Question about Acer Aspire 3000 Notebook
Visualbasic code for place order system
If u checked for one product its automatically display 1quantity and it display the price...and if u change the number of quantity of the same product its automatically add to the price to it...and if uve checked many product itz automatically give the total amount that need to pay...and if u want to clear it...the quantity displayed as 1 and the price diplay as 0.00 and also in total amount...
Need 2 unlock nkia lumia 920
Hi.
I see the website which offer to unlock Lumia 920 , I tried this website, they really unlocked my Nokia Lumia 920 from at&t, i would like Thanks & appreciate to Team of AT&T Unlock Code shop.They provide really good service , I hope this service provider will unlock your Nokia Lumia 920.
Once again thanks http://www.attphoneunlockingshop.us/
the link of http://www.attphoneunlockingshop.us/products/USA-AT%26T-Nokia-Lumia-920-IMEI-Unlock-Code.html.Thanks USA AT Nokia Lumia 920 Unlock Code Unlock Nokia Lumia 920 from AT USA USA AT Nokia Lumia 920 Unlock Code Unlock Nokia Lumia 920 from AT USA
Nice vid. This site explains all this in very easy to order format:
Aug 12, 2014 | Cell Phones
How fix error code 0xc19a0003 on HP B110a ?
0xc19a0013 or no code Check the cartridges
The ink system can fail if the cartridges in the product are installed incorrectly, if the ink in the cartridge is low or out, or if the cartridges are damaged or not correctly vented. Follow these steps to check the cartridges thoroughly and resolve any issues you find.
Step 1: Replace empty or low cartridges
Step 2: Make sure the cartridges are installed correctly
Step 3: Use the automatic printhead cleaning utility
The automatic printhead cleaning utility is available only if you installed the HP software that came with the product.
If the print quality is acceptable on the test page, you are done, and there is no need to continue to troubleshoot. If the print quality is not acceptable, repeat the automatic printhead cleaning procedure again. If the print quality is still not acceptable, 'Remove, clean, and reinstall the printhead' .
Reset the HP Photosmart B8550 Printer
The error message might disappear after you turn off the product and turn it on again. After you make any adjustments to the cartridges or the printhead, reset the product in order for the error message to clear completely. Follow these steps to reset the product.
1.Press the Power button to turn off the product.
2.Disconnect the power cord from the back of the product.
3.Wait 30 seconds.
4.Reconnect the power cord to the back of the product.
5.Turn on the product by pressing the power button.
Check the product control panel display. If the error message disappears, you are done, and you do not need to troubleshoot further. If the error message persists, continue with the next section, 'Remove, clean, and reinstall the printhead.
Read More Help.....HP Printer Support
Thanks,
Aug 08, 2014 | HP PhotoSmart Office Equipment & Supplies
What does service system stability mean on my 2001 Cadillac
This refers to the suspension and steering, you probably have a faulty sensor somewhere.
One of the most common sensors to fail in this system is the steering wheel position sensor.
You need to run a diagnostic check to pull the trouble codes to pinpoint the faulty component.
How to pull the codes.....
Use the 3 switches located to the right (LH drive cars) of the Driver Information Center (DIC) to activate and respond to the OBD prompts on the DIC.
ON/OFF = YES
INFO RESET = NO
INFO DOWN or INFO UP = manual toggle
Ignition ON, acknowledge any warning messages;.
Press ON/OFF and INFO UP together for 2 to 3 seconds. Everything in front of you lights up for 4 or 5 seconds, then you will see:
Display shows "ALL?"
Answering YES will display "ALL CODES?"
Answering YES will run automatic test sequence and display codes, if any.
"ALL CLEAR CODES?" will display at the end of the automatic test. If you are satisfied you have the information you need, answer YES to clear/erase all error codes.
Answering "ALL?" with INFO DOWN will toggle systems test manually in order.
Answering "ALL?" with INFO UP will toggle system test manually in reverse order.
Press INFO RESET to reset DIC to "ALL?" to start again.
Ignition OFF to exit.
Write down the codes as they appear on the DIC, you may need to run the check again as it tends to scroll through quickly.
Report back here with the codes.
