Question about SAMTRON 55V 15" CRT Monitor
Minitor is shrinked on both side horizontally. The settings are all ok and resolution is perfect. Seem some problem with CRT or something like H/W. Any help on this???
  • 293 Answers
Open your on-screen display on your monitor, find & press auto adjust. If that doesn't work go to factory reset menu and pressed to reset to original settings.Then reboot your pc.
Posted on Jan 28, 2009
Picture cut off on sides, how do i shrink picture to screen?
If model listed is correct the problem is in power supply or vertical or horizontal circuits.
If cut off on sides (horizontal) and bowed on sides it is a pincussion problem. IF short top and bottom a vertical issue--if both it is in the power supply.
Model listed is rather old and parts may not be available for it.
May 30, 2012 | GE 35GT740 35" TV
Picture shrinks horizontally every few seconds.
You are changing parts in the wrong circuit. The problem is in the vertical circuit. Look for the vertical IC and resolder the pins first. It should be an LA7837 or something similar. Also, check the 100ufd and 47ufd caps in the same circuit.
Keep us posted.
Jan 19, 2009 | Panasonic CT-20G11 TV
Hoizontal Bar across RCA Model 24F501TDV Color TV
you may need to change your resolution on tv settings as well as cable or satelite settings if you have one of those
Dec 12, 2008 | RCA 24F501TDV 24" TV
Gateway MX6448, screen is stretched problem is not screen resolution
On the desktop,
right click and go to Properties
then goto Settings
See the horizontal bar,
move it left or right to change the display settings
Apply and Ok it
the screen will refresh and you can ok it or go back to previous settings and try something else
Oct 17, 2008 | Gateway MX6448 Notebook
GE 31
check electrolitc capacitors in horizontal circuit
May 09, 2008 | GE 31GT659 31" TV
Horizontal display
Check with the manufacturer information that you have the refresh rates and maximum resolution set correctly. If in doubt, go to your display properties and try something basic to test if this is the problem. A basic setting may be as low as 1024x768 at 60 Hz.
(You can access your display settings by right-click the desktop anywhere and choose properties, then settings).
Leave the monitor at that setting for a while to see if the monitor changes the picture.
If the picture changes, it may be component failure in the monitor. If not, the problem is then related to the settings from your VGA card are too high or dense causing the monitor to fail after a time. Try something higher like 1280x1024 @ 60Hz and keep going till the picture fails. Compare the best functioning resolution with the manufacturer claims about the product in the product documentation.
Be sure there are no cable bunches and the power cables are not wrapped up with the VGA cable under the desk or there are not too many cables lying about, although unlikely, this has been known to distort the picture.
Let us know if this helps.
Mar 30, 2008 | LG Studioworks 775N 17" CRT Monitor
Monitor settings can't be adjusted
You may need to check the resolution for your graphics card. Check the display settings in the control panel.
Jan 27, 2007 | Dell E773C 17" CRT Monitor
Picture Shrinks
It is in the power supply or I would guess most likly in the horizontal sweep section of the tV set. MOST of the time, if the power supply is going lower in voltage, the set will shrink in width,BUT will also shrink in vertical size. If this is not happening, then I would say it is in the horizontal drive circuit. This is not a circuit a user should be experimenting with, as this is the HIGH VOLTAGE circuit and can pack a mean punch! Please if the sets less the 4 to 5 years old you may want to concider an estimate or replacing the set. Its all up to you. GOOD LUCK
Oct 07, 2006 | Philips 8P6034 TV
SAMTRON 55V 15" CRT Monitor Logo
90 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
Richard Lilja
Richard Lilja
William Miller
William Miller
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
