Question about Samsung SGH-E900 Cellular Phone
Camera sucks the camera is just giving me probs, ok when I take the photo, it looks ok the immediate snap shot, but then it shows an overly exposed bright foto right after this occurs especially when I use the flash.the pics are so bad that you cant see anything, just a bright blurry image anyone know how to fix this
  • 139 Answers
Re: camera sucks
Take the Model and Make go to the Camera Name website and see If they have any new software or upgrades you can upload to your Camera,First go to your menu and Check s/w Software Version then Ck Website Hope this Helps ttech
Posted on Jul 24, 2007
0 characters
3 Points
I can't find the photo's i've recently taken .. other photo's saved ok
Possible that the location you are checking is not the folder it was stored. Please check on the my images/my photos folder. You can also open camera and check the options window to see the recent images files which will indicate the location.
Nov 01, 2011 | Sony Ericsson Cyber-shot C902 Cellular...
How do I take Better Pictures with my Smartphone Camera
<p>Camera phones have come a long way in recent years, but they do not always point and shoot quality images on the first try. See how the best quality photos from the camera pressed to your smart phone. <br /> <p>All phones and cameras are different, so your mileage may vary according to a tip. While most camera phones suffer from similar weaknesses (particularly the inability to make good pictures in low light), each also has its peculiarities. The iPhone, for example, usually takes pictures with a color very good, while the Droid often produces colors that are less than stellar. That said, most of these tips can be applied to your favorite phone and camera application quite easily. <br /> <p><br /> <p>1. Clean your lens - may sound crazy, but give your lens a wipe down before you start taking pictures with your phone. While most people are very good at keeping their dirty fingers away from camera lenses is not as easily done with camera phones. If you have a dirty lens, none of the other tips in this article your picture is less a waste, so keep that in mind. <br /> <p><br /> <p>2. Use Your Light - It is important, with all the cameras to make sure that your subject is the source of light and you're not, but even more important with camera phones. The biggest weakness is the inability to make good pictures in low light, which means that you generally want as much light as you can possibly get on the subject. <br /> <p><br /> <p>3. Avoid Digital Zoom - You've probably heard that a million times, but we cannot stress enough how often this function is useless. As you approach a topic, you are much better closer to them. If you cannot, you can always crop the photo later, everything is digital zoom really does, you can always cut down, but you cannot appear. <br /> <p><br /> <p>4. Give attention to the flash - Sure, LED flashes in a recent hyped smartphone cameras, but they are not all that is cracked up to be. If you do not have enough light to work, they can at least make sure you have an image, but many phones tend to use it more often than necessary, and that white light LED can be really difficult. <br /> <p><br /> <p>5. Go to your smartphone camera settings - depending on your phone and the camera application that comes with it, you can use some settings you can customize before taking a photo. In almost all cases, however, you can do better, grabbing a camera more advanced application, such as camera zoom or camera FX Android + iPhone. <br /> <p><br /> <p>6. Check the resolution of your camera - Most applications have a camera setup to take pictures at different resolutions. Lower resolutions are fun if you're a quick photo via MMS and they will save on your phone faster, but if you take a picture you want to keep, you better take it at a higher resolution. It is a clear and simple to adjust, but something you definitely want to check before you start snapping, there's nothing worse than taking two very nice photos, only to find when you put them on your PC that they just 640x480. (Also worth noting, some phones resize photos if you send them, make sure to send a full resolution of quality issues.) <br /> <p><br /> <p>7. Turn on the stable settings of your phone camera - Phones are difficult to maintain constant start your shutterbug, and is sometimes difficult to detect the blur of an image unstable on a small screen. Although you can always rest your elbows on something solid and breathe like a sniper, causing an adjustment in your application Steady Shot camera will help a lot. This configuration will use your phone's accelerometer to measure how much you shake the camera, and will not take the picture until his hand is stable for a certain time (usually about one or two seconds). Some applications can even show the sensitivity of Steady Shot, so your phone can not wait to go for the shot. <br /> <p><br /> <p>8. Check out White balance - Most camera phones are very good at detecting the white balance, but if you're in low light, they have difficulty. The first thing you can do is a second camera to adjust yourself if you just open the camera application and snap away, you can get an amazing orange sign. <br /> <p><br /> <p>9. Check out Exposure - Adjusting the exposure is greater let more light into the lens, which means kick it up a notch will probably have a bright, vivid photos. <br />
on Aug 08, 2011 | Cell Phones
When i saved my picture captured by my samsung champ mobile in memory card then after some time it is not showing in any folder of memory card or fone, where these photos are saved? how it can be...
If the photo was taken properly it will be saved within the phone. Now open camera and use the left corner key to open the OPTIONS. You will find the links to the previous files and it can be opened. Normally the camera shots go to the image folder and it can be transferred and named into the memory card- my pictures.
Aug 01, 2011 | Samsung SGH-a437 Cellular Phone
How do i take a shot with the camera?
On the icons screen, click camera icon. The camera automatically gets ready for taking a shot. Now, aim the lens situated on the top right (other) side of the phone, viewing the image on the screen, tap the 'camera image' above the Home Button. The snap is taken and saved automatically in the Camera Roll folder. To view the shot, simply touch the left-down icon (containing your snapshops), all the snaps can be seen by sliding the pics.
Oct 02, 2010 | Apple iPhone 3G
It shows "standby" on switch on the camera
restore it with passward star hash 7780 hash and give secorety code set will restart this is ok
Dec 16, 2009 | Nokia 3110 Cellular Phone
LG Dare camera resets when taking a picture.
Not sure what might be going on here but I'll give it a shot.
Try using the button at the bottom of the right side of the phone to take photos. The button has a little camera icon on it.
The button is nearest to the "Hang Up" button on the front of the phone.
Sep 08, 2009 | LG Dare VX9700 Cell Phone
I would like am instruction manual on how to properly us my LG Xenon cell phone camera for still shots and for video.It must include how I can send the pictures or video to my home computer.
Using the camera module built into your
phone, you can take pictures of people or
events while on the move. Additionally, you
can send photos to other people in a picture
Please find the blow user guide for LG Xen, and view the page 76 for snaps shots and page 103 for sending the files and image to PC
Sep 04, 2009 | Cell Phones
Camera problem
Jul 10, 2009 | LG Shine KE970 Cellular Phone
Lg envy rain trouble
first thing you should have done is remove the battery immediately. The battery with water will fry the phone. The phone needs to dry out. I have heard several people have good luck by putting the phone in a bag of rice for 3 days. Rice will remove the moisture. Give it a try and good luck!
Sep 02, 2008 | LG enV VX9900 Cellular Phone
Samsung SGH-E900 Cellular Phone Logo
22 people viewed this question
Top Samsung Cell Phones Experts
Steven Wander
Steven Wander
Fred Sops
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