Sep 21, 2009 | 2001 Cadillac Sts
I have an HP 12C calculator and I cannot find the user manual and I cannot remember how to change the no. of decimal places?
Check this HP FAQ:
Setting a Fixed Decimal Place You can download the manual and user guides for your calculator from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=81575&lang=en&
For more information, Faqs & how-Tosgo the HP support homepage for your calculator:
http://h10025.www1.hp.com/ewfrf/wc/product?lc=en&dlc=en&cc=us&lang=en&product=81575&
Introduction This document describes how to set the desired number of decimal places on the HP 12c calculator in standard format. It also covers how to enter a number in scientific notation. Instructions for standard format
  1. Press and release c01774993.jpg .
  2. Press the number key for the desired number of decimal places to be displayed to the right of the decimal point (0 through 9). The calculator displays a maximum of 10 digits.
The display will show the specified number of decimal places. The answer will be rounded to the number of digits selected. Example (standard format) If the number in the display is 14.87456320, the display will be changed as follows: Keystroke Display c01774994.jpg 14.8746 c01774995.jpg 14.9 c01774996.jpg 15 c01774997.jpg 14.87456320 Instructions for scientific notation Use scientific notation for very large or very small numbers. Type in the mantissa. After pressing, c01774998.jpg the next numbers keyed in are exponents of 10. Press c01774569.jpg . If during an operation a result has more than 10 digits, the calculator automatically displays the number in scientific notation
Aug 24, 2009 | HP 12c Calculator
Visualbasic coding for library system
hi there,
try to download from this link
http://www.topshareware.com/download.aspx?id=47712&p=&url=http%3a%2f%2fusers.tpg.com.au%2fdwang88%2falda%2fen%2fsms_installer.zip
please don't forget to rate me. thanks!
Mar 21, 2009 | Microsoft Windows XP Professional
Create an inventory prog. in visualbasic?
Do you have Microsoft Office? There are some excellent Access Templates for Inventory Databases
Jan 13, 2009 | Microsoft Windows Vista Ultimate Edition
Pick-up procedure
Hey mikey50,
Whenever you place an order through our website, you will want to make sure that you first receive an e-mail confirmation that your order could be filled before stopping into your local store. Once you've gotten that e-mail, you will need to bring with you the following things:
* Your order number (this will appear within your order confirmation e-mail.
* Your driver's license or another valid photo I.D.
* The credit card you used to make the online purchase.
The reason why you'll need your credit card with you is because you aren't officially charged for your order until you pick the products up at your local Best Buy™ store. As such, the credit card holder will need to be there in person to provide us with their signature. If you placed your order using only gift cards however, you should only need to bring your order number and a valid photo I.D.
Additionally, if the store offers a lower sale price than our website on any product you ordered, you will automatically be provided with the lower on-site sale price.
Should you have any other questions, I would strongly recommend checking out our FAQ through the following link:
http://www.bestbuy.com/site/olspage.jsp?type=page&entryURLType=page&entryURLID=pcat17005&categoryId=cat10005&contentId=1043363607351&id=cat12098
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 14, 2008 | Video Game Consoles & Games
Brother Correctronic 50 typewriter
Dear Brother Customer,
Thank you for your recent inquiry regarding a manual for your Brother
product.
Currently we do not have a downloadable version for this manual and we
appreciate you bringing this to our attention.
This manual is currently available in hard copy. Please see price
information below:
Item: 593640011
Price: $6.11
S&H: $5.75 (Ground)
Sales tax will be added if applicable.
To place an order for any Brother products or accessories you may
call our toll free number 1-800-284-4357 or visit our website at
www.brothermall.com
For your convenience we accept all major credit cards- Visa, MasterCard,
American Express, or Discover.
You may also mail in a check or money order to the address below:
Brother International Corp
PO Box 341332
Bartlett, TN 38184
When placing an order by mail please include your name, address, contact
phone number and the items you wish to order.
Thank you for purchasing genuine Brother products and accessories.
We appreciate your business.
Consumer Sales Dept
www.brothermall.com
Brother International Corporation
Dec 07, 2007 | Office Equipment & Supplies
Acer Aspire 3000 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
