Question about Reliable AH100GT Ironing Shoe For Ace-Hi AH-100G Gravity Feed Iron AH-100GT AH100-GT AH100G AH100
How to wire a plug into ace-hi iron model ah-2100
Iron plug
Bit more information would be handy? whats wrong with the plug? is there just no power going to the iron? have you tried replacing the fuse? have you tried taking the wires out and making sure there is a strong connection between the wires and the screws? if your iron isnt turning on it may not even be a problem with the plug. it could be an issue with the motherboard in the iron
Jul 04, 2013 | Irons
Instruction Manual for Rowenta surefine Inox Steam Iron Model DE-57 1C
Ah, simply search for it online, or go to the manufactors website. I am sure you will find it on the internet.
Jul 22, 2012 | Rowenta Irons
Sparks when you put in plug
Do any other devices or appliances spark when you plug them into the same outlet? If so, you may have a wiring problem, and you should have an electrician inspect the wiring as soon as possible.
If the iron is the only thing that sparks when you plug it into the outlet, there may be a wiring problem inside the iron, or the ground wire may not be connected. Irons are not generally expensive; you should replace the iron for safety's sake.
Nov 29, 2011 | Irons
How do i clean my gc3531 iron
Hi e st clair...
I would use CLR to clean your iron.
Mix it according to the directions with distilled water.
Can be bought at Home Depot,Loews,Walgreens,CVS,Ace Hardware and many other places.
After cleaning rinse completely free of contaminated water with clean distilled water
Please take time to rate me
Sep 04, 2011 | Philips GC 3111 Iron
White flacky material is coming out with the steam. How to clean the inside of the iron? Vinegar?? Special cleaner?? Do I need to used distilled H2O with these irons? Thanks! Debbie
Hi Debbie...
You can use vinegar, but I would recommend that you use "CLR" it is made for cleaning calicum,rust,etc and it is available at all major drug stores,Lowes,HomeDepot,Ace Hardware,etc.
Use as instructed on the bottle.
After cleaning, be sure to flush properly with distilled water and make sure you use ONLY distilled water in your iron.
Sep 01, 2011 | Rowenta Effective DX1900 Iron with Auto...
I have a rowenta proffesional luxe iron but the cable keeps turning it off so when i move the cable it goes back on and when i am ironing it shuts off
you have a open circuit that occurs due to a wire loose at the plug end or a loose connection within the iron. a break in the cable will also display the systems you discribe. check for loose connections before you decide to replace the cable. by keeping the cable stationery when the iron is on at the plug end check wether it switches off when you move the cable near the plug end.if it switches off the loose wire is in the plug if it does not the try the moving the cable nearer the Iron end.
Apr 10, 2011 | Rowenta Professional Luxe DM880 Iron
We have a Rowenta iron effective model DX1700, less than a year old. It will not heat. Is there an iron made that will give satisfactory service for more than a year? Are they repairable?
If the cord and plug are ok (the wires in the cord often break just at the cord protector at the iron) the most likely other problems will be the thermal fuse(s) or the element. Thermal fuses can be replaced but if the element is gone that is unfortunately that. Take the back cover off and check for continuity from the plug to the inside connections using a test light or multimeter (the iron is of course unplugged).
Jan 19, 2011 | Rowenta Irons
When i plugged the iron it wont start , i have to shake the plug up and down then it start and as soon as i leave the cord it goes back to shut down
You have a short in the cord.Go to ace hardware and get a replacement cord. remove the bad cord. And put the new one on. Your ready to iron.
Aug 10, 2009 | Irons
When i am ironing all the power in the house goes off and it is a brand new iron
Patrick,
The iron may actually be ok. If not, remember that because it's new it will come with a guarantee.
Did you put the plug onto the iron yourself? Check inside the plug to make sure that there's no bare wires that can touch as the cord flexes as you iron. This would cause it to short and throw the power in the house.
Try using the iron in a different room. If you get the same problem then there's possibly a wiring fault (maybe a broken/worn insulation on the wires of the iron cord ... though as it's new, I would doubt this).
Are you using an electrical extension lead to plug the iron into? If you haven't overloaded the socket with other electrical appliances it may be that the extension cable has a broken/faulty/loose wire inside that when they touch, causes the power to go off. A few years ago the power in my house used to go off on occasions whenever someone went to the fridge. The fault was traced to split insulation on one of the wires in the extension cable I was using. Whenever somebody stood on the cable it shorted out and cut the power.
To be really sure - go into a neighbours and use the iron! If the power goes off - it's the iron at fault. If not, it's probably just a small problem like worn insulation/loose/broken wire in an extension lead in your own house.
Sep 19, 2008 | Conair Compact Garment Steamer Iron
Reliable AH100GT Ironing Shoe For Ace-Hi AH-100G Gravity Feed Iron AH-100GT AH100-GT AH100G AH100 Logo
43 people viewed this question
Top Reliable Irons Experts
Are you a Reliable Iron Expert? Answer questions, earn points and help others
