Question about Epson America EPSON Stylus Pro 3880 CA61201-VM InkJet Workgroup Color Printer
Epson 3880 error 1531 - Epson America EPSON Stylus Pro 3880 CA61201-VM InkJet Workgroup Color Printer
Tip
Epson Stylus Pro 3880
ERROR CODES CAUSES AND SOLUTION
1101
CR life error The CR scan path counter has reached a predetermined level.
(The end of life of the Ink Supply Tube)
Replace the Ink Supply Tube (INK, SYSTEM, ASSY) and reset the counter using the Adjustment Program. In addition, check the statuses of the CR motor (MOTOR ASSY.,
CR), the driven pulley, the Carriage Unit, and the Head FFC, if any abnormal noise or wear is found, replace the corresponding part(s) along with the Ink Supply Tube.1120
CR lock error The CR encoder failed to read the CR scale during a predetermined time period. Replace the CR encoder (BOARD ASSY., ENCODER, CR).
Replace the CR scale (SCALE, CR).The carriage unit does not operate due to a CR motor failure or some reasons. Move the carriage unit manually to check if it moves smoothly, and fix any abnormality.
Replace the CR motor (MOTOR ASSY., CR).1121
CR reverse error An abnormal operation (reveres movement) of the carriage was detected a predetermined number of times. Check the CR scale (SCALE, CR) for incorrect attachment, scratch, dirt, and fix any abnormality. Replace the CR scale (SCALE, CR).Replace the CR encoder (BOARD ASSY., ENCODER, CR).
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
on Feb 23, 2016 | Epson Stylus Pro 3880 InkJet Plotter...
How do i need to purge the ink lines on an epson 3880
Purging Procedure - If you have just installed a new archival or Quadtone cartridge you must purge the Epson print head of all of the old, non-archival, ink before you can begin to print with the full archival effect. The print heads in the Epson 200/400/440/500/600/640/740/800/850/860/900/1160/1520/Photo/Photo 700/Photo EX/Photo 750/Photo 1200 printers hold about 3 to 5 pages worth of ink. Always run a Nozzle check before printing. Even if you get a perfect nozzle check on your first try after putting in a new cartridge, run at least one or two head cleaning cycles. This will prevent any excess ink from over filling the print head. After the cleaning cycles, use the purging test patterns below to purge your system of the old ink. After printing about 5 (8.5x11) pages of this pattern, 98% of the old ink will be gone. The rest will come out slowly and may take as many as 20 or more pages, but at the 98% point you will see good results. If you have an Epson 3000, 5000 or 9000. See below
Sep 11, 2015 | Epson Stylus Pro 3880 InkJet Plotter...
Epson 3880 prit head cleaning
does it not have a head cleaning cycle
Oct 11, 2014 | Epson Office Equipment & Supplies
I have the Epson Stylus Pro 3880. Up till a few weeks ago all was well, the today, it decided not to print out the black areas of my shots. I've check the inks, the heads all is well. HELP
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Dec 02, 2012 | Epson Stylus Pro 3880 InkJet Plotter...
Epson Stylus Pro 3880 Service call error 1224
4 possible problems and solutions, but you really need the service manual to do this:You might find it free somewhere, but most free sights will eventually lead to someplace where you will have to pay- just go here: http://www.2manuals.com/index.php?cPath=2_39
Sep 04, 2012 | Epson Stylus Pro 3800 InkJet Printer
The feed mechanism in my Espon 3800 quit working. Is it affordable to fix or should I dump it?
In Case, if the Feed Mechanism Quit Working, it is better to have New Printer as the Cost of Repair would be high relevant to the Cost of New Printer.
I wish i could have a Better Answer.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 11, 2010 | Epson Stylus Pro 3800 InkJet Printer
GOT ERROR c}}??{{MC;1531-17
This error appears when some characters are sent to the printer and printer don't expect it . To solve this problem configure the printer for CODE { | } in the menu 2 PARAMETER SET. To enter in this menu, turn on the printer while pressing FEED and RESTART.
Jan 19, 2010 | Toshiba TEC B-SX4 Thermal Label Printer
Epson America EPSON Stylus Pro 3880 CA61201-VM InkJet Workgroup Color Printer Logo
223 people viewed this question
Top Epson America Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Epson America Office Equipment and Supply Expert? Answer questions, earn points and help others
