Question about D-Link DSL-504T Router
I need to open port 8888 on d-link DSL-504T and is there any manual i can see to do that thanks so much
  • 68 Answers
Please download this maunal.
http://www.pobox.co.uk/support/downloads/manuals/DSL-504T_Install_Guides.pdf
and refer to page 14 which is port forwarding...
Posted on Jan 29, 2009
Port forwarding
WHEN YOU OPEN A PORT YOU NEED TO ASSIGN THE DEVICE THAT GOES ASSOCIATED WITH IT...LIKE PC1 IP 192.168.1.1
PC2 IP 192.168.1.2 THE PORT YOU WANT TO OPEN NEEDS TO BE ASSOCIATED TO EITHER PC1 0R PC2 WHICH EVER IS RUNNING YOUR APLICATION...TEKGODS.COM
Feb 18, 2013 | D-Link DSL-2740R Wireless N ADSL2 4-Port...
D-Link DSL-504T driver disc missing, looking for Win 7 compatable driver for modem.
No driver needed since you aren't connecting the pc the the modem, but to the router.
Connect the pc to the D-Link DSL-504T with a LAN cable, access it from a browser by going to this IP - 192.168.0.1 - , in there access the modem settings and configure it accordingly.
Jun 20, 2011 | D-Link SWT DSL-504T ADSL MODEM with 4...
I suspect other people may be using my internet. I have a DSL-504T D-Link router and a Belkin wireless router connected to that for our laptops, how do I protect our internet?
Go to the site
http://support.dlink.com/emulators/wbr2310/wireless.htm
and follow the steps for your router.
1.In Wireless Security mode select Enable WEP wireless security.
2. Authentication select as shared key.
3.Now set your WEP key values.
4.Save the setting.
Hope this will help you.
Thanks for using FixYa.
May 14, 2011 | D-Link DSL-504T Router (DSL504TX31FOC)
HOW CAN I OPEN A PORT TCP AND UDP IN FRENCH FOR DSLG604T V3.00
Exemple : Vous accueillez un web server sur un PC qui a l'IP address de LAN de 192.168.0.50 et votre ISP bloque le port 80. Nommez le Virtual Server (par exemple : Web server) écrivez l'IP address de la machine sur votre LAN (par exemple : 192.168.0.50 Entrez dans le port privé comme [80] Entrez dans le port public comme [8888] Choisissez le protocole (par exemple TCP). Assurez que le programme est placé à toujours Cliquez sur sauf pour ajouter les arrangements à la liste virtuelle de serveurs Répétez ces étapes pour chaque règle de Virtual Server que vous souhaitez s'ajouter. Après que la liste soit complète, clic sauf des arrangements au dessus de la page. Avec cette entrée de Virtual Server, tout le trafic sur Internet sur le port 8888 sera réorienté à votre web server interne sur le port 80 à l'IP address 192.168.0.50.
My French isn't good sorry.
Feb 15, 2010 | D-Link AirPlus G DSL-G604T (790069265662)...
I need to change the modulation type on my modem to select g.dmt to make my internet connection more stable HELPPPPP!! i have NO clue how to do it. it's an ADSL 2+router DSL 504T.i am computer...
To configure the modem You will need to use the cd provided.
ftp://files.dlink.com.au/products/DSL-504T-GenII/QuickInstallGuide/DSL-504T_C3_QIG_v2.00.pdf
Or to configure without the cd follow the steps below:
  1. Connect the Adsl router with your computer.
  2. Use the network cable provided with the router.
  3. Connect the power cable to the modem, it will light on firmly with a green button on.
  4. Open your web browser and type the ip address: http://10.1.1.1
  5. Default username and password is:
  6. User-name: admin
  7. Password: admin
  8. Use the quick setup wizard.
  9. It will be more easy for you to configure it.
  10. Be sure to have the username and password from the ISP for the internet access, you may need to reconfigure it from start. or if you may need to reset the modem
  11. At times to access your modem you will need to set the ip of your network card to the same range.
  12. To set the ip go in control panel then open network connection
  13. Doulbe click the local area connection.
  14. open Internet Protocol Open Tcp/ip
  15. then set your ip Like: 10.1.1.5
  16. ok
  17. ftp://files.dlink.com.au/Products/DSL-504T-GenII_NZ/Manuals/
I am enclosing a manual for you.
If you Need further help do not hesitate to revert back
Ok cheers
Uttam
Feb 13, 2010 | Computers & Internet
Remote manage a DSL 504T router
If you have a dynamic IP on your wan port you shall register a domain name and register it with dynamic DNS, provide your dynamic dns name in your DSL router so that you shall connect to your DSL router by calling the registered dynamic dns name from any where (you should have internet connection).
1. Register a name in dyndns.com
2. update this on your dsl router
Wait for some time,
3. access the registered name from anywhere using a browser
Jun 09, 2009 | D-Link DSL-504T/EU Router
DSL-504T Router - not connecting?
Try using the D-Link Click'n Connect Utility.
Admin is the correct code for both the user name and password.
10.1.1.1 is the correct IP address for the setup page.
You may need to reset the router again by holding the reset button in for 30 seconds until the lights flash off then on.
Here is the setup manual:
ftp://files.dlink.com.au/products/DSL-504T-GenII/QuickInstallGuide/DSL-504T_GenII_QIG.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 04, 2009 | D-Link DSL-504T Router
Utorrent port not working
Here is a great website: http://portforward.com/routers.htm
Get your model number of your router/modem, and find it on the website list, then it gives you the instructions on how to foward ports.
Hope that helps.
Jan 02, 2009 | D-Link DSL-504T Router
Pluging in
Rather than me repeating them, this same question has been answered several times on FIXYA. I would copy
and paste it in the FIXYA search on top of page to find several answers.
Dec 25, 2017 | D-Link SWT DSL-504T ADSL MODEM with 4...
Lan connection
Device your needing:
1. Modem
2. Router
3. Hub / Switch
4. UTP cable
5. RJ45
I'm sure you have a modem, right? First you need to have a router. The manual on your router will teach you how to connect to LAN, you just follow the instruction.
For cabling instruction and other info. just e-mail me ragutz2002@yahoo.com
I can't put all the details here..
Nov 10, 2007 | D-Link SWT DSL-504T ADSL MODEM with 4...
D-Link DSL-504T Router Logo
94 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
