Question about Euro-Pro Shark 9110 Sewing Machine
I need a replacement 240mW LED lamp. - Euro-Pro Shark 9110 Sewing Machine
How do you open the sewing head to change bulb on Pfaff 955 hobbymatic
To access the light bulb, use the button-hole foot to lift up the insert on the arm cover. Remove the cover. Hold the edge guide slightly tilted and push it into the opening in the head of the sewing machine. Press down on the lamp housing to hold it still. Push up on the bulb and turn it counter-clockwise. Once the bulb is loose, pull it down and out of the lamp housing. To replace the bulb, continue to hold the lamp housing. Push the new bulb into the housing and rotate it clockwise. Release the lamp housing and then use the button-hole foot to replace the cover.
Pfaff has the manuals for most of their machines here: http://www.pfaff.com/en-US/Support-and-Updates/Support . The Hobbymatic 955 support page is http://www.pfaff.com/en-US/Support/3529 . The direct link to the manual is http://www.pfaff.com/SiteMedia/PFAFF/Products/Machines/Support-manuals/Pfaff_935_955_HobbyMATIC-manual-EN-FR-DE-NL.PDF . See page 51 (page 59 of the PDF) for the directions to change the light bulb, These pictures may help you see how to get to the bulb. If you need a replacement button-hole foot, see http://www.sewingpartsonline.com/buttonhole-foot-low-shank-new-1932l.aspx .
I hope this helps.
Jul 21, 2017 | PfaFF Sewing Machines
How can I replace the lamp on an unidentified sewing machine?
The best bet is the owner's manual. Most lamps either skrew in or twist about half a turn and pop out. Computerized machine bulbs sometimes have to be serviced by a technician. You can probably take the machine to a repair shop and have them replace the lamp for you.
Mar 15, 2016 | Sewing Machines
Why doesn't light work?
The replacement lamp could be defective.
Feb 22, 2016 | Sewing Machines
Led light does not work. how to replace led light on singer 14sh654
I believe the newer machine lights need to be replaced by a technician. You can check on getting some of those LED light strips that can be added to the machine instead.
Jun 24, 2017 | Singer 14SH654
Foot pedal doesnt work on AEG 11227 LED sewing machine
First get someone with a multi-meter to test the foot pedal. If it is bad replace it with a new one.
Sep 15, 2012 | Sewing Machines
Need part number for a part on singer 14sh654
Singer has a PDF with the illustrated parts list for the 14sh654 available here: http://parts.singerco.com/CPpartCharts/14_CG_J_SH_T/14SH644_14SH654.pdf . There are two different models listed for 14sh654 manuals. However you can download them (or buy them). To download the Ultralock with incandescent lamp manual, go to http://www.singerco.com/uploads/download/434_14sh644_654_e.pdf . For the Finishing Touch (LED lamp), the manual is http://www.singerco.com/uploads/download/555_14sh644_654-(e_s_f)-(new-led-version).pdf .
I hope this helps.
Sep 24, 2011 | Singer 14SH654
The light above the needle went out. The manual says it is a 240mW LED. Where can I get one or where are local service centers? I'm in zip 24091.
I checked everywhere on the web and locally, but ended up having to call the cust. service number for the company. 800-798-7395. Option 2 for english. They knew exactly what I needed, and total including shipping is $31.90. Just glad to have found this without any hassle from the company....
Hope this helps!
Sep 23, 2010 | Euro-Pro Shark 9110 Sewing Machine
Pfaff Tiptronic model 2030 LCD display panel went dark, no display. Now lamp burns hot. Told by local service shop that panel needed to be replace to correct lamp issue. Need replacement lcd panel.
very common prob . with pfath . panel failure . display failure . no easy sol . but to repl pc control panel .. / how ever after repair ( and they never tell us .. use a surge power controler on the line . to your machine .. .. **** .. hope this ansewered your Q " mm feed back pls .. mm
Jan 15, 2010 | PfaFF Tiptronic 2030
LED Bulb Replacement
I've been searching for two days for the bulb replacement in my mother's 9110 sewing machine...needs a 240mW led lamp which the manual says 'not user replaceable'. I called the 800 # for Euro-Pro and the recording referred me to 1-800-361-4639 for Euro-Pro sewing machines. The rep I spoke with knew immediately the lamp needed (must get a lot of calls for this). The total cost including shipping was $31.90 and is shipped from CA. She said it is 2-4 wk delivery, but could come in as little as 2 days. I just ordered it today, so hopefully I will receive it soon and it will be what I need...it looks simple enough to replace, so don't know why they say it isn't user replaceable.
Jan 15, 2009 | Euro-Pro 9105 Computerized Sewing Machine
Need to replace the light bulb--how do I do that
You will need to obtain a new lamp from a Janome dealer.......they will probably offer to install it for you for no additional charge.......just ring to agree a time.
It is a small low voltage, simple push in type lamp & I believe the part number to be: 000 009 906
Just make sure the machine is NOT plugged in when you change it !!
Apr 28, 2008 | Janome Memory Craft 4000 Sewing Machine
Euro-Pro Shark 9110 Sewing Machine Logo
42 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
