Question about AO Smith A O Smith Motors Century 1hp 115v Thru - Bolt Lomart Motor - Bv90
I have a Century AC motor 1/2hp #8-158944-20,Frame J56,115/230,type CSS that I need to wire to a Dutton-Laison winch switch. The motor has 6 cables,White,Blue,Black,Yellow,Orange and Red. The switch has 4 cables, Black,White,Red,Blue.
  • 1388 Answers
SOURCE: rewiring mootor from 230v down to 115v
Diagram for aosmith motor b381 is here: http://www.electricmotorwarehouse.com/IMAGES/B381_connection.htm
However, I believe that this motor will be more efficient at 230v depending on load conditions. At 115v this motor will draw more amps and tend to run hot, but situation rules. Enjoy
Posted on Dec 14, 2008
john224
  • 1378 Answers
SOURCE: Which wires goes to which post ? Just bought an
It does not matter. Just make sure it is set to the correct voltage your system supplies to it and that you put pne wire on each terminal as the diagram on the side of the motor will show you.
Posted on Jun 14, 2009
erpaalai
  • 999 Answers
SOURCE: wiring a 220v single phase motor and capacitor
Black and white are usually power. an ohmmeter will confirm. Brown are for capacitors. There is almost always a diagram on the motor someplace. Eric
Posted on Jun 17, 2009
john224
  • 1378 Answers
SOURCE: I HAVE AO SMITH MOTOR BL6414 HOW DO I WIRER IT UP
The BL6414 motor is shaded pole and does not require a capacitor.
Posted on Jul 12, 2009
john224
  • 1378 Answers
SOURCE: Need to get diagram to wire gould century 1.5 h.p.
Email me at john@arrowmotor.net and I'll reply with the .PDF from AOSmith. You need to move a couple of wires but as they say, a picture is worth me typing a thousand words.
Posted on Aug 27, 2009
How to rewire my century 3hp ac motor part # 8-141443-02 from 230v to 120v
look on the side of motor it has a schematic for 110 volts and 220 volts have to move wires or turn a switch
Sep 11, 2015 | Century Pool & Spa
So I'm wiring up the KFI stealth 3500 winch on my ATV do I need to ground the contactor box to my frame
If it has a black wire that goes to neg on the battery.Pos or red to a switch if the winch does not have one.
Mar 24, 2015 | ATVs
KFI winch won't spool in or out there is power to it I can hear it clicking
If your wiring a remote control to the winch or inside control,,, 4 solinoids type,,make sure the solinoids have ground on the brown wire(warn)...if you don't have a ground all it will do is click,,,even if power is applyed
Feb 19, 2015 | Cars & Trucks
I need a winch wiring diagram
The third wire should be the extra ground wire and is usually grounded to the metal body of the device.
Jan 08, 2014 | chicago electric power tools 1500 Lb....
Century single phase 2 hp 3450 rpm type cs motor Frame f56
the motor is on 220 volts ,i like hook that up on 120 volts ,,thanks
May 10, 2012 | Air Tools & Compressors
I bought an A frame house with an old Dayton 5k340-R motor that powers a platform elevator to the loft of the A Frame. The ancient switch has shorted and I need to rewire. I need a wiring diagram so I can...
two of the motor wires are most likely to a starting capacitor but the color codes are what you need. A commercial garage door switch should work fine here but you need to ring out the wires with a DVM....
Jan 11, 2010 | Air Tools & Compressors
518 cat skidder gearmatic winch keeps turning when put in free wheel 1985
pull the secondary clutch apart on the winch and clean with emory cloth or sand paper and u should see a change in this problem
Sep 08, 2009 | Heavy Duty Associated Equipment 6002B...
Rewiring mootor from 230v down to 115v
Dec 13, 2008 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
AO Smith A O Smith Motors Century 1hp 115v Thru - Bolt Lomart Motor - Bv90 Logo
101 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Steve
Larry Maranto
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
