the next morning
    Genius:
  • 2,920 Answers
I think you have a freon leak...that would tell you why its not getting cold and why its not working now at all.
Posted on Jan 28, 2009
We ve had the Bosch fridge-freezer (KGU3201GB/01) for about 10 years. Suddenly this morning the freezer started losing temperature, which rose to -13 degrees and the alarm went off. We put the...
Hi Robert, sounds like the unit is not defrosting.
Try this to indicate defost issues.
1. relocate food in the freezer, turn the unit off for 2 days and leave the door open, this will allow total defrost.
2. clean, then restart unit with door closed, after and every 2 hours check temp, I feel you may find it will get to its operating temp reasonably fast and should stay there.
If this is the case, I suspect the defrost heater element has failed and needs replacing, this is the most common cause of your type of issue.
Hope that helps and please dont forget to vote. Regards Russ
Mar 19, 2011 | Bosch 3.2 cu. ft. / 91 liter Upright...
I have a whirlpool 363L WRN38RWG6, the problem i am having is that the fridge leaks water from the vent inside the door on top of the fridge section, then the fridge freezes any thing put to the back of...
I could not find the model but i assume it is a side by side.The model # should be located in the fridge side on the upper right hand corner on the fridge wall.On the freezer side in the back there is a cover with vents covering the evaporator coils. Remove the shelves,the cover to expose the evaporator.If the evaporator is all iced up your defrost themostat may not be working.The defost thermostat is located on top of the coils,it is a little round unit with 2 wires going to it.To check you can uplug it and put a jumper wire in the plug in to see if the defroster starts up.Make sure the fan is also working.Also check the drain (little round hole in the bottem of the drain pan) below the coils.Just poor a little water down it.If it is pluged you can use a small round tube and push it through the drain.Hope this helps,if so give us a 4 thumbs up. THANKS
Mar 02, 2011 | Refrigerators
Fridge Not Working
Your problem could be one of the following:
* compressor
* attachments to compressor (e.g.: relay, capacitor (if applicable) or overload protector)
* refrigerant (e.g.: restriction or leak)
* temperature control assembly
Contact an appliance service company.
Feb 19, 2010 | LG LRTBC1825T Top Freezer Refrigerator
The freezer half is not working
sounds like the defrost timer is stuck to me
call the fridge man or bur a new fridge
parts should be arround 50 plus 50 to install
but call and check first
Jul 25, 2009 | Refrigerators
Bosch fridge KSU 44 leaking water from bottom of fridge
Check the hose or the drain hole in the back of the freezer make sure hose is connect and the drain hole is not plugged
Feb 07, 2009 | Bosch KSU49630 Top Freezer Refrigerator
Bosch KGU40124 water leaking from freezer
remove freezer back panel and you will see a tray at the bottom with a drain hole in the middle and it is this which is blocked. if blocked with ice, clear with some hot water and make sure drain is free and water flows away
Nov 05, 2008 | Bosch KGU40124 Bottom Freezer Refrigerator
FREEZER WORKING - FRIDGE NOT WORKING
Ok, got it sussed! [well here's what I did anyway]...
Quite simply, I turned off the fridge-freezer at the mains overnight and in the morning, broke and chucked out the ice chunks that had lined up in the bottom of the freezer section and then turned it back on. I returned that night to see that it was working fine again! Hallelujah, I got my fridge back!!
So it seems that all it needed was a good long defrost, so far so good! I hope this solves your problem.
Jan 07, 2008 | Bosch Classixx KGV28323 Bottom Freezer...
Bosch Classixx KGV28323 Bottom Freezer Refrigerator Logo
284 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
