Question about Hitachi Magic Wand Hv250r Hand Held Massager
Replacement head for magic wand - Hitachi Magic Wand Hv250r Hand Held Massager
The small spring in the head of my hitachi magic wand is broken. How can I remove it to take it to the hardware store & replace it?
I have a doctors tool called forceps that work wonderfully for grasping small parts . check the sporting goods department at walmart .
May 27, 2015 | Health & Beauty
When I scan something with my magic instascan I can not find it on my computer. Doi need to install something first?
Make sure your wand is turned on. You have a microSD card inserted in the Magic Wand. Go to "My Computer" and look for a removable disk drive.
Oct 05, 2013 | VuPoint Magic Instascan Hard Case For...
Akai cassette deck GXC-725D
It could be head dirt, bad switches, broken head wire or electronics problem. A Technician or you if you know electronics will need to get into it further to find where the problem is. There si no magic wand except some alcohol and a Q tip if the heads are dirty.
Dec 06, 2012 | Audio Players & Recorders
I fixed my hitachi magic wand, but now I cannot get the silver ring back on during the final steps of reassembly
rotate the head/neck part, one of the sides is not aligned with the notches in the bace of the neck. rotate it to fit right then you should be able to fit it on easily
Jul 16, 2011 | Hitachi Magic Wand Hv250r Hand Held...
How do you delete pictures and copies from the VuPoint Magic Wand?
Your VuPoint Magic Wand scanner should have come with a USB cable. Use the cable to connect the scanner to your PC, and the memory card in the scanner appears as a removable drive in Windows Explorer. Deleting files from the card is just like deleting files in any Windows folder -- just highlight them and press the Delete key.
Nov 12, 2010 | VuPoint PDSST410VP
How do you remove the top of the Magic Wand Portable Scanner to install the batteries for Vupoints model # ST415 magic wand?
The battery cover is the silver-colored "hump" on the right side of the scanner. Just slide it to the right, and it'll unhook from the scanner, giving you access to the battery compartment.
Oct 05, 2010 | VuPoint PDSST410VP
Can the Magic Wand Rechargeable Massager be charged from a 220 volt power?
If your wand is N American then "don't do it" 220 through a 110/120 will fry all the magic out of it. You could get a step down transformer 220 to 110. Plug that into the 220 socket and plug your magic wand charger into that.
The cost would not be worth it though ... buy some more magic that is 220. be happy ... not sorry :-)
Nov 17, 2009 | Hitachi Rechargeable Wireless Magic Wand...
Sounds like its working, but nothing happens
I had the same problem with mine, it's due to the fact that the smaller spring has become un-lodged from the ******** itself.
You will need:
1. Roll of electrical tape.
2. Utility Knife
3. A small slot head screw driver OR a pair of needle nose pliers.
The solution is to unscrew the silver ring so that is can be moved up and down. Now, you need to use a utility knife and cut the blue rubber off of the spring. Once you have the blue rubber but off you can see a large spring with another smaller spring inside. Push the head of the ******** till the larger spring's coils are an 1/8 to 1/4 of an inch apart. Next take either the small slot head screw driver or a pair of needle nose and jam the smaller spring back into the hole in the center of the white plastic piece inside of the larger ring. Next plug it in to make sure the vibration is working, reattach the silver piece and tape the larger spring with electric tape.
Oct 25, 2008 | Hitachi Magic Wand Hv250r Hand Held...
Saeco Magic squirts water out the wand when brewing
Hi Steve,
You have to replace the gasket on the steam pin, maybe you have to replace the steam pin to if it is worn.
Apr 11, 2008 | Saeco Magic Cappuccino Espresso&Cappuccino...
Hitachi Magic Wand Hv250r Hand Held Massager Logo
73 people viewed this question
Top Hitachi Health & Beauty Experts
ray gallant
Stan Ford
Are you a Hitachi Health and Beauty Expert? Answer questions, earn points and help others
